k610 error when empty fill... SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:9900,EMP protocol:0301 Speed:115200 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35463801744208 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID: 897E writing "D:\drive c\setool\SETOOL v1.01\gdfs_in_ssw_format\db2020\K610_GDFS_SSW.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 640 Will flash 32 blocks... Setting up GDFS... WRITING OTP IMEI:35463801744208 write OTP fail,err:05 OTP WRITE FAILURE WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "10020677" SIGNING... Elapsed: 217 secs. |
no error since you haven't change flashchip, and writting only gdfs. Normal behaviour |
Same problem here trying to repair IMEI, what can we do? Code: SIGNED MODE (USING SERVER) |
OTP: LOCKED:1 One time programmable 352208012382654 is a correct imei for k790a to change it 1 check your country laws 2 use the gdfs solution (unlock +imei change) |
* mark only SIGN MODE ( 1.01 version already gdfs repair free) * press RECOVERY * connect phone with usb or com port * you get brown 49 K610 after successful RECOVERY * switch to empty board tab * select K610 * add K610_GDFS_SSW.ssw * add DB2020EROM_CNV_RED52_BROWN_CID49_DB2020.ssw * click flash * now u get red 52 K610 * flash with red 52 firmware check on settings signed mode "customize phone after flash" * DONE.http://forum.gsmhosting.com/ubb/smile.gifhttp://forum.gsmhosting.com/ubb/smile.gif |
did you see the log in the 2nd post above yours |
