08-08-2008, 03:19 | #1 (permalink) |
No Life Poster Join Date: Jun 2006 Location: sn,fdo,lu philippines
Member: 288470 Status: Offline Sonork: 100.1605122 Thanks Meter: 664 | >>> K610i damaged GDFS successfully repaired <<< Just O N E TRY in stage 1 & Just O N E TRY in stage 2 8/8/2008 9:54:21 AM v0.914037/UNI 8/8/2008 9:54:21 AM CARD SERIAL: >>> K E A E L I T E <<< 8/8/2008 9:54:21 AM Loaded 51 flash de******ors 8/8/2008 9:57:49 AM TESTPOINT REPAIR STAGE #1 STARTED 8/8/2008 9:57:49 AM Open COM port OK 8/8/2008 9:58:34 AM ChipID:9900,EMP protocol:0301 8/8/2008 9:58:34 AM Speed:921600 8/8/2008 9:58:35 AM OTP LOCKED:1 CID:51 PAF:1 IMEI:35463801641799 CERT:N/A 8/8/2008 9:58:35 AM FLASH CID:52 COLOR:RED 8/8/2008 9:58:36 AM LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 8/8/2008 9:58:36 AM PREPARING... 8/8/2008 9:58:43 AM ATTACH TP #1 AND PRESS "READY" 8/8/2008 10:05:18 AM RELEASE TP #1 AND PRESS "READY" 8/8/2008 10:05:20 AM TP #1 LOOKS OKAY 8/8/2008 10:05:28 AM DONE 8/8/2008 10:05:29 AM Elapsed: 460 secs. 8/8/2008 10:08:57 AM TESTPOINT REPAIR STAGE #2 STARTED 8/8/2008 10:08:57 AM Open COM port OK 8/8/2008 10:09:02 AM ChipID:9900,EMP protocol:0301 8/8/2008 10:09:02 AM Speed:921600 8/8/2008 10:09:02 AM ATTACH TP #2 AND PRESS "READY" 8/8/2008 10:09:18 AM Trying to launch embedded bootloader... 8/8/2008 10:09:18 AM TP #2 LOOKS OKAY 8/8/2008 10:09:18 AM RELEASE TP #2 AND PRESS "READY" 8/8/2008 10:09:22 AM INT LDRB2020_PRELOADER_FOR_SETOOL2 8/8/2008 10:09:25 AM WRITING EROM... 8/8/2008 10:09:28 AM DONE 8/8/2008 10:09:29 AM Elapsed: 32 secs. 8/8/2008 10:10:22 AM Open COM port OK 8/8/2008 10:10:25 AM ChipID:9900,EMP protocol:0301 8/8/2008 10:10:25 AM Speed:921600 8/8/2008 10:10:26 AM OTP LOCKED:1 CID:51 PAF:1 IMEI:35463801641799 CERT:N/A 8/8/2008 10:10:26 AM FLASH CID:49 COLOR:BROWN 8/8/2008 10:10:28 AM LDR:060721 1021 DB2020_SERVICE_LOADER 8/8/2008 10:10:28 AM Flash ID check:897E 8/8/2008 10:10:28 AM Flash props sent ok 8/8/2008 10:10:28 AM writing F:\SETool\v.0914037\gdfs_in_ssw_format\db2020\K610 _GDFS_SSW.ssw 8/8/2008 10:10:29 AM CURRENT FLASH FILE CID:49 8/8/2008 10:10:29 AM SSW uses complete hash, hash len is:640 8/8/2008 10:10:30 AM Will flash 32 blocks... 8/8/2008 10:11:03 AM SSW loading returns:0 8/8/2008 10:11:04 AM Setting up GDFS... 8/8/2008 10:11:04 AM OTP WRITE NOT EXECUTED. 8/8/2008 10:11:04 AM Writing simlocks... 8/8/2008 10:11:04 AM ALL UNLOCK/LOCK CODES SET TO "42867537" 8/8/2008 10:11:04 AM Signing... 8/8/2008 10:11:05 AM control keys complete. 8/8/2008 10:11:06 AM full sig complete. 8/8/2008 10:11:09 AM Elapsed: 46 secs. 8/8/2008 10:11:35 AM SIGNED MODE (USING SERVER). 8/8/2008 10:11:35 AM ALTERNATIVE SECURITY BYPASS ENABLED. 8/8/2008 10:11:35 AM Open COM port OK 8/8/2008 10:11:39 AM ChipID:9900,EMP protocol:0301 8/8/2008 10:11:39 AM Speed:921600 8/8/2008 10:11:40 AM OTP LOCKED:1 CID:51 PAF:1 IMEI:35463801641799 CERT:N/A 8/8/2008 10:11:40 AM FLASH CID:49 COLOR:BROWN 8/8/2008 10:11:42 AM LDR:060721 1021 DB2020_SERVICE_LOADER 8/8/2008 10:11:42 AM Flash ID check:897E 8/8/2008 10:11:42 AM Flash props sent ok 8/8/2008 10:11:42 AM writing F:\SETool\v.0914037\eroms\DB2020EROM_CNV_RED52_BRO WN_CID49_DB2020.ssw 8/8/2008 10:11:43 AM CURRENT FLASH FILE CID:49 8/8/2008 10:11:43 AM SSW uses complete hash, hash len is:40 8/8/2008 10:11:43 AM Will flash 2 blocks... 