Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (Non-Official Support) > SETool2
Old 01-11-2012, 14:18   #1 (permalink)
Registered User
Member: 1359163
Thanks Meter: 37
K700i DEAD WHEN FLASH IT
Hi brothers
I try to flash k700i via rj45 setool cable and program 1.1203
an now when flash i have
RUNNING v 1.1203/01.11/UNI
CARD SERIAL 00013383
USBFLASH DRIVER VERSION 02.02.00.05
CFG:000000000000
ChipID:8000,EMP protocol:0301
PHONE STATE: "RETAIL"
FLASH CID: 0029
Speed:230400
LDR:061113 1250 ALUCXC125872_COMPACTPRODUCTION_ID_LOADER P3L
FLASH ID: 890D
OTP LOCKED:1 CID:29 PAF:1 IMEI:354__________ CERT:RED
ACTIVE CID:29 COLOR:RED
Model (from GDFS):K700i
Language Package: ORANGE_GEN
CDA article: CDA102298/22
CDA version: R26A
Default article: cxc125822
Default version: 3E1W
PROVIDER: 000-00
SIMLOCKS NOT DETECTED
USERCODE:0000
Elapsed: 14 secs.
CFG:000000000000
Will backup GDFS now.
FLASH CID: 0029
Speed:230400
LDR:040319 0923 LLECXC1326739_COMPACTCERTLOADER R2E
LDR:041214 0816 LLECXC1326743_COMPACTPRODUCTION R2AB
FLASH ID: 890D
LDR:060119 0203 EMPCXC1327364_COMPACT_SEMC_CS_LOADER
loader GDFS startup executed
stated number of vars:1274
Found:756 units
Found:518 units
gdfs read done,gdfs_3IMEI:354__________.bin written
Phone detached
Elapsed: 85 secs.
CFG:001000000000
FLASH CID: 0029
Speed:230400
FLASH ID: 890D
writing "C:\setool2g\flash\K700\k700r2ca_main_euro.cry "
CURRENT FLASH FILE CID: UNIVERSAL
SSW uses dynamic hash, dynamic hash len is: 217
Will flash 217 blocks ...
subblock 001 NAK, [44040000/00010000]
Elapsed: 72 secs.
SIGNED MODE (USING SERVER)
CFG:101000000000
FLASH CID: 0036
Speed:230400
OTP LOCKED:1 CID:29 PAF:1 IMEI:354__________9 CERT:RED
PHONE NOT SUPPORTED IN THAT MODE
Elapsed: 53 secs.
CFG:001000000000
FLASH CID: 0036
Speed:230400
LDR:050404 1011 LLECXC125872_COMPACTPRODUCTION_ID_LOADER R2F
can't get packet start.
no ack during certificate replace.
can't change certificate.
Elapsed: 50 secs.
CFG:001000000000
PHONE STATE: "UNKNOWN" [00000000]
SUPPORTED FLASH CID IS NOT DETECTED [0000]
skipping empty loader ...
FAILED TO SETUP PHONE
Elapsed: 18 secs.
CFG:001000000000
Elapsed: 5 secs.
CFG:001000000000
Elapsed: 201 secs.
and now I hve death phone, any solution to repair ?
Old 01-12-2012, 08:47   #2 (permalink)
Crazy Poster
Member: 770368
Thanks Meter: 15
repair gdfs first and full flash again use you back up from your box programme... dont forget to use fully chareged battery...
Old 01-25-2012, 10:02   #3 (permalink)
Registered User
Member: 1359163
Thanks Meter: 37
I do Recovery procedure
then reflash with Customize phone after flash:
RECOVERY MODE STARTED
Speed:460800
REC:041213 1452 MATCXC1326739_COMPACTCERTLOADER R2L
CHECKING OTP ...
OTP LOCKED:1 CID:29 PAF:1 IMEI:35(o__o)
CERTIFICATE RESTORED. PLEASE REFLASH PHONE NOW.
Elapsed: 16 secs.
CFG:001000000000
FLASH CID: 0029
Speed:460800
OTP LOCKED:1 CID:29 PAF:1 IMEI:35(o__o) CERT:RED
FLASH ID: 890D
writing "C:\setool2g\flash\K700\k700r2aa_main.cry"
CURRENT FLASH FILE CID: 29
SSW uses dynamic hash, dynamic hash len is: 214
Will flash 214 blocks ...
writing "C:\setool2g\flash\K700\k700r2aa_fs.emea1.cry"
SSW uses dynamic hash, dynamic hash len is: 101
Will flash 101 blocks ...
loader FILESYSTEM startup executed
using GENERIC phone customization
tpa/preset/custom/C3_PCA_G3v2.cer
tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm
tpa/preset/custom/customize.xml
tpa/preset/custom/DESKTOP_HOOK_2.itm
tpa/preset/custom/Entrust.net Root Certificate.cer
tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt
tpa/preset/custom/FM_PICTURES_HOOK_3.itm
tpa/preset/custom/FM_SOUNDS_HOOK_3.itm
tpa/preset/custom/FM_THEMES_HOOK_3.itm
tpa/preset/custom/FM_VIDEOS_HOOK_3.itm
tpa/preset/custom/GAMES_HOOK_3.itm
tpa/preset/custom/GTE_CyberTrust_Root.cer
tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt
tpa/preset/custom/Root.cer
tpa/preset/custom/SEMC_E2E_Root_CA.crt
tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm
tpa/preset/custom/ThawtePremium.der
tpa/preset/custom/ThawteServerCA.cer
tpa/preset/custom/Utiroot.cer
tpa/preset/custom/VeriSignClass3Root.cer
tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt
Phone detached
Elapsed: 572 secs.
and now phone works fine !
Old 05-06-2013, 06:04   #4 (permalink)
rakib_sheak's Avatar
Member: 1201843
Thanks Meter: 487
Model (from GDFS