03-29-2010, 21:57 | #1 (permalink) |
No Life Poster Join Date: Jun 2008 Location: ****** Age: 45
Member: 801286 Status: Offline Sonork: [email protected] Thanks Meter: 54 | plz helpe g700 RUNNING v 1.02/UNISIGNED MODE (USING SERVER) CFG:100100000000 writing "F:\G700_MR2_HEBREW__R9N002_R1F_R6K842_R6K836_.zip " Processing package F:\G700_MR2_HEBREW__R9N002_R1F_R6K842_R6K836_.zip detected MASTER on COM5, SLAVE on COM6 PDA EROM VERSION: 1202-0237 R1A01 package not contains ISP files Processing ACPU files PROCESSING: Core OS FILE FLASHED OK PROCESSING: ROFS1 FILE FLASHED OK PROCESSING: ROFS1 Extension FILE FLASHED OK PROCESSING: ROFS2 FILE FLASHED OK PROCESSING: USERDATA FILE FLASHED OK PLEASE IGNORE "PRESS POWER ON" MESSAGES !!!! fetched MASTER on COM5, SLAVE on COM6 |
06-24-2010, 11:03 | #3 (permalink) |
No Life Poster Join Date: Nov 2008 Location: RVIII
Member: 890926 Status: Offline Thanks Meter: 2,057 | Be sure PC identifies phone, Install needed drivers, Open SW Go to PDA Tab, choose Model, Add File G700 in RAR Format, go to Settings Check Signed Mode Back to PDA Tab Click Flash. |
The Following User Says Thank You to xerraco For This Useful Post: |
06-24-2010, 12:04 | #4 (permalink) |
Insane Poster Join Date: Jan 2010 Location: center of the earth <hell>
Member: 1219358 Status: Offline Sonork: misu Thanks Meter: 27 | tnx tnx my phone works now this is my log ..a very long one :| but mabey it will help others SIGNED MODE (USING SERVER) CFG:100000000000 writing "C:\Documents and Settings\George\My Documents\Downloads\G700c_Generic_PRC_CDF1205_0658 .zip" Processing package C:\Documents and Settings\George\My Documents\Downloads\G700c_Generic_PRC_CDF1205_0658 .zip DETECTED PORTS [MASTER COM74,SLAVE COM75] PDA EROM VERSION: 1202-0237 R1A01 package not contains ISP files Processing ACPU files PROCESSING: Core OS FILE FLASHED OK PROCESSING: ROFS1 FILE FLASHED OK PROCESSING: ROFS1 Extension FILE FLASHED OK PROCESSING: ROFS2 FILE FLASHED OK PROCESSING: USERDATA FILE FLASHED OK PLEASE IGNORE "PRESS POWER ON" MESSAGES !!!! DETECTED PORTS [MASTER COM74,SLAVE COM75] NEW SECURITY (RESPIN) PHONE ChipID:7100,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 OTP LOCKED:1 CID:52 PAF:1 IMEI:35388702185580 CERT:RED LDR:060524 0930 LIECXC1325414_DB2000_FLASHLOADER_R1A003 FLASH ID: 8964 Processing CCPU files PROCESSING: R5C01_1203_6568_CCPU_fs_JO_TY_Red_CID53_DB2001.sof tware CURRENT FLASH FILE CID:53 SSW uses full hash, hash len is: 160 Will flash 8 blocks... PROCESSING: R9N002_1203_6566_CCPU_JO_TY_Red_CID53_DB2001.softw are CURRENT FLASH FILE CID:53 SSW uses full hash, hash len is: 2120 Will flash 106 blocks... Processing update files LDR:070405 1245 NPA1_CXC1327363_1_SEMC_CS_LOADER_1_P1E loader GDFS startup executed PROCESSING: R1A_Dpy_z_reset_Josephine.gdfs Writing GDFS var 0000/0002/0004 Writing GDFS var 0000/0003/0004 