Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | ★ Wholesale Unlock ★ | Direct Unlock Source | Mark Forums Read |
![]() | #18 (permalink) |
Junior Member Join Date: Feb 2009 Location: sunday market
Member: 966375 Status: Offline Thanks Meter: 7 | w395 unlocked ok. hi, i was having trouble unlocking this phone,i kept getting 'power on button shortly' message but se tools would not go any further. do not identify first(this what i had been doing) of course its a w395 go to settings 'signed mode' and 'perform full unlock instead of' use your correct com port and rj cable instead of the dcu cable. THEN if you wish press identify,then press unlock. here is my log, please note the 'proceedure was stopped by user' part was because i had the wrong com port assigned !!!! v0.915038/UNI CARD SERIAL: 000886XX Loaded 51 flash descriptors SIGNED MODE (USING SERVER) CFG:100000100000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... PROCEDURE WAS STOPPED BY USER supported phone was not detected Can't load ID loader ! Elapsed: 168 secs. SIGNED MODE (USING SERVER) CFG:100000100000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... PROCEDURE WAS STOPPED BY USER supported phone was not detected FAILED TO SETUP PHONE Elapsed: 56 secs. SIGNED MODE (USING SERVER) CFG:100000100000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... EROM "R7A024" CID: 0001 SOFTWARE CID: 0001 SIMLOCK STATE: "NOT_TAMPERED" LOADER AID: 0002 LOADER VERSION: "R3A009" PHONE IMEI:35236203154749 MODEL (from GDFS): W395 FACTORY CXC: 1207-7713 R7A024 CURRENT CXC: 12175563_R1CB009 CURRENT CDA: 1223-4226_R4A CURRENT FS: 12182023_FS_WESTERN-EUROPE_HS_YO_R1CB009 LANGUAGE: AL Elapsed: 22 secs. SIGNED MODE (USING SERVER) CFG:100000100000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... EROM "R7A024" CID: 0001 SOFTWARE CID: 0001 SIMLOCK STATE: "NOT_TAMPERED" LOADER AID: 0002 LOADER VERSION: "R3A009" PHONE IMEI:352362031547XX MINOR ERROR "MISC_ERROR (No_such_unit)" IN "MISC_CLASS" Checking for EROM signature... Waiting for calculation process... RESPONSE: "SUCCESS" (2331) GOT SEED:55D5CE97DAE3D0A6F4F429F2 P96 AUTH PASSED Unlock DONE Elapsed: 39 secs. hope this helps, steve. ' |
![]() | #21 (permalink) |
Junior Member ![]() Join Date: Jan 2006 Location: guadeloupe
Member: 220317 Status: Offline Thanks Meter: 2 | is it Normal that the remote dongle is not available until 5 days? i try to unlock a w395 and i always have this message? 17/08/2009 16:06:26 SERVER CREDITS LEFT/USED: 49/11 17/08/2009 16:06:28 CARD COUNTERS: FLASH 101, UNLOCK 110 17/08/2009 16:06:28 Elapsed: 3 secs. 17/08/2009 16:07:09 SIGNED MODE (USING SERVER) 17/08/2009 16:07:09 CFG:10000010000000 17/08/2009 16:07:11 PLEASE ATTACH TURNED OFF PHONE NOW 17/08/2009 16:07:11 PRESS "POWER ON" BUTTON SHORTLY... 17/08/2009 16:07:17 17/08/2009 16:07:17 EROM "R7A024" AID: 0001 17/08/2009 16:07:17 SOFTWARE AID: 0001 17/08/2009 16:07:17 SIMLOCK STATE: "NOT_TAMPERED" 17/08/2009 16:07:18 LOADER AID: 0002 17/08/2009 16:07:23 LOADER VERSION: "R3A011" 17/08/2009 16:07:23 17/08/2009 16:07:23 PHONE IMEI:35236203422095 17/08/2009 16:07:23 MINOR ERROR "MISC_ERROR (No_such_unit)" IN "MISC_CLASS" 17/08/2009 16:07:23 Checking for signature... 17/08/2009 16:07:24 Waiting for calculation process... 17/08/2009 16:07:24 remote dongle not available 17/08/2009 16:07:25 signature calculation not done,err: 144 17/08/2009 16:07:27 Elapsed: 18 secs. |
![]() | #23 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Oct 2007 Location: Ghana
Member: 600628 Status: Offline Thanks Meter: 54 | How to unlock w395 You need only 1 credit to unlock this phone.Just Check this setting. 1)Signed mode( 2)Enable alternative security bypass Thats all you dont need anything again no server down,it works 24 hours |
![]() | #26 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2006 Location: manchester, united kingdom Age: 38
