HOW TO unlock SE v600i ??please help HOW TO unlock SE v600i use se-tool ? I can't find this model in se box . please help:( |
Hello, Is it possible to unlock V600i with Setool ? And what are the settings, please ? Thanks to all. |
Bro there two ways of unlocking this phone : 1. identify ur phone & download rest file from support , add in setool/rest folder then directly click on unlock tab. or 2. directly flash ur phone ( tick two options 1. complete phone after flash & 2. unlock phone after flash) |
v600 is there go to sony erricson tab . select k600/V600/K608 model and do wht ever u want as regular |
Hello, Please help me. My v600i is dead after flash. I chose the solutions 2 proposed by sheikh1777, and the phone is dead. Here is the log : ----------------------------------------------------------------------- CFG:001100000000 ChipID:7100,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 BAUDRATE DECREASED OTP LOCKED:1 CID:49 PAF:1 IMEI:35683100009000 CERT:RED REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" STARTING BOOTLOADER... INT LDR:050810 0923 DB2000_CRIPPLED_PRELOADER_SETOOL2_R2B LDR:050926 1421 NPA1CXC1250164_SEMC_PRODUCTION R2D FLASH ID: 200D FOUND VERSION "R2T002_CXC1250074_EU_2_MI" can't open file "C:\Documents and Settings\ordinatop\Bureau\Déblocage\SETOOL (Sony Ericsson)\V1.085\rest\R2T002_CXC1250074_EU_2_MI" SWITCHING TO "USB"... INTERFACE NOT CHANGED Setting up GDFS... WRITING CLEAR SIMLOCK UNITS... SIMLOCK CODES SET TO "24012107" SIGNING... LDR:051125 1048 FILE_SYSTEM_LOADER_SETOOL2_V24 GDFS startup failed,error is 04 [1D] loader GDFS startup failed, that is fatal Elapsed: 90 secs. ----------------------------------------------------------------------------------- After the settings, i clicked on "flash". Please help me to repair the phone. Thanks to all. |
gdfs corrupted you must doing reset procedure read faq |
Hello, Thank you very much, siudziu, but i'm a beginner and i don't know much to use Setool. Then i think i can't make the thirst procedure in the faq. It's to much difficult for me. I don't understand it really. Can you explain me simply what should i do step by step to repair the phone, please ? Thanks to anyone can help me. |
Bro where is flashing Log , Please attach it . i think u have done something wrong in flashing procedure |
Hello sheikh1777, This was the log, after chosing 1 and 2 in settings, and clicking in "flash" button. What should i do now to repair the phone, please ? |
this happened only because u have not added flash files as i say in point 2 . now u download the two files from support area like this 1. r2t002_CXC1250074_EU_2_MI.ssw ( Main file) 2. r2t002_vfe1_fs.ssw (FS file ) while adding these two files follow point no. 2 it will be ok. |
Hello brother, I have selected model k600/v600/k608. I have added the two flash files, as you ask me. Then i ticked options 3 (customize phone after flash) and 4 (unlocking during flash procedure). Then i clicked on "flash" button. But it failed to setup phone. Here is the log : ------------------------------------------------------------------- RUNNING v 1.085/UNI CARD SERIAL 00145096 USBFLASH DRIVER VERSION 02.02.00.05 CFG:001100000000 PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Elapsed: 131 secs. ----------------------------------------------------------------- What should i do, please ? Thanks. |
Check the cable, clean the connector with a needle |
Hello, I have tried several times, and checked cable and connector. The phone doesn't start. It doesn't react at all. Help me please. Thanks to all. |
Hello, Nobody can help me more ? Any solution, please ? Thanks to all. |
Check cable and correct port setting |