Writing GDFS var 0000/0004/0001 Writing GDFS var 0000/0005/0026 Writing GDFS var 0000/0007/0002 Writing GDFS var 0000/0010/000C Writing GDFS var 0000/0011/0001 Writing GDFS var 0000/0012/0001 Writing GDFS var 0000/0014/000E Writing GDFS var 0000/0015/0002 Writing GDFS var 0000/0016/0002 Writing GDFS var 0000/0017/0001 Writing GDFS var 0000/0018/0001 Writing GDFS var 0000/0019/0018 Writing GDFS var 0000/001A/0001 Writing GDFS var 0000/001B/0002 Writing GDFS var 0000/001C/0001 Writing GDFS var 0000/002A/0001 Writing GDFS var 0000/002E/0002 Writing GDFS var 0000/002F/0001 Writing GDFS var 0000/0030/0001 Writing GDFS var 0000/0031/0001 Writing GDFS var 0000/0032/0001 Writing GDFS var 0000/0033/0001 Writing GDFS var 0000/0034/0005 Writing GDFS var 0000/0035/0001 Writing GDFS var 0000/0038/0001 Writing GDFS var 0000/003D/0001 Writing GDFS var 0000/003E/0002 Writing GDFS var 0000/003F/0001 Writing GDFS var 0000/0040/0001 Writing GDFS var 0000/0041/0001 Writing GDFS var 0000/0042/0001 Writing GDFS var 0000/0043/0002 Writing GDFS var 0000/0044/0002 Writing GDFS var 0000/0045/0002 Writing GDFS var 0000/0046/0001 Writing GDFS var 0000/0047/0001 Writing GDFS var 0000/0048/0002 Writing GDFS var 0000/0049/0002 Writing GDFS var 0000/004A/0002 Writing GDFS var 0000/004B/001E Writing GDFS var 0000/004C/0002 Writing GDFS var 0000/004D/0002 Writing GDFS var 0000/004E/000A Writing GDFS var 0000/004F/0002 Writing GDFS var 0000/0050/0001 Writing GDFS var 0000/0051/0001 Writing GDFS var 0000/0052/0014 Writing GDFS var 0000/0054/000E Writing GDFS var 0000/0055/000E Writing GDFS var 0000/0056/0002 Writing GDFS var 0000/0057/0002 Writing GDFS var 0000/0058/0002 Writing GDFS var 0000/0059/0002 Writing GDFS var 0000/005A/0001 Writing GDFS var 0000/005B/0001 Writing GDFS var 0000/005C/000A Writing GDFS var 0000/005E/0001 Writing GDFS var 0000/0061/000A Writing GDFS var 0000/0062/0002 Writing GDFS var 0000/0063/0002 Writing GDFS var 0000/0064/0002 Writing GDFS var 0000/0065/0002 Writing GDFS var 0000/0066/0002 Writing GDFS var 0000/0067/0044 Writing GDFS var 0000/0068/0004 Writing GDFS var 0000/0069/0001 Writing GDFS var 0000/006A/0001 Writing GDFS var 0000/006B/0001 Writing GDFS var 0000/006C/000D Writing GDFS var 0000/006D/0002 Writing GDFS var 0000/006E/0001 Writing GDFS var 0000/006F/0001 Writing GDFS var 0000/0070/0001 Writing GDFS var 0000/0071/0001 Writing GDFS var 0000/0072/0001 Writing GDFS var 0000/0073/0001 Writing GDFS var 0000/0083/0001 Writing GDFS var 0000/0084/0001 Writing GDFS var 0000/0085/000A Writing GDFS var 0000/0086/0002 Writing GDFS var 0000/0087/001E Writing GDFS var 0000/0088/0002 Writing GDFS var 0000/0089/0002 Writing GDFS var 0000/008A/0002 Writing GDFS var 0000/008B/0002 Writing GDFS var 0000/008C/0002 Writing GDFS var 0000/008D/0002 Writing GDFS var 0000/008E/0001 Writing GDFS var 0000/008F/0013 