Member: 288521 Status: Offline Thanks Meter: 683 | 07/11/2009 13:48:43 v0.915053/UNI 07/11/2009 13:48:43 CARD SERIAL: 0 07/11/2009 13:48:43 Loaded 51 flash descriptors 07/11/2009 13:48:59 SIGNED MODE (USING SERVER) 07/11/2009 13:48:59 CFG:100000000000 07/11/2009 13:48:59 No server found. 07/11/2009 13:49:01 CARD COUNTERS: FLASH 510, UNLOCK 420 07/11/2009 13:49:01 Elapsed: 2 secs. 07/11/2009 13:49:02 SIGNED MODE (USING SERVER) 07/11/2009 13:49:02 CFG:100000000000 07/11/2009 13:49:02 SERVER CREDITS LEFT/USED: 19/11 07/11/2009 13:49:04 CARD COUNTERS: FLASH 510, UNLOCK 420 07/11/2009 13:49:04 Elapsed: 2 secs. 07/11/2009 13:49:51 SIGNED MODE (USING SERVER) 07/11/2009 13:49:51 ALTERNATIVE SECURITY BYPASS ENABLED 07/11/2009 13:49:51 CFG:110000000000 07/11/2009 13:49:51 PLEASE ATTACH TURNED OFF PHONE NOW 07/11/2009 13:49:51 PRESS AND HOLD "C" BUTTON... 07/11/2009 13:50:05 07/11/2009 13:50:05 EROM "R7A024" AID: 0001 07/11/2009 13:50:05 SOFTWARE AID: 0001 07/11/2009 13:50:05 SIMLOCK STATE: "NOT_TAMPERED" 07/11/2009 13:50:05 LOADER AID: 0002 07/11/2009 13:50:09 FLASH ID: "0001/307E" 07/11/2009 13:50:09 LOADER VERSION: "R3A011" 07/11/2009 13:50:09 07/11/2009 13:50:09 PHONE IMEI: 07/11/2009 13:50:10 GOT SEED:8456FFBB89024007267F28F8 07/11/2009 13:50:11 P96 AUTH PASSED 07/11/2009 13:50:11 Searching... 07/11/2009 13:50:13 SIMLOCK CHECK FOUND 07/11/2009 13:50:13 Writing... 07/11/2009 13:50:14 Unlock DONE 07/11/2009 13:50:14 Elapsed: 22 secs. nice and easy |
![]() | #27 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Nov 2009
Member: 1170910 Status: Offline Thanks Meter: 76 | Sucessfully Unlocked W395 12/30/2009 3:45:17 PM SIGNED MODE (USING SERVER) 12/30/2009 3:45:17 PM CFG:100001000000 12/30/2009 3:45:19 PM PLEASE ATTACH TURNED OFF PHONE NOW 12/30/2009 3:45:19 PM PRESS "POWER ON" BUTTON SHORTLY... 12/30/2009 3:45:45 PM 12/30/2009 3:45:45 PM EROM "R7A024" AID: 0001 12/30/2009 3:45:45 PM SOFTWARE AID: 0001 12/30/2009 3:45:45 PM SIMLOCK STATE: "NOT_TAMPERED" 12/30/2009 3:45:45 PM LOADER AID: 0002 12/30/2009 3:45:50 PM FLASH ID: "00EC/220C" 12/30/2009 3:45:50 PM LOADER VERSION: "R3A011" 12/30/2009 3:45:50 PM 12/30/2009 3:45:50 PM PHONE IMEI:35876xxxxxxxxxx 12/30/2009 3:45:50 PM MINOR ERROR "MISC_ERROR (No_such_unit)" IN "MISC_CLASS" 12/30/2009 3:45:50 PM Checking for signature... 12/30/2009 3:45:53 PM Waiting for calculation process... 12/30/2009 3:46:05 PM RESPONSE: "SUCCESS" [2331] 12/30/2009 3:46:09 PM GOT SEED:A69AB30A8F01402A268C98F0 12/30/2009 3:46:11 PM P96 AUTH PASSED 12/30/2009 3:46:11 PM Unlock DONE 12/30/2009 3:46:13 PM Elapsed: 55 secs. |
![]() | #28 (permalink) |
Registered User ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2005 Location: Turkiye :islam Age: 52
Member: 115596 Status: Offline Sonork: [email protected] Thanks Meter: 1,124 ![]() | 2 credits ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, |
![]() | #29 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Mar 2003 Location: obywatel swiata
Member: 23661 Status: Offline Thanks Meter: 29 | I just tryd new w395, and cant be done coz LOADER ID its 0004 ![]() EROM "R7A024" AID: 0001 SOFTWARE AID: 0001 SIMLOCK STATE: "NOT_TAMPERED" LOADER AID: 0004 phone AID not supported (0004) Can't load ID loader ! |
![]() | #30 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jul 2008 Location: PAKISTAN Age: 35
Member: 812648 Status: Offline Thanks Meter: 80 | SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110000000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... EROM "R7A024" AID: 0001 SOFTWARE AID: 0001 SIMLOCK STATE: "NOT_TAMPERED" LOADER AID: 0002 FLASH ID: "0001/307E" LOADER VERSION: "R3A011" PHONE IMEI:35633603****** GOT SEED:4CA643A98B00C024268B00A1 P96 AUTH PASSED Searching... SIMLOCK CHECK FOUND Writing... Unlock DONE Elapsed: 45 secs. successfully unlocked in 1 credit ![]() |
HOW TO UNLOCK J220i WITH SETOOLS | mbond | Old Ericsson Phones & Sony Phones | 5 | 02-27-2009 07:42 |
How to unlock K800i with SETool? | fonefingz2003 | SETool2 | 7 | 12-14-2007 20:58 |
How To Unlock Db2020 With Setool | smkazim | Sony Ericsson | 3 | 05-24-2007 01:53 |
How To Unlock U8110 With Setool | SixthSence | LG | 3 | 08-03-2005 15:21 |
