10-06-2011, 13:31 | #1 (permalink) |
Freak Poster Join Date: Aug 2006
Member: 340774 Status: Offline Thanks Meter: 164 | w580i gdfs problem.. imei mismatch CFG:000000000100 ChipID:9900,EMP protocol:0301 Speed:921600 LDR:071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M FLASH ID: 897E OTP LOCKED:1 CID:49 PAF:1 IMEI:35240101377821 ACTIVE CID:52 COLOR:RED IMEI MISMATCH ! GDFS IMEI:04857555048575 Model (from GDFS):W850i Brand:Generic MAPP CXC article: R1KG001 prgCXC1250200_GENERIC_CY MAPP CXC version: R1KG001 Language Package: EUROPE_2 CDA article: CDA102677/95 CDA version: R1A Default article: cxc1250489 Default version: R1ED001 PROVIDER: 000-00 SIMLOCKS NOT DETECTED how can i restore its original imei.. anybudy ve nay idea |
10-06-2011, 13:37 | #2 (permalink) |
Product Manager Join Date: Sep 2009 Location: Pakistan Age: 36
Member: 1118710 Status: Offline Sonork: 100.1604414 Thanks Meter: 4,970 | Try to Use RESET METHOD to solve ur problem... |
The Following User Says Thank You to Danish Shafiq For This Useful Post: |
10-06-2011, 13:42 | #3 (permalink) | |
Banned Join Date: Aug 2011
Member: 1629736 Status: Offline Sonork: aayushjaiswal Thanks Meter: 272 | Quote:
10-07-2011, 04:31 | #7 (permalink) |
Member: 1629736 Status: Offline Sonork: aayushjaiswal Thanks Meter: 272 | Update Service Sony Ericsson Update Service (SEUS) "- a convenient way to upgrade the software ( firmware ) the phone . It helps the latest available software to improve the phone . You can access the application " Update Service "via the Internet from your computer . Timely update phone software it provides optimal performance and provides access to new features. Requirements * Access to the Internet (preferably broadband) * USB-cable * To update the PC- card slot is needed for PC- card * Intel ® Pentium ® 4 2.0 GHz or faster , AMD Athlon * 500 MB free hard disk space * 512 MB RAM * 1 free USB 2.0 port * Windows XP ™ (Home or Professional) with Service Pack 2 or later * Microsoft ® Windows Vista ™ ( 32/64-bit ) * Microsoft ® 7 ™ ( 32/64-bit ) With the use SEUS you can update the firmware : Quote: pnx5230: - W350, W380, Z310, Z555 DB2000: - K600, K608, W900 DB2000 (PDA / Smartphones): - G700, G900, Xperia X1, M600, M608, P990, W900, W950, W958, W960, P1 DB2010: - D750, J300, K300, K310, K500, K510, K700, K750, K758, S700, W300, W550, W600, W700, W800, W810, Z520, Z525, Z530, Z550, Z558 DB2012: - K320, W200 DB2020: - K530, K550, K610, K618, K770, K790, K800, K810, K818, S500, T650, V630, W580, W610, W660, W710, W830, W850, W880, W888, Z610, Z710 DB3100 (ODM): - F305, S302, W302, W395 DB3150: - C702, C902, G502, K630, K660, K850, V640, T700, TM506, W595, W760, W890, W902, W910, W980, Z750, Z770, Z780 DB3200/10, 3350 : - C510, C901, C903, C905, G705, G705u, T707, T715, W508, W705, W715, W995, Aino (U10), Yari (U100), Jalou (F100), Naite (J105), Hazel, Elm, X10,, as well as all PC- Card Sony Ericsson - Satio, X1, Xperia Pureness, Xperia X2, Vivaz, X10, X10 mini, X10 mini pro, as well as all PC- Card Sony Ericsson latest sony updater here Update_Service_Setup-2.11.9.6.exe |
10-07-2011, 06:01 | #8 (permalink) | |
No Life Poster Join Date: Mar 2004 Location: jamshedpur Age: 38
Member: 59185 Status: Offline Sonork: 100.1593175 Thanks Meter: 4,911 | Quote:
make recovery and repair imei . | |
10-18-2011, 14:51 | #10 (permalink) |
Registered User Join Date: Oct 2011 Location: noshki balochistan pak
Member: 1669709 Status: Offline Sonork: 1654655 Thanks Meter: 163 | plzzzzzzzzzzz sir help me. k750i gdfs imei and curent imei mismuch?/// PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 FLASH ID: 200D OTP: LOCKED:1 CID:49 PAF:1 IMEI:35570601495645 CERT:RED FLASH CID:49 COLOR:RED IMEI MISMATCH ! GDFS IMEI:35998600495645 Model (from GDFS):K700 MAPP CXC article: R1DB001 prgCXC125952_EU_1_CL MAPP CXC version: R1DB001 Language Package: EMEA_6 CDA article: CDA102295/7 CDA version: R2A Default article: cxc125953 Default version: R1CA021 PROVIDER: 000-00 SIMLOCKS NOT DETECTED USERCODE:0000 RESTORATION FILE PRESENT FOR DETECTED FIRMWARE |
10-18-2011, 14:52 | #11 (permalink) |
Member: 1669709 Status: Offline Sonork: 1654655 Thanks Meter: 163 | sir plzzzzz help k750i imei a nd gdfs imei not metch PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 FLASH ID: 200D OTP: LOCKED:1 CID:49 PAF:1 IMEI:35570601495645 CERT:RED FLASH CID:49 COLOR:RED IMEI MISMATCH ! GDFS IMEI:35998600495645 Model (from GDFS):K700 MAPP CXC article: R1DB001 prgCXC125952_EU_1_CL MAPP CXC version: R1DB001 Language Package: EMEA_6 CDA article: CDA102295/7 CDA version: R2A Default article: cxc125953 Default version: R1CA021 PROVIDER: 000-00 SIMLOCKS NOT DETECTED USERCODE:0000 RESTORATION FILE PRESENT FOR DETECTED FIRMWARE |
10-18-2011, 14:52 | #12 (permalink) |
10-18-2011, 15:18 | #13 (permalink) |
Member: 1118710 Status: Offline Sonork: 100.1604414 Thanks Meter: 4,970 | Follow This Step to solve ur problem.. 1. go to emptyboard tab 2. select proper model 3. on settings, check "signed mode" 4. press recovery 5. after successful recovery 6. on settings uncheck all 7. if gdfs totally damaged, add to firmware area proper gdfs in ssw format,otherwise skip that step 8. add to firmware area proper EROM (EROM CID >= OTP CID) 9. press flash 10. if needed,reflash phone on usual semc tab with needed settings. & Post result.. |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
Nokia 51xx/61xx imei changer ver. 1.10?????? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 04-06-2012 16:22 |
6110 imei changer !!!!!! | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 11-21-2011 01:44 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