Writing GDFS var 0000/0090/0001 Writing GDFS var 0000/0091/0001 Writing GDFS var 0000/0092/0003 Writing GDFS var 0000/0093/0009 Writing GDFS var 0000/0094/0001 Writing GDFS var 0000/0095/0001 Writing GDFS var 0000/0096/0001 Writing GDFS var 0000/0097/0001 Writing GDFS var 0000/0098/0001 Writing GDFS var 0000/0099/0003 Writing GDFS var 0000/009A/0003 Writing GDFS var 0000/009B/0004 Writing GDFS var 0000/009C/0004 Writing GDFS var 0000/009D/0004 Writing GDFS var 0000/009E/0004 Writing GDFS var 0000/009F/0008 Writing GDFS var 0000/00A0/0005 Writing GDFS var 0000/00A1/0001 Writing GDFS var 0000/00A2/0001 Writing GDFS var 0000/00A3/0001 Writing GDFS var 0000/00A4/0001 Writing GDFS var 0000/00A5/0001 Writing GDFS var 0000/00A6/0005 Writing GDFS var 0000/00A8/0001 Writing GDFS var 0000/00A9/0001 Writing GDFS var 0000/00AA/000A Writing GDFS var 0000/00AC/0001 Writing GDFS var 0000/00AE/0001 Writing GDFS var 0000/00AF/0001 Writing GDFS var 0000/00B0/000A Writing GDFS var 0000/00B1/0002 Writing GDFS var 0000/00B2/0005 Writing GDFS var 0000/00B3/0002 Writing GDFS var 0000/00B4/0002 Writing GDFS var 0000/00B5/0002 Writing GDFS var 0000/00B6/0002 Writing GDFS var 0000/00B7/0001 Writing GDFS var 0000/00B8/0001 Writing GDFS var 0000/00B9/0001 Writing GDFS var 0000/00BA/0001 Writing GDFS var 0000/00E2/0006 Writing GDFS var 0001/00E8/0001 Writing GDFS var 0001/00E9/0001 Writing GDFS var 0001/00EA/0001 Writing GDFS var 0001/00EB/0001 Writing GDFS var 0001/00EC/0001 Writing GDFS var 0001/00ED/0001 Writing GDFS var 0001/00EE/0001 Writing GDFS var 0001/00EF/0001 Writing GDFS var 0001/00F0/0007 Writing GDFS var 0001/00F1/0007 Writing GDFS var 0001/00F2/0007 Writing GDFS var 0001/00F3/0007 Writing GDFS var 0001/00F4/0001 Writing GDFS var 0001/00F9/0001 Writing GDFS var 0001/00FA/0001 Writing GDFS var 0001/00FB/0001 Writing GDFS var 0001/00FC/0001 Writing GDFS var 0001/00FF/0060 Writing GDFS var 0001/0103/0010 Writing GDFS var 0001/010C/0008 Writing GDFS var 0001/010D/0008 Writing GDFS var 0001/010E/0008 Writing GDFS var 0001/010F/0008 Writing GDFS var 0001/0110/0001 Writing GDFS var 0001/0111/0001 Writing GDFS var 0001/0112/0001 Writing GDFS var 0001/0113/0001 Writing GDFS var 0001/0114/0040 Writing GDFS var 0001/0115/0040 Writing GDFS var 0001/0116/0040 Writing GDFS var 0001/0117/0040 Writing GDFS var 0001/0118/0040 Writing GDFS var 0001/0119/0040 Writing GDFS var 0001/011A/0040 Writing GDFS var 0001/011B/0040 Writing GDFS var 0001/011C/0006 Writing GDFS var 0001/011D/0006 Writing GDFS var 0001/011E/0006 Writing GDFS var 0001/011F/0006 Writing GDFS var 0001/0120/0001 Writing GDFS var 0001/0121/0001 Writing GDFS var 0001/0122/0001 Writing GDFS var 0001/0123/0001 Writing GDFS var 0001/0124/0024 Writing GDFS var 0001/0125/0024 Writing GDFS var 0001/0126/0024 Writing GDFS var 0001/0127/0024 Writing GDFS var 0001/0164/0001 Writing GDFS