Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SETool2
Old 05-26-2015, 11:57   #1 (permalink)
Crazy Poster
Member: 1340219
Thanks Meter: 25
3 credit lose during unlock w20i
RUNNING v 1.1415/01.15/UNI
CARD SERIAL 00181385
USBFLASH DRIVER VERSION 03.00.00.00
SIGNED MODE (USING SERVER)
CFG:100000000000
short credits consumption list :
Services OFFLINE
S1 v1,v2,S1 OPEN AID 004,FLASHMODE activation
Services ONLINE
A1 phones, CSCA unlock/repair 03 credits
A2 phones, CSCA unlock/repair 03 credits
S1 OPEN, CSCA unlock/repair 03 credits
W100,W150 unlock codes 01 credits
S1 QSD8250,MSM7227,MSM8255 alternative bypass unlock/repair 01 credits
ST21,ST21i2,ST23,ST26,C150x,C160x alternative bypass unlock 01 credits
You CAN NOT unlock next phones, when S1 services offline:
u1/u5/u8 with loader AID 004,
LoCosto,Neptune-based phones with loader AID 004,
LoCosto,Neptune-based phones with damaged security zone,
w100,w150 full unlock,ck13,ck15,wt13,
any SONY phone, released from 2012 year,except
ST21,ST21i2,ST23,ST26,C150x,C160x phones
S1 QSD8250,MSM7227,MSM8255 alternative bypass STANDALONE activation 10 credits
ST21,ST21i2,ST23,ST26,C150x,C160x alternative bypass unlock/repair FREE, if you have this activation
CFG:100010000000
ChipID: F100, EMP protocol: 0401
PHONE DOMAIN: "RETAIL"
PHONE CID: 0081
OTP: LOCKED:1 CID:81 PAF:1 IMEI:01238200087755 CERT:RED
LDR: 2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096
LDR CAPS: SYSTEM FLASH SIGNATURE AUTH
LDR: 2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096
LDR CAPS: SYSTEM FLASH GDFS FILESYSTEM TA
Executing CSCA-based unlock.
Checking for signature ...
Waiting for calculation process ...
RESPONSE: "SUCCESS" [1038]
server error:remote dongle not available
Unlock FAILED
Unlock FAILED
Elapsed: 9 secs.
Old 05-26-2015, 12:43   #2 (permalink)
moshman's Avatar
Member: 193192
Thanks Meter: 327
No you just failed to read FAQ full procedure
if s1 signature server offline, you can not use quick (without modem drivers) unlock.
instead, you should :
select proper model
2.
on settings, check
"signed mode",
"do full unlock instead usercode reset",
"disable flash mode activation for semc a2 phones",
fill login details
3.
back to semc a2 tab, press unlock
4.
when prompted, install phone modem drivers
(they can be found in drivers\Modem_Drivers or will be automatically installed if you install semc pc suite)
5.
when you will get message "unlock done" - do not remove cable or battery,
wait until phone automatically power on, otherwise you will get 5 locks and need to repeat procedure.
Old 05-26-2015, 14:31   #3 (permalink)
Crazy Poster
Member: 1340219
Thanks Meter: 25
after procedure S1 OPEN,CSC unlock/repair 03 credits
after procedure
CFG:000000000000
Services OFFLINE
Services ONLINE
current updater version: 0.95
current setool2 version: 1.1416
request denied.
CARD COUNTERS: FLASH 91, UNLOCK 43
Elapsed: 2 secs.
CFG:100011000000
PHONE CID: 0081
signature found, skipping calculation
Backup security data ...
Erasing locks ...
DISCONNECT PHONE NOW
REMOVE SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN
INSTALL PHONE MODEM DRIVERS IF NEEDED
SEARCHING FOR PHONE, "STOP" TO ABORT
PHONE FOUND AT COM565
Phone not responding to AT #1, retry 1
Phone not responding to AT #1, retry 2
Phone not responding to AT #1, retry 3
Phone not responding to AT #1, retry 4
Phone not responding to AT #1, retry 5
CSCA UNLOCK FAILED
Unlock FAILED
Elapsed: 211 secs.
Old 05-26-2015, 17:25   #4 (permalink)
moshman's Avatar
Member: 193192
Thanks Meter: 327
You MUST flash r7cXXX firmware version to be able unlock w20 phone with CSCA method.
This is mentioned in FAQ already.
HOW TO WORK WITH A2-BASED PHONES
The Following User Says Thank You to moshman For This Useful Post:
Old 05-26-2015, 19:16   #5 (permalink)
Crazy Poster
Member: 1340219
Thanks Meter: 25
Unlock done after flash it
TNX moshman
elapsed: 9 secs.
Signed mode (using server)
cfg:100011000000
chipid: F100, emp protocol: 0401
phone domain: "retail"
phone cid: 0081
otp: Locked:1 cid:81 paf:1 imei:01238200087755 cert:red
ldr: 2010-03-02 18:05 1212-4656_db3350_cs_loader_acc_sdram_r2a096
ldr caps: System flash signature auth
ldr: 2010-03-02 18:06 1212-4655_db3350_cs_loader_app_sdram_r2a096
ldr caps: System flash gdfs filesystem ta
executing csca-based unlock.
Signature found, skipping calculation
backup security data ...
Erasing locks ...
Disconnect phone now
remove sim card, fully turn phone on and attach again
install phone modem drivers if needed
searching for phone, "stop" to abort
phone found at com565
phone ready to proceed.
Got seed: 006f4485
activation completed. Usercode reset to "0000"
do not disconnect phone from cable
until phone turns on by itself
unlock done
Page generated in 0.19761 seconds with 8 queries
