Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SETool2
Old 10-22-2012, 04:44   #1 (permalink)
aermacchi's Avatar
Member: 778507
Sonork: 100.1640413
Thanks Meter: 265
Samsung A687 unlock done by SETOOLS
UNIT: Samsung A687
DIAGNOSTIC:
Phone Freeze
TOOLS:
  • SETOOLS
  • CA-101 usb cable(5130c)
PROCEDURE:
  • Open "SETOOLS GUI"
  • Select "SEMC A2" tab
  • in "Phone Type"
    • Select phone model(SAMSUNG SGH-A687)
  • Tick "Settings" tab
    • tick "SIGNED MODE"
  • Tick back "SEMC A2" tab
  • then tick "Unlock/Repair"
  • in phone press ang hold 1 and 0 keys
  • connect phone without battery
  • wait till finished...
here's my logs..
here's how to enter freeze code:
type the freeze code(in my case 14707283)then press ok or center button
[COLOR="*****Brown"]NOTE:[/COLOR] "YOU CAN'T SEE THE NUMBER THAT YOU ARE TYPING"
then it shows "INVALID SIM CARD NETWORK LOCK"
then press unlock
then enter "NETWORK UNLOCK CODE" (in my case 73637572)
here's my finished product:
hope it will help..
thanks,
br,
Aermacchi
The Following 10 Users Say Thank You to aermacchi For This Useful Post:
Old 11-06-2012, 14:20   #2 (permalink)
Member: 246917
Thanks Meter: 3
RUNNING v 1.1292/01.12/UNI
CARD SERIAL
USBFLASH DRIVER VERSION 03.00.00.00
SIGNED MODE (USING SERVER)
CFG:100000000000
ChipID: D900, EMP protocol: 0401
BOOTROM MODE DETECTED
OTP DBG: [1,26,0,35557503120248]
OTP LOCKED: 1 CID: 26 PAF: 0 IMEI: 35557503120248 CERT: BROWN
LDR: 090325 1251 RFACXC1723918_A9_DB3200_PRODUCTION_LOADER_ACC_SDRA M_P5C
LDR CAPS: SYSTEM FLASH SIGNATURE
LDR: 090325 1345 RFACXC1723919_1A9_DB3200_PRODUCTION_LOADER_APP_SDR AM_JEFF_CABS_P5C
LDR CAPS: SYSTEM FLASH GDFS FILESYSTEM
UNFREEZE CODE: 42586290
[NETWORK UNLOCK] #7465625*638*70809470#
[SUBSET UNLOCK] #7465625*782*00000000#
[SP UNLOCK] #7465625*77*00000000#
[CP UNLOCK] #7465625*27*00000000#
Unlock DONE
Elapsed: 226 secs.
Old 02-19-2013, 06:36   #3 (permalink)
Member: 199050
Thanks Meter: 4
Originally Posted by aermacchi View Post
UNIT: Samsung A687
DIAGNOSTIC:
Phone Freeze
TOOLS:
  • SETOOLS
PROCEDURE:
  • in "Phone Type"
here's my logs..
then press unlock
hope it will help..
thanks,
br,
Aermacchi
exactly which drivers that you used?
can give us a link.
the device was installed but the software could not
detect anything.
Old 09-05-2014, 14:01   #4 (permalink)
Member: 1328210
Sonork: NONE
thanks po sa magadang mong post ...its already done...
Old 03-19-2015, 09:41   #5 (permalink)
Member: 1355941
Thanks Meter: 10
thanks my problem soloved
Old 10-11-2021, 19:35   #6 (permalink)
Member: 2358876
Thanks Meter: 78
UNIT: Samsung A687
DIAGNOSTIC:
Phone Freeze
TOOLS:
  • SETOOLS
PROCEDURE:
  • in "Phone Type"
here's my logs..
then press unlock
hope it will help..
y
thanks,
br,
Aermacchi
THIS procedure worked 10000....% and Tested by SirReal
Page generated in 0.14270 seconds with 8 queries