var 0001/0165/0001 Writing GDFS var 0001/0166/0001 Writing GDFS var 0001/0167/0001 Writing GDFS var 0001/0168/0007 Writing GDFS var 0001/0169/0007 Writing GDFS var 0001/016A/0007 Writing GDFS var 0001/016B/0007 Writing GDFS var 0001/0170/0020 Writing GDFS var 0001/0171/0020 Writing GDFS var 0001/0172/0020 Writing GDFS var 0001/0173/0020 Writing GDFS var 0001/0174/0020 Writing GDFS var 0001/0175/0020 Writing GDFS var 0001/0176/0020 Writing GDFS var 0001/0177/0020 Writing GDFS var 0001/0178/0020 Writing GDFS var 0001/0179/0020 Writing GDFS var 0001/017A/0020 Writing GDFS var 0001/017B/0020 Writing GDFS var 0001/017C/0020 Writing GDFS var 0001/017D/0020 Writing GDFS var 0001/017E/0020 Writing GDFS var 0001/017F/0020 Writing GDFS var 0001/0180/0020 Writing GDFS var 0001/0181/0020 Writing GDFS var 0001/0182/0020 Writing GDFS var 0001/0183/0020 Writing GDFS var 0001/0184/0020 Writing GDFS var 0001/0185/0020 Writing GDFS var 0001/0186/0020 Writing GDFS var 0001/0187/0020 Writing GDFS var 0001/0188/0020 Writing GDFS var 0001/0189/0020 Writing GDFS var 0001/018A/0020 Writing GDFS var 0001/018B/0020 Writing GDFS var 0001/018C/0020 Writing GDFS var 0001/018D/0020 Writing GDFS var 0001/018E/0020 Writing GDFS var 0001/018F/0020 Writing GDFS var 0001/0190/0020 Writing GDFS var 0001/0191/0020 Writing GDFS var 0001/0192/0020 Writing GDFS var 0001/0193/0020 Writing GDFS var 0001/0194/0020 Writing GDFS var 0001/0195/0020 Writing GDFS var 0001/0196/0020 Writing GDFS var 0001/0197/0020 Writing GDFS var 0001/0198/0020 Writing GDFS var 0001/0199/0020 Writing GDFS var 0001/019A/0020 Writing GDFS var 0001/019B/0020 Writing GDFS var 0001/019C/0020 Writing GDFS var 0001/019D/0020 Writing GDFS var 0001/019E/0020 Writing GDFS var 0001/019F/0020 Writing GDFS var 0001/01A0/0020 Writing GDFS var 0001/01A1/0020 Writing GDFS var 0001/01A2/0020 Writing GDFS var 0001/01A3/0020 Writing GDFS var 0001/01A4/0020 Writing GDFS var 0001/01A5/0020 Writing GDFS var 0001/01A6/0020 Writing GDFS var 0001/01A7/0020 Writing GDFS var 0001/01A8/0020 Writing GDFS var 0001/01A9/0020 Writing GDFS var 0001/01AA/0020 Writing GDFS var 0001/01AB/0020 Writing GDFS var 0001/01AC/0020 Writing GDFS var 0001/01AD/0020 Writing GDFS var 0001/01AE/0020 Writing GDFS var 0001/01AF/0020 Writing GDFS var 0001/01B0/0020 Writing GDFS var 0001/01B1/0020 Writing GDFS var 0001/01B2/0020 Writing GDFS var 0001/01B3/0020 Writing GDFS var 0001/01B4/0020 Writing GDFS var 0001/01B5/0020 Writing GDFS var 0001/01B6/0020 Writing GDFS var 0001/01B7/0020 Writing GDFS var 0001/01B8/0020 Writing GDFS var 0001/01B9/0020 Writing GDFS var 0001/01BA/0020 Writing GDFS var 0001/01BB/0020 Writing GDFS var 0001/01BC/0020 Writing GDFS var 0001/01BD/0020 Writing GDFS var 0001/01BE/0020 Writing GDFS var 0001/01BF/0020 Writing GDFS var 0001/01C0/0020 Writing GDFS var 0001/01C1/0020 Writing GDFS var 