10-24-2009, 17:24 | #1 (permalink) |
Freak Poster Join Date: May 2004 Location: INDIA Age: 46
Member: 67260 Status: Offline Thanks Meter: 146 | sony k530i dead failed to setup GDFS Loaded 51 flash descriptors CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 FLASH ID:897E OTP: LOCKED:1 CID:51 PAF:1 IMEI:35901901797489 CERT:N/A FLASH CID:52 COLOR:RED can't get packet start. packet not acknowledged (17) setGDFS_params failed failed to setup GDFS Elapsed: 76 secs. how to solve this problem..... ? |
10-24-2009, 19:11 | #2 (permalink) | |
No Life Poster Join Date: Nov 2007 Location: inside nck
Member: 628112 Status: Offline Sonork: 100.1589052 Thanks Meter: 3,726 | Quote:
10-24-2009, 22:35 | #3 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Pakistan/UAE/WorldWide
Member: 417298 Status: Offline Sonork: 100.1578269 Thanks Meter: 18,268 | GDFS corrupted repair with reset method for all information check FAQ http://forum.gsmhosting.com/vbb/showthread.php?t=699462 post 51 |
05-15-2010, 09:38 | #4 (permalink) |
Banned Join Date: Dec 2009 Location: india
Member: 1178099 Status: Offline Sonork: 143 Thanks Meter: 3 | SIGNED MODE (USING SERVER) CFG:100100000000 Will backup GDFS now. ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35901901551729 CERT:N/A FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID:897E LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed GDFS startup failed,error is 04 [1D] loader GDFS startup failed, that is fatal Elapsed: 21 secs. SIGNED MODE (USING SERVER) CFG:100100000000 Will write GDFS now. ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35901901551729 CERT:N/A FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID:897E LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed GDFS startup failed,error is 04 [1D] loader GDFS startup failed, that is fatal Elapsed: 21 secs. SIGNED MODE (USING SERVER) CFG:100100000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35901901551729 CERT:N/A FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID:897E writing "I:\SETOOL-3\SONYERICSSON SETOOL FLASH FILES\SETOOL-LITE\K530\CID-52\K530_R8BB001_MAIN_GENERIC_NC_RED52.mbn" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is: 9200 Will flash 460 blocks... writing "I:\SETOOL-3\SONYERICSSON SETOOL FLASH FILES\SETOOL-LITE\K530\CID-52\K530_R8BB001_FS_BALTIC_RED52.fbn" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is: 3140 Will flash 157 blocks... LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed GDFS startup failed,error is 04 [1D] loader GDFS startup failed, that is fatal Elapsed: 815 secs. |
05-15-2010, 10:01 | #5 (permalink) |
Member: 1178099 Status: Offline Sonork: 143 Thanks Meter: 3 | i will flashe k530i but loader startup: executed GDFS startup failed,error is 04 [1D] loader GDFS startup failed, that is fatal Elapsed: 670 secs. pls help me |
05-15-2010, 20:07 | #6 (permalink) |
No Life Poster Join Date: Jun 2006 Location: {JUST@PRAY@FOR@ME} Age: 39
Member: 288504 Status: Offline Sonork: .:100.1587032:. Thanks Meter: 2,266 | Do it first: 1. select proper model 2. on settings, check "signed mode" 3. press identify 4. after that Flash the phone with setting 1. check "signed mode" 2. customize phone after flash if not done then: 1. go to emptyboard tab 2. select proper model 3. on settings, check "signed mode" 4. press recovery (Reset Procedure, Need 1 Credits) 5. after successful recovery 6. on settings uncheck all 7. if gdfs totally damaged, add to firmware area proper gdfs in ssw format,otherwise skip that step 8. add to firmware area proper EROM (EROM CID >= OTP CID) 9. press flash 10. if needed,reflash phone on usual semc tab with needed settings. |
The Following User Says Thank You to roney_nexus For This Useful Post: |
05-15-2010, 20:32 | #7 (permalink) | |
No Life Poster Join Date: Sep 2007 Location: algeria
Member: 591880 Status: Offline Thanks Meter: 561 | Quote:
05-20-2010, 08:37 | #9 (permalink) |
Member: 1178099 Status: Offline Sonork: 143 Thanks Meter: 3 | CFG:000000000000 RECOVERY MODE STARTED ChipID:9900,EMP protocol:0301 Speed:921600 REC:070703 1229 NPA4_CXC1329130_DB2020_SEMC_RECOVERY_P3N can't open file "frec\marikabrowncid52.bin" Recovery failed. Phone dead. Elapsed: 2 secs. |
05-20-2010, 09:03 | #10 (permalink) | |
Member: 288504 Status: Offline Sonork: .:100.1587032:. Thanks Meter: 2,266 | Quote:
2. select proper model 3. on settings, check "signed mode" 4. press recovery 5. after succeful recovery 6. on settings uncheck all 7. if gdfs totally damaged, add to firmware area proper gdfs in ssw format,otherwise skip that step 8. add to firmware area proper EROM (EROM CID >= OTP CID) 9. press flash 10. if needed,reflash phone on usual semc tab with needed settings. | |
The Following 2 Users Say Thank You to roney_nexus For This Useful Post: |
06-24-2010, 19:43 | #11 (permalink) |
Insane Poster Join Date: Jan 2009
Member: 936481 Status: Offline Sonork: saeedbaco Thanks Meter: 11 | CFG:001010000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35901901788418 ACTIVE CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID: 897E writing "C:\Program Files\se\flash\K530i\r6bc002_cxc1250912_nc_red_cid 53.software" CURRENT FLASH FILE CID:53 SSW uses full hash, hash len is: 9200 HDR block not accepted,error: 19 Elapsed: 13 secs. please help bro |
06-24-2010, 20:00 | #12 (permalink) | |
please check FAQ for details. | |
06-25-2010, 07:20 | #13 (permalink) | |
Junior Member Join Date: Jul 2009 Location: iran
Member: 1074300 Status: Offline Thanks Meter: 3 | Quote:
06-26-2010, 06:53 | #14 (permalink) |
Member: 936481 Status: Offline Sonork: saeedbaco Thanks Meter: 11 | CFG:001010000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35901901788418 ACTIVE CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID: 897E writing "C:\Program Files\se\flash\K530i\R8BB001_1250912_GENERIC_NC.ss w" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is: 9200 HDR block not accepted,error: 19 Elapsed: 22 secs. please help bro |
06-26-2010, 07:48 | #15 (permalink) | |
CID 50,51,52,53 that is so-called reset procedure. 1. go to emptyboard tab 2. select proper model 3. on settings, check "signed mode" 4. press recovery 5. after succeful recovery 6. on settings uncheck all 7. if gdfs totally damaged, add to firmware area proper gdfs in ssw format,otherwise skip that step 8. add to firmware area proper EROM (EROM CID >= OTP CID) 9. press flash 10. if needed,reflash phone on usual semc tab with needed settings. Try To Result Me Thx.... | |
lost credit loss but failed to reconstuction gdfs k320(cid detect 51) | sharky_tan | Cruiser Suite | 4 | 04-24-2010 10:24 |
W850 failed to setup phone | dapinderjit | Sony Ericsson | 4 | 02-08-2010 18:05 |
j132 FAILED TO SETUP PHONE | GMC | SETool2 | 5 | 01-30-2010 01:13 |
Se w700 failed to setup phone | ..::khaled::.. | SETool2 | 1 | 01-26-2010 09:50 |
P1 cid 53 failed to setup GDFS | Winston rio hum | SETool2 | 3 | 11-26-2008 17:48 |
