07-25-2008, 15:15 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: NC, USA Age: 36
Member: 779665 Status: Offline Sonork: 100.1581784 Thanks Meter: 492 | k610i unlock problem here is ideinty 7/24/2008 4:12:47 AM Model:K610i 7/24/2008 4:12:47 AM MAPP CXC article: R1CD001 prgCXC1250539_HUTCHISON_TH 7/24/2008 4:12:47 AM MAPP CXC version: R1CD001 7/24/2008 4:12:47 AM Language Package:HUTCH_1 7/24/2008 4:12:47 AM CDA article: CDA102497/46 7/24/2008 4:12:47 AM CDA version: R14A 7/24/2008 4:12:47 AM Default article: cxc1250376 7/24/2008 4:12:47 AM Default version: R1CD001 7/24/2008 4:12:47 AM PROVIDER: 000-00 7/24/2008 4:12:47 AM Network LOCKED 7/24/2008 4:12:47 AM 7/24/2008 4:12:47 AM RESTORATION FILE NOT PRESENT 7/24/2008 4:12:47 AM "R1CD001_CXC1250539_HUTCHISON_TH" 7/24/2008 4:12:47 AM YOU MUST PERFORM FULL FLASHING 7/24/2008 4:12:47 AM WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED 7/24/2008 4:12:47 AM 7/24/2008 4:12:47 AM BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE 7/24/2008 4:12:47 AM 7/24/2008 4:12:47 AM SECURITY UNITS BACKUP CREATED. here is unlock process..... 7/24/2008 4:12:53 AM SIGNED MODE (USING SERVER). 7/24/2008 4:12:54 AM ALTERNATIVE SECURITY BYPASS ENABLED. 7/24/2008 4:12:54 AM PRELOADER SECURITY BYPASS ENABLED. 7/24/2008 4:12:59 AM ChipID:9900,EMP protocol:0301 7/24/2008 4:12:59 AM 7/24/2008 4:13:00 AM PHONE IS RED RETAIL PRODUCT 7/24/2008 4:13:00 AM FLASH CID detected:49 7/24/2008 4:13:00 AM Speed:921600 7/24/2008 4:13:00 AM OTP LOCKED:1 CID:49 PAF:1 IMEI:35170901246017 CERT:RED 7/24/2008 4:13:00 AM FLASH CID:49 COLOR:RED 7/24/2008 4:13:01 AM PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 7/24/2008 4:13:01 AM LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 7/24/2008 4:13:01 AM Flash ID check:2019 7/24/2008 4:13:01 AM Flash props sent ok 7/24/2008 4:13:04 AM LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 7/24/2008 4:13:04 AM loader startup: executed 7/24/2008 4:13:19 AM loader GDFS startup: executed 7/24/2008 4:13:25 AM loader filesystem startup: executed 7/24/2008 4:13:25 AM loader unlock: executed 7/24/2008 4:13:31 AM 7/24/2008 4:13:31 AM DISCONNECT PHONE NOW 7/24/2008 4:13:31 AM INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN 7/24/2008 4:13:31 AM BE SURE THAT YOU SET PHONE IN "PHONE MODE" 7/24/2008 4:13:31 AM IF ASKED, INSTALL PHONE DRIVERS 7/24/2008 4:13:31 AM 7/24/2008 4:13:31 AM SEARCHING FOR PHONE, "STOP" TO ABORT 7/24/2008 4:52:58 AM PHONE FOUND AT COM10 7/24/2008 4:53:04 AM PHONE READY TO PROCEED 7/24/2008 4:53:11 AM EXECUTOR STARTED 7/24/2008 4:53:11 AM 7/24/2008 4:53:11 AM REMOVE CABLE FROM PHONE 7/24/2008 4:53:11 AM REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK 7/24/2008 4:53:11 AM THEN PRESS "READY" 7/24/2008 4:53:31 AM 7/24/2008 4:53:35 AM ChipID:9900,EMP protocol:0301 7/24/2008 4:53:35 AM 7/24/2008 4:53:35 AM PHONE IS RED RETAIL PRODUCT 7/24/2008 4:53:35 AM FLASH CID detected:49 7/24/2008 4:53:35 AM Speed:921600 7/24/2008 4:53:35 AM Trying to launch embedded bootloader... 7/24/2008 4:53:36 AM INT LDRB2020_PRELOADER_FOR_SETOOL2 7/24/2008 4:53:37 AM Flash ID check:2019 7/24/2008 4:53:37 AM Flash props sent ok 7/24/2008 4:53:46 AM FOUND: R1CD001_CXC1250539_HUTCHISON_TH 7/24/2008 4:53:46 AM Restore from:R1CD001_CXC1250539_HUTCHISON_TH 7/24/2008 4:53:46 AM can't open file "C:\Documents and Settings\nadir\Desktop\setool\rest\R1CD001_CXC1250 539_HUTCHISON_TH" 7/24/2008 4:53:49 AM full sig complete. 7/24/2008 4:53:49 AM USERCODE RESET TO "0000" 7/24/2008 4:53:49 AM Searching... 7/24/2008 4:54:00 AM Can't find SIMLOCK check 7/24/2008 4:54:00 AM Unlock FAILED 7/24/2008 4:54:00 AM Elapsed: 2466 secs plzzzz help why this happend..... |
07-25-2008, 16:06 | #2 (permalink) |
Junior Member Join Date: Aug 2007 Location: philipines
Member: 569928 Status: Offline Thanks Meter: 1 | cid 49 to cid 52 free unlock using executor tested by me..... tick. misc files>find>\script\DB2020_CID49_51_to_CID52_OLD.tx t tick>write scrift identify phone is cid 49 to 52 go to settings setool tick> sign mode>enable artirnative>enable freloader then tick flash {note} no files only here sample... DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN BE SURE THAT YOU SET PHONE IN "PHONE MODE" IF ASKED, INSTALL PHONE DRIVERS SEARCHING FOR PHONE, "STOP" TO ABORT Can't find attached phone with IMEI *********x PROCEDURE WAS STOPPED BY USER Elapsed: 94 secs. PRELOADER SECURITY BYPASS ENABLED. ChipID:9900,EMP protocol:0301 remove cable > insert battery go to menu file manager games run executor > phone is off go to setool settings >untick >sign mode>enable artirnative tick > enable freloader