0001/01C2/0020 Writing GDFS var 0001/01C3/0020 Writing GDFS var 0001/01C4/0020 Writing GDFS var 0001/01C5/0020 Writing GDFS var 0001/01C6/0020 Writing GDFS var 0001/01C7/0020 Writing GDFS var 0001/01C8/0020 Writing GDFS var 0001/01C9/0020 Writing GDFS var 0001/01CA/0020 Writing GDFS var 0001/01CB/0020 Writing GDFS var 0001/01CC/0001 Writing GDFS var 0001/01CD/0001 Writing GDFS var 0001/01CE/0001 Writing GDFS var 0001/01CF/0001 Writing GDFS var 0001/01D0/0001 Writing GDFS var 0001/01D1/0001 Writing GDFS var 0001/01D2/0001 Writing GDFS var 0001/01D3/0001 Writing GDFS var 0001/01D4/0003 Writing GDFS var 0001/01D5/0003 Writing GDFS var 0001/01D6/0003 Writing GDFS var 0001/01D7/0003 Writing GDFS var 0001/01D8/0021 Writing GDFS var 0001/01D9/0021 Writing GDFS var 0001/01DA/0021 Writing GDFS var 0001/01DB/0021 Writing GDFS var 0001/01DC/0040 Writing GDFS var 0001/01DD/0040 Writing GDFS var 0001/01DE/0040 Writing GDFS var 0001/01DF/0040 Writing GDFS var 0001/021A/0018 Writing GDFS var 0001/021B/0018 Writing GDFS var 0001/021E/0030 Writing GDFS var 0001/0220/0030 Writing GDFS var 0001/0221/0070 Writing GDFS var 0001/0223/0018 Writing GDFS var 0001/0224/0030 Writing GDFS var 0001/0226/0002 Writing GDFS var 0001/0227/0002 Writing GDFS var 0001/0228/0010 Writing GDFS var 0001/0229/0008 Writing GDFS var 0001/022A/0018 Writing GDFS var 0001/022B/000A Writing GDFS var 0001/022C/000A Writing GDFS var 0001/0240/0001 Writing GDFS var 0001/0241/0001 Writing GDFS var 0001/0242/0001 Writing GDFS var 0001/0243/0001 Writing GDFS var 0001/024C/0001 Writing GDFS var 0001/024D/0008 Writing GDFS var 0001/024E/0008 Writing GDFS var 0001/024F/0008 Writing GDFS var 0001/0250/0008 Writing GDFS var 0001/0251/0001 Writing GDFS var 0001/0252/0001 Writing GDFS var 0001/0253/0001 Writing GDFS var 0001/0254/0001 Writing GDFS var 0001/0255/0001 Writing GDFS var 0001/0256/0001 Writing GDFS var 0001/0257/0001 Writing GDFS var 0001/0258/0001 Writing GDFS var 0001/0259/0001 Writing GDFS var 0001/025A/0001 Writing GDFS var 0001/025B/0001 Writing GDFS var 0001/025C/0001 Writing GDFS var 0001/025D/0001 Writing GDFS var 0001/025E/0001 Writing GDFS var 0001/025F/0008 Writing GDFS var 0001/0260/0008 Writing GDFS var 0001/0261/0001 Writing GDFS var 0001/0262/0001 Writing GDFS var 0001/0263/0001 Writing GDFS var 0001/0264/0001 Writing GDFS var 0001/0265/0001 Writing GDFS var 0001/0266/0001 Writing GDFS var 0001/0267/0001 Writing GDFS var 0001/0268/0001 Writing GDFS var 0001/0269/0001 Writing GDFS var 0001/026A/0001 Writing GDFS var 0001/026B/0001 Writing GDFS var 0001/026C/0001 Writing GDFS var 0001/026D/0001 Writing GDFS var 0001/026E/0001 Writing GDFS var 0001/026F/0001 Writing GDFS var 0001/0270/0001 Writing GDFS var 0001/0271/0001 Writing GDFS var 0001/0272/0001 Writing GDFS var 0001/0273/0001 Writing GDFS var 0001/0274/0001 Writing GDFS var 0001/0279/002C