K550 ,,, not unlocking HI I HAVE THIS K550 WHICH I AM TRING TO UNLOCK,, BUT IT SAYS NO EXECUTOR FOUND .... I DOWNLOADED THE GENERIC FILE AND FLASH THE PHONE STILL THE SAME SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:101000100000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" PM FLASH CID: 0052 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35273302012750 CERT:RED FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 PM loader startup: executed PM loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM81 PHONE READY TO PROCEED There is NO EXECUTOR in phone ! |
your phone is k550 or K550 I mode ? |
K550im pls help br nikki |
if cid 51 or 52 use old vertion lik v0.914023 , select : -complet phone -unlock after flash -use server -enable alternative -do ful unlock and flash it ;) |
Flash k550 52 and unlock using bypass 100% |
@indikait tried that but no luck wbr |
worked fine,, fully flashed thanx wbr nikki |
