Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SETool2
Old 07-17-2010, 08:52   #46 (permalink)
Member: 541724
Sonork: 100.1604043
Thanks Meter: 73
1...segned mode< use serever for bypass/csca
2... enable al ternative secuirty bypass
3.... enable preloader secuirty bypass
than prass unlock button after that fully poweron the phone with test sim install modem drivers and press ready 100% works
if not unlock then try this it will take 1or 2 credits always use latest ver.
segned mode-profam full unlock insterd user code
Old 07-17-2010, 09:38   #47 (permalink)
Member: 1039966
Thanks Meter: 148
w395
This fone it's free dont take credits
Optins:
Signed Mode
Enable Alternative Security Bypass
Enable Preloader Security Bypass
Interface: Com port
Log:
RUNNING v 1.01/UNI
CARD SERIAL 001xxxxx
USBFLASH DRIVER VERSION 02.02.00.05
SIGNED MODE (USING SERVER)
ALTERNATIVE SECURITY BYPASS ENABLED
PRELOADER SECURITY BYPASS ENABLED
CFG:111000000000
PLEASE ATTACH TURNED OFF PHONE NOW
PRESS "POWER ON" BUTTON SHORTLY...
info:
EROM "R7A024" AID: 0001
SOFTWARE AID: 0001
SIMLOCK STATE: "NOT_TAMPERED"
LOADER AID: 0002
FLASH ID: "00EC/220C"
LOADER VERSION: "R3A011"
PHONE IMEI:35236203xxxxx
MODEL (from GDFS): W395
FACTORY CXC: 1207-7713 R7A024
CURRENT CXC: 12175563_R1CB009
CURRENT CDA: 1219-9980_R7A
CURRENT FS: 12182009_FS_FRANCE_HS_YO_R1CB009
LANGUAGE: AL
Elapsed: 25 secs.
Unlock:
CFG:111000000000
SOFTWARE AID: 0001
LOADER AID: 0002
PHONE IMEI:352362039xxxxx
GOT SEED:52E379A88600A0152689C1AF
P96 AUTH PASSED
Searching...
SIMLOCK CHECK FOUND
Writing...
Unlock DONE
Elapsed: 112 secs.
It's Free i dont have any credits in this box
Old 07-17-2010, 09:40   #48 (permalink)
Member: 1039966
Thanks Meter: 148
w395
Originally Posted by mothertelecom View Post
RUNNING v 1.07/UNI
CARD SERIAL 00044583
PLEASE UPGRADE USBFLASH DRIVER 02.02.00.00
CFG:000000000000
PROCEDURE WAS STOPPED BY USER
FAILED TO SETUP PHONE
Elapsed: 200 secs.
CFG:110000000000
PRESS AND HOLD "C" BUTTON...
SOFTWARE AID: 0001
SIMLOCK STATE: "NOT TAMPERED"
LOADER AID: 0004
LOADER VERSION: "R3B004"
PHONE IMEI:35902403093800
phone AID not supported in that mode (0004)
Elapsed: 21 secs. how to unlock plz help me
You must change the port to COM port
and the options are:
Signed Mode
Then click unlock and conect cable in fone whit batary , the operation start and go end whit the fonbe unlock
It's free dont take any credits
Old 07-17-2010, 09:43   #49 (permalink)
Member: 1039966
Thanks Meter: 148
W395 unlock free
SOFTWARE AID: 0001
LOADER AID: 0004
PHONE IMEI:35902403708006
Elapsed: 12 secs.
W395 unlock free
Optins:
Signed Mode
Interface: Com port
Old 07-17-2010, 12:05   #50 (permalink)
Member: 646256
Thanks Meter: 63
Don't post nosenses
did you see
SOFTWARE AID: 0001
LOADER AID: 0004
Elapsed: 12 secs.
Old 07-18-2010, 08:34   #51 (permalink)
Member: 1039966
Thanks Meter: 148
aid 0001,0002,0003 supported......... but 0004 not supported
Originally Posted by KHD19 View Post
Don't post nosenses
did you see
SOFTWARE AID: 0001
LOADER AID: 0004
Elapsed: 12 secs.
aid 0001,0002,0003 supported......... but 0004 is new it might be not supported as yet
Old 07-18-2010, 08:36   #52 (permalink)
Member: 1039966
Thanks Meter: 148
AID 004 not supported
Originally Posted by calhinha View Post
W395 unlock free
Optins:
Signed Mode
Interface: Com port
aid 0001,0002,0003 supported......... but 0004 not supported KHD19 is rigth.
Old 08-07-2010, 14:19   #53 (permalink)
Member: 232607
Sonork: 100.1585040
Thanks Meter: 260
2 credit
CFG:110000000000
SOFTWARE AID: 0001
LOADER AID: 0002
FLASH ID: "0001/307E"
PHONE IMEI:35633603******
GOT SEED:4CA643A98B00C024268B00A1
P96 AUTH PASSED
Searching...
SIMLOCK CHECK FOUND
Writing...