Writing GDFS var 0001/027A/002C Writing GDFS var 0001/027B/002C Writing GDFS var 0001/027C/002C Writing GDFS var 0001/027D/00C0 Writing GDFS var 0001/027E/00C0 Writing GDFS var 0001/027F/00C0 Writing GDFS var 0001/0280/00C0 Writing GDFS var 0001/0285/0001 Writing GDFS var 0001/028A/0010 Writing GDFS var 0001/028B/0001 Writing GDFS var 0001/0298/0008 Writing GDFS var 0001/0299/0008 Writing GDFS var 0001/029A/0008 Writing GDFS var 0001/029B/0008 Writing GDFS var 0001/029C/0008 Writing GDFS var 0001/029D/0008 Writing GDFS var 0001/029E/0008 Writing GDFS var 0001/029F/0008 Writing GDFS var 0001/02A0/0008 Writing GDFS var 0001/02A1/0008 Writing GDFS var 0001/02A2/0008 Writing GDFS var 0001/02A3/0008 Writing GDFS var 0001/02A4/0008 Writing GDFS var 0001/02A5/0008 Writing GDFS var 0001/02A6/0008 Writing GDFS var 0001/02A7/0008 Writing GDFS var 0001/0350/0006 Writing GDFS var 0001/0351/0002 Writing GDFS var 0001/0352/0002 Writing GDFS var 0001/0353/0002 Writing GDFS var 0001/0354/0002 Writing GDFS var 0001/0355/0002 Writing GDFS var 0001/0356/0002 Writing GDFS var 0001/0357/0002 Writing GDFS var 0001/0358/0002 Writing GDFS var 0001/0359/0002 Writing GDFS var 0001/035A/0002 Writing GDFS var 0001/035B/0002 Writing GDFS var 0001/035C/0002 Writing GDFS var 0001/035D/0002 Writing GDFS var 0001/035E/0002 Writing GDFS var 0001/035F/0002 Writing GDFS var 0001/0360/0004 Writing GDFS var 0001/0361/0004 Writing GDFS var 0001/0362/0002 Writing GDFS var 0001/0363/0002 Writing GDFS var 0001/0364/0002 Writing GDFS var 0001/0365/0002 Writing GDFS var 0001/0366/0002 Writing GDFS var 0001/0367/0002 Writing GDFS var 0001/0368/0002 Writing GDFS var 0001/0369/0002 Writing GDFS var 0001/036A/0002 Writing GDFS var 0001/036B/0002 Writing GDFS var 0001/036C/0002 Writing GDFS var 0001/036D/0002 Writing GDFS var 0001/036E/0002 Writing GDFS var 0001/036F/0002 Writing GDFS var 0001/0370/0002 Writing GDFS var 0001/0371/0002 Writing GDFS var 0001/0372/0002 Writing GDFS var 0001/0373/0002 Writing GDFS var 0001/0374/0002 Writing GDFS var 0001/0375/0002 Writing GDFS var 0001/0376/0002 Writing GDFS var 0001/0377/0002 Writing GDFS var 0001/0378/0002 Writing GDFS var 0001/0379/0002 Writing GDFS var 0001/037A/0002 Writing GDFS var 0001/037B/0002 Writing GDFS var 0001/037C/0002 Writing GDFS var 0001/037D/0002 Writing GDFS var 0001/037E/0002 Writing GDFS var 0001/037F/0002 Writing GDFS var 0001/0380/0002 Writing GDFS var 0001/0381/0002 Writing GDFS var 0001/0382/0002 Writing GDFS var 0001/0383/0002 Writing GDFS var 0001/0384/0002 Writing GDFS var 0001/0385/0002 Writing GDFS var 0001/0386/0002 Writing GDFS var 0001/0387/0002 Writing GDFS var 0001/0388/0002 Writing GDFS var 0001/0389/0002 Writing GDFS var 0001/038A/0002 Writing GDFS var 0001/038B/0002 Writing GDFS var 0001/038C/0002 Writing GDFS var 0001/038D/0002 Writing GDFS var 0001/038E/0002 