Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SETool2
Old 07-08-2012, 22:39   #1 (permalink)
Member: 1271541
Thanks Meter: 35
were withdrawn 3 log while w20i is not unlocking
ChipID: F100, EMP protocol: 0401
PHONE DOMAIN: "RETAIL"
PHONE CID: 0081
OTP LOCKED: 1 CID: 81 PAF: 1 IMEI: 01253000607214 CERT: RED
LDR: 2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096
LDR CAPS: SYSTEM FLASH SIGNATURE AUTH
LDR: 2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096
LDR CAPS: SYSTEM FLASH GDFS FILESYSTEM TA
Executing CSCA-based unlock.
Checking for signature ...
signature found, skipping calculation
server error:remote dongle not available
Unlock FAILED
Elapsed: 12 secs.
SIGNED MODE (USING SERVER)
CFG:100010000000
SERVER CREDITS LEFT/USED: 19/11
CARD COUNTERS: FLASH 174, UNLOCK 161
Elapsed: 2 secs.
Old 07-09-2012, 22:48   #2 (permalink)
cycofcgb's Avatar
Member: 1388004
Sonork: 100.1637034
Thanks Meter: 444
try this :
http://forum.gsmhosting.com/vbb/f473...nlock-1314913/
Old 07-10-2012, 03:29   #3 (permalink)
koperta4512's Avatar
Member: 1704846
Sonork: 1617108
Thanks Meter: 117
Read and unlock phone:
1. select proper model
2. on settings, check
"signed mode",
"do full unlock instead usercode reset",
"disable flash mode activation for semc a2 phones",
fill login details
3. back to semc a2 tab, press unlock
4. when prompted, install phone modem drivers
(they can be found in drivers\Modem_Drivers or will be automatically installed if you install semc pc suite)
5. when you will get message "unlock done" - do not remove cable or battery,wait until phone automatically power on, otherwise you will get 5 locks and need to repeat procedure.
you MUST flash r7cXXX firmware version to be able unlock w20 phone with CSCA method.
Old 07-13-2012, 12:48   #4 (permalink)
Member: 1322963
CFG:100011000000
PHONE CID: 0081
OTP LOCKED: 1 CID: 81 PAF: 1 IMEI: 01253000560323 CERT: RED
Waiting for calculation process ...
RESPONSE: "SUCCESS" [1038]
Backup security data ...
Erasing locks ...
DISCONNECT PHONE NOW
REMOVE SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN
INSTALL PHONE MODEM DRIVERS IF NEEDED
SEARCHING FOR PHONE, "STOP" TO ABORT
PHONE FOUND AT COM103
Phone not responds to AT #1, retry 1
Phone not responds to AT #1, retry 2
Phone not responds to AT #1, retry 3
Phone not responds to AT #1, retry 4
Phone not responds to AT #1, retry 5
CSCA UNLOCK FAILED
Unlock FAILED
Elapsed: 65 secs.
Old 07-13-2012, 21:22   #5 (permalink)
Member: 1704846
Sonork: 1617108
Thanks Meter: 117
"you MUST flash r7cXXX firmware version to be able unlock w20 phone with CSCA method."
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
Page generated in 0.15201 seconds with 9 queries