security bypass tick > unlock >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> > here logs bro....... PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:921600 Flash ID check:897E Flash props sent ok OTP LOCKED:1 CID:49 PAF:1 IMEI:35171001734433 CERT:RED FLASH CID:49 COLOR:RED Model:K610i MAPP CXC article: R1EJ001 prgCXC1250540_CHINA_TH MAPP CXC version: R1EJ001 Language Package:APAC CDA article: CDA102568/101 CDA version: R5A Default article: cxc1250376 Default version: R1EJ001 PROVIDER: 515-03 Network LOCKED RESTORATION FILE PRESENT FOR DETECTED FIRMWARE SECURITY UNITS BACKUP CREATED. Elapsed: 7 secs. SIGNED MODE (USING SERVER). Processing ****** "C:\Program Files\Setool\******\DB2020_CID49_51_to_CID52_OLD.t xt"... ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35171001734433 CERT:RED FLASH CID:49 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed Writing GDFS var 0001:084E len:010B Success Phone detached Elapsed: 22 secs. SIGNED MODE (USING SERVER). ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:921600 Flash ID check:897E Flash props sent ok OTP LOCKED:1 CID:49 PAF:1 IMEI:35171001734433 CERT:RED FLASH CID:52 COLOR:RED Model:K610i MAPP CXC article: R1EJ001 prgCXC1250540_CHINA_TH MAPP CXC version: R1EJ001 Language Package:APAC CDA article: CDA102568/101 CDA version: R5A Default article: cxc1250376 Default version: R1EJ001 PROVIDER: 515-03 Network LOCKED RESTORATION FILE PRESENT FOR DETECTED FIRMWARE BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE SECURITY UNITS BACKUP CREATED. Elapsed: 5 secs. SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. PRELOADER SECURITY BYPASS ENABLED. phone pre-boot failed,possible RECOVERY needed. PROCEDURE WAS STOPPED BY USER Elapsed: 3 secs. SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. PRELOADER SECURITY BYPASS ENABLED. ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:921600 Flash ID check:897E Flash props sent ok OTP LOCKED:1 CID:49 PAF:1 IMEI:35171001734433 CERT:RED FLASH CID:52 COLOR:RED Model:K610i MAPP CXC article: R1EJ001 prgCXC1250540_CHINA_TH MAPP CXC version: R1EJ001 Language Package:APAC CDA article: CDA102568/101 CDA version: R5A Default article: cxc1250376 Default version: R1EJ001 PROVIDER: 515-03 Network LOCKED RESTORATION FILE PRESENT FOR DETECTED FIRMWARE BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE SECURITY UNITS BACKUP CREATED. Elapsed: 5 secs. SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. PRELOADER SECURITY BYPASS ENABLED. ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35171001734433 CERT:RED FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN BE SURE THAT YOU SET PHONE IN "PHONE MODE" IF ASKED, INSTALL PHONE DRIVERS SEARCHING FOR PHONE, "STOP" TO ABORT Can't find attached phone with IMEI 35171001734433 PROCEDURE WAS STOPPED BY USER Elapsed: 94 secs. PRELOADER SECURITY BYPASS ENABLED. ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:921600 Trying to launch embedded bootloader... INT LDRB2020_PRELOADER_FOR_SETOOL2 OTP LOCKED:1 CID:49 PAF:1 IMEI:35171001734433 CERT:RED FOUND: R1EJ001_CXC1250540_CHINA_TH Restore from:R1EJ001_CXC1250540_CHINA_TH full sig complete. USERCODE RESET TO "0000" Searching... Firmware SIMLOCK check determined. Unlock DONE Elapsed: 31 secs. |
03-03-2009, 17:15 | #3 (permalink) | |
No Life Poster Join Date: Nov 2008 Location: Faisalabad pakistan
Member: 900083 Status: Offline Thanks Meter: 601 | Quote:
brother here is my logs all is ok but i on set show insert correct sim card so how i enter menu and file manager and games option please tell me hurry SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED. PRELOADER SECURITY BYPASS ENABLED. ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35171001592458 CERT:RED FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PROCEDURE WAS STOPPED BY USER Can't find attached phone with IMEI 35171001592458 Elapsed: 77 secs. | |
03-04-2009, 10:16 | #6 (permalink) |
Registered User Join Date: Apr 2007 Location: ==**Syria**== Age: 44
Member: 493205 Status: Offline Sonork: 100.1581647 Thanks Meter: 526 | to make resteration file just do : 1- add flash (main+fs) 2- press identify and in the end will make rest file or....... go to supprort and download it Good Luck |
sony k610i unlock problem | ptholt | Sony Ericsson | 2 | 05-01-2008 08:29 |
K610i unlock problem! now 5 locks | Lpapp | Seking Server | 3 | 04-16-2008 00:54 |
K610i unlocking problem | kungpaoski | FuriousGold | 2 | 11-15-2007 06:14 |
K610i unlocking problem | kungpaoski | FuriousGold | 3 | 11-07-2007 09:09 |
K610i unlocking problem with FG.. | enrikez | FuriousGold | 4 | 10-18-2007 17:58 |