Writing GDFS var 0001/038F/0002 Writing GDFS var 0001/0390/0002 Writing GDFS var 0001/0391/0002 Writing GDFS var 0001/0392/0002 Writing GDFS var 0001/0393/0004 Writing GDFS var 0001/0394/0002 Writing GDFS var 0001/0395/0004 Writing GDFS var 0001/0396/0004 Writing GDFS var 0001/0397/0002 Writing GDFS var 0001/0398/0002 Writing GDFS var 0001/0399/0002 Writing GDFS var 0001/039A/0004 Writing GDFS var 0001/039B/0002 Writing GDFS var 0001/039C/0002 Writing GDFS var 0001/039D/0002 Writing GDFS var 0001/039E/0002 Writing GDFS var 0001/039F/0002 Writing GDFS var 0001/03A0/0002 Writing GDFS var 0001/03A1/0002 Writing GDFS var 0001/03A2/0002 Writing GDFS var 0001/03A3/0002 Writing GDFS var 0001/03A4/0002 Writing GDFS var 0001/03A5/0002 Writing GDFS var 0001/03A6/0002 Writing GDFS var 0001/03A7/0002 Writing GDFS var 0001/03A8/0002 Writing GDFS var 0001/03A9/0002 Writing GDFS var 0001/03AA/0002 Writing GDFS var 0001/03AB/0002 Writing GDFS var 0001/03AC/0002 Writing GDFS var 0001/03AD/0002 Writing GDFS var 0001/03AE/0002 Writing GDFS var 0001/03AF/0002 Writing GDFS var 0001/03B0/0002 Writing GDFS var 0001/03B1/0002 Writing GDFS var 0001/03B2/0002 Writing GDFS var 0001/03B3/0002 Writing GDFS var 0001/03CA/0578 Writing GDFS var 0001/03CB/0020 Writing GDFS var 0001/03CC/0020 Writing GDFS var 0001/03CD/0001 Writing GDFS var 0001/03CE/0001 Writing GDFS var 0001/04C2/0004 Writing GDFS var 0001/051E/0001 Writing GDFS var 0001/051F/0001 Writing GDFS var 0000/0522/0001 Writing GDFS var 0000/0523/0001 Writing GDFS var 0000/0524/0001 Writing GDFS var 0000/0525/0001 Writing GDFS var 0000/0526/0001 Writing GDFS var 0000/0527/0001 Writing GDFS var 0000/056E/0001 Writing GDFS var 0000/056F/0001 Writing GDFS var 0000/0570/0001 Writing GDFS var 0000/0571/0001 Writing GDFS var 0000/0572/0001 Writing GDFS var 0000/0573/0005 Writing GDFS var 0000/0574/0001 Writing GDFS var 0000/0575/0001 Writing GDFS var 0000/0576/0001 Writing GDFS var 0000/0577/0001 Writing GDFS var 0000/0578/0002 Writing GDFS var 0000/057A/0044 Writing GDFS var 0000/057B/0044 Writing GDFS var 0000/057C/0028 Writing GDFS var 0000/057D/0028 Writing GDFS var 0000/057E/0022 Writing GDFS var 0000/057F/0002 Writing GDFS var 0000/0580/000C Writing GDFS var 0000/0581/0001 Writing GDFS var 0000/0582/0001 Writing GDFS var 0000/0586/0008 Writing GDFS var 0000/0587/0002 Writing GDFS var 0000/0588/0002 Writing GDFS var 0000/0589/0002 Writing GDFS var 0000/058A/0002 Writing GDFS var 0000/058B/0002 Writing GDFS var 0000/058C/0002 Writing GDFS var 0000/058D/0002 Writing GDFS var 0000/058E/0002 Writing GDFS var 0000/058F/0002 Writing GDFS var 0000/0590/0002 Writing GDFS var 0000/0591/0002 Writing GDFS var 0000/0592/0002 Writing GDFS var 0000/0593/0002 Writing GDFS var 0000/0594/0002 Writing GDFS var 0000/0595/0002 Writing GDFS var 0000/0596/0002 Writing GDFS var 0000/0597/0002 Writing GDFS var 0000/0598/0002 Writing GDFS var 0000/0599/0002 Writing GDFS var 0000/059A/0002 Writing GDFS var 0000/059B/0002 Writing GDFS var 0000/059C/0002 Writing GDFS var 0000/059D/0002 Writing GDFS var 0000/059E/0002 Writing GDFS var 0000/059F/0002 Writing GDFS var 0000/05A0/0002 Writing GDFS var 0000/05A1/0002 Writing GDFS var 0000/05A2/0002 Writing GDFS var 0000/05A3/0002 Writing GDFS var 0000/05A4/0002 Writing GDFS var 0000/05A5/0002 Writing GDFS var 0000/05A6/0002 Writing GDFS var 0000/05A7/0001 Writing GDFS var 0000/05A8/0001 Writing GDFS var 0000/05A9/0001 Writing GDFS var 0000/05AA/0040 Writing GDFS var 0000/05CA/0001 Writing GDFS var 0000/05CB/0002 Writing GDFS var 0000/05CC/0008 Writing GDFS var 0000/05D0/0001 Writing GDFS var 0000/05DE/00F8 Writing GDFS var 0000/05DF/0001 Writing GDFS var 0000/05E0/0001 Writing GDFS var 0000/05E1/0001 Writing GDFS var 0000/05E2/0001 Writing GDFS var 0000/05E3/0001 Writing GDFS var 0000/05E4/0001 Writing GDFS var 0000/05E5/0001 Writing GDFS var 0000/05E6/0001 Writing GDFS var 0000/05E7/0001 Writing GDFS var 0000/05E8/0001 Writing GDFS var 0000/05E9/0001 Writing GDFS var 0000/05EA/0001 Writing GDFS var 0000/05F5/0001 Writing GDFS var 0000/05F6/0001 Writing GDFS var 0000/05F7/0001 Writing GDFS var 0000/05F8/0001 Writing GDFS var 0000/05F9/0001 Writing GDFS var 0000/05FA/0001 Writing GDFS var 0000/05FB/0002 Writing GDFS var 0000/05FC/0002 Writing GDFS var 0000/05FD/0002 Writing GDFS var 0000/05FE/0002 Writing GDFS var 0002/06D6/0001 Writing GDFS var 0002/06D8/0001 Writing GDFS var 0002/06D9/0001 Writing GDFS var 0002/06DA/0001 Writing GDFS var 0002/06DD/0004 Writing GDFS var 0002/06DE/0004 Writing GDFS var 0002/06DF/0004 Writing GDFS var 0002/06E1/0002 Writing GDFS var 0002/0704/0028 Writing GDFS var 0002/0705/0028 Writing GDFS var 0002/0706/0028 Writing GDFS var 0002/0707/0028 Writing GDFS var 0003/07D0/0009 Writing GDFS var 0003/07D1/000A Writing GDFS var 0003/07E4/0008 Writing GDFS var 0003/07E5/0008 Writing GDFS var 0003/07E6/0001 Writing GDFS var 0003/07E7/0040 Writing GDFS var 0003/0BAD/0001 Writing GDFS var 0003/0BAE/0002 Writing GDFS var 0003/0BB0/0001 Writing GDFS var 0003/0BB1/0001 PROCESSING: R6K842_25G_CAH1621166_GDF_JO_25G_PUQData_PRC.gdfs Writing GDFS var 0002/079E/0053 PROCESSING: R6K842_25G_CAH1621166_GDF_JO_25G_Settings_LockRemo ved.gdfs Writing GDFS var 0000/0094/0001 Writing GDFS var 0002/06D3/000F Writing GDFS var 0002/06D4/0006 Writing GDFS var 0002/06D6/0001 Elapsed: 764 secs. |
plz help 1680 camera standby | med26 | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 04-19-2010 17:30 |
plz help mmmmmmmmmmmmmmmme ?? | vmin81 | UST Pro II | 3 | 03-30-2010 12:59 |
plz help me | lloydgsm | FuriousGold | 3 | 03-29-2010 20:08 |
plz help me its urgent | lloydgsm | SETool2 | 2 | 03-29-2010 17:45 |
plz help me | lloydgsm | SETool2 | 6 | 03-29-2010 13:10 |