Unlock DONE
Elapsed: 45 secs.
successfully unlocked in 1 credit
perform full unlock user code
its take 2 credit
thanx
Old 08-14-2010, 11:39   #54 (permalink)
Crazy Poster
Member: 143785
Thanks Meter: 2
CFG:110010000000
SOFTWARE AID: 0001
LOADER AID: 0004
PHONE IMEI:35902403520876
Elapsed: 14 secs.
same
LOADER VERSION: "R3B004" cant unlock ?
LOADER VERSION: "R3A011" can ......
Old 08-14-2010, 11:54   #55 (permalink)
dani2080's Avatar
Member: 1055074
Thanks Meter: 7,096
CFG:110010000000
SOFTWARE AID: 0001
LOADER AID: 0004
Elapsed: 14 secs.
same
change usb mode.put usb mode.all will done.luck
Old 08-14-2010, 12:11   #56 (permalink)
Crazy Poster
Member: 143785
Thanks Meter: 2
usb mode already .....
Old 08-14-2010, 12:39   #57 (permalink)
dani2080's Avatar
Member: 1055074
Thanks Meter: 7,096
sorry mistake.here is succefully done log.
w395 successfull flash logs
CFG:101110000000
SOFTWARE AID: 0001
LOADER AID: 0004
PHONE IMEI:35902403301xxx
CURRENT CDA: 1224-7141_R2A
CURRENT FS: 12182017_FS_S-CENTR-AFR_HS_YO_R1CB009
LANGUAGE: AL
Elapsed: 10 secs.
CFG:101110000000
SOFTWARE AID: 0001
LOADER AID: 0004
writing "F:\FIRMWARES\SONY ERICSON\w395\R1CB009_1217_5563_GENERIC_HS_YO_RED.s oftware"
writing "F:\FIRMWARES\SONY ERICSON\w395\R1CB009_1218_2014_FS_RUSSIA_HS_YO_RED .software"
FINALIZING...
USERLOCK RESET TO "0000"
TOTAL CALL TIME RESET
Elapsed: 250 secs.
Old 09-06-2010, 22:19   #58 (permalink)
Member: 59789
Thanks Meter: 16
Originally Posted by media2udirect View Post
hi, i was having trouble unlocking this phone,i kept getting 'power on button shortly' message but se tools would not go any further.
do not identify first(this what i had been doing) of course its a w395
go to settings
'signed mode' and 'perform full unlock instead of'
use your correct com port and rj cable instead of the dcu cable.
THEN if you wish press identify,then press unlock.
here is my log, please note the 'proceedure was stopped by user' part was because i had the wrong com port assigned !!!!
v0.915038/UNI
CARD SERIAL: 000886XX
Loaded 51 flash descriptors
CFG:100000100000000
supported phone was not detected
Can't load ID loader !
Elapsed: 168 secs.
CFG:100000100000000
Elapsed: 56 secs.
CFG:100000100000000
EROM "R7A024" CID: 0001
SOFTWARE CID: 0001
LOADER AID: 0002
LOADER VERSION: "R3A009"
PHONE IMEI:35236203154749
CURRENT CDA: 1223-4226_R4A
CURRENT FS: 12182023_FS_WESTERN-EUROPE_HS_YO_R1CB009
LANGUAGE: AL
Elapsed: 22 secs.
CFG:100000100000000
SOFTWARE CID: 0001
LOADER AID: 0002
PHONE IMEI:352362031547XX
MINOR ERROR "MISC_ERROR (No_such_unit)" IN "MISC_CLASS"
Checking for EROM signature...
Waiting for calculation process...
RESPONSE: "SUCCESS" (2331)
GOT SEED:55D5CE97DAE3D0A6F4F429F2
P96 AUTH PASSED
Unlock DONE
Elapsed: 39 secs.
hope this helps, steve.
here is mt log
CFG:100001000000
SOFTWARE AID: 0001
LOADER AID: 0004
PHONE IMEI:01228800179340
Checking for signature...
RESPONSE: "SUCCESS" [2331]
SAKE AUTH PASSED
Unlock DONE
Elapsed: 32 secs.
thanks
Old 09-07-2010, 14:19   #59 (permalink)
Member: 83870
Thanks Meter: 13
w395 unlock
tick-signmode
tick-alternative sec bypass
clicck -unlock/repair
CFG:110000000000
SOFTWARE AID: 0001
LOADER AID: 0002
PHONE IMEI:35236203299025
GOT SEED:947E2CF38F00602324032AC2
P96 AUTH PASSED
Searching...
SIMLOCK CHECK FOUND
Writing...
Unlock DONE
Elapsed: 120 secs.
The Following User Says Thank You to shaaban . For This Useful Post:
Old 09-14-2010, 18:13   #60 (permalink)
papsnew's Avatar
Member: 390521
Thanks Meter: 57
GUYS we talking about this....
Elapsed: 14 secs.
OPEN your eyes.WE need solution for this not what we all already know
HOW TO UNLOCK J220i WITH SETOOLS mbond Old Ericsson Phones & Sony Phones 5 02-27-2009 07:42
How to unlock K800i with SETool? fonefingz2003 SETool2 7 12-14-2007 20:58
How To Unlock Db2020 With Setool smkazim Sony Ericsson 3 05-24-2007 01:53
How To Unlock U8110 With Setool SixthSence LG 3 08-03-2005 15:21
Page generated in 0.37504 seconds with 10 queries