8/8/2008 10:11:46 AM SSW loading returns:0 8/8/2008 10:11:48 AM Elapsed: 13 secs. 8/8/2008 10:11:51 AM SIGNED MODE (USING SERVER). 8/8/2008 10:11:51 AM ALTERNATIVE SECURITY BYPASS ENABLED. 8/8/2008 10:11:51 AM Open COM port OK 8/8/2008 10:11:54 AM ChipID:9900,EMP protocol:0301 8/8/2008 10:11:54 AM Speed:921600 8/8/2008 10:11:55 AM Flash ID check:897E 8/8/2008 10:11:55 AM Flash props sent ok 8/8/2008 10:11:55 AM OTP LOCKED:1 CID:51 PAF:1 IMEI:35463801641799 CERT:N/A 8/8/2008 10:11:55 AM FLASH CID:52 COLOR:RED 8/8/2008 10:11:56 AM 8/8/2008 10:11:56 AM Model:V630i 8/8/2008 10:11:56 AM Brand:F SFR 8/8/2008 10:11:56 AM MAPP CXC article: R1JE001 prgCXC1250556_VODAFONE_MW 8/8/2008 10:11:56 AM MAPP CXC version: R1JE001 8/8/2008 10:11:56 AM Language Package:VFE_LIVE_2 8/8/2008 10:11:56 AM CDA article: CDA102514/24 8/8/2008 10:11:56 AM CDA version: R7A 8/8/2008 10:11:56 AM Default article: cxc1250557 8/8/2008 10:11:56 AM Default version: R1JE001 8/8/2008 10:11:56 AM PROVIDER: 000-00 8/8/2008 10:11:56 AM SIMLOCKS NOT DETECTED 8/8/2008 10:11:56 AM 8/8/2008 10:11:56 AM SEARCH:F:\SETool\v.0914037\eroms\DB2020EROM_CNV_RE D52_BROWN_CID49_DB2020.ssw 8/8/2008 10:11:58 AM RESTORATION FILE NOT PRESENT 8/8/2008 10:11:58 AM "R1JE001_CXC1250556_VODAFONE_MW" 8/8/2008 10:11:58 AM YOU MUST PERFORM FULL FLASHING 8/8/2008 10:11:58 AM WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED 8/8/2008 10:11:58 AM 8/8/2008 10:11:58 AM BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE 8/8/2008 10:11:58 AM 8/8/2008 10:11:58 AM Elapsed: 6 secs. br keaelite |
08-08-2008, 05:53 | #6 (permalink) |
No Life Poster Join Date: Dec 2005 Location: NEAR YOU
Member: 205427 Status: Offline Sonork: 100.1580937 Thanks Meter: 1,162 | Great work, keep up. Me too have repaired a W850i yesterday... Akaward job, really needs skill.. |
The Following User Says Thank You to zeel_zeel For This Useful Post: |
08-09-2008, 05:45 | #7 (permalink) |
No Life Poster Join Date: Apr 2007 Location: BIRMINGHAM UNITED KINGDOM Age: 34
Member: 488632 Status: Offline Thanks Meter: 391 | bro i got more than 5 /6 fone lyk k800 w580 k610 red light blinking but i need easy tp for dat i cn clear stage 1 need for stage 2 thnx in ad yasermalik dadyal azad kashmir |
>>> My X6-2 Successfully Repaired By SMTI <<< | zeel_zeel | SMTi | 5 | 04-08-2009 22:35 |
>>> 6500s DAMAGED SP area REPAIRED by JAF BB5+ <<< | keaelite | JAF No Tp Unlocker by Cinek | 5 | 03-22-2009 09:59 |
>>> K550i gdfs damaged successfully repaired <<< | keaelite | SETool2 | 3 | 11-17-2008 23:05 |
Go to first new post >>> K550i gdfs damaged successfully repaired <<< | ayhen42 | SETool2 | 1 | 08-06-2008 10:06 |
>>> another K800i gdfs damaged successfully repaired <<< | keaelite | SETool2 | 2 | 07-18-2008 10:18 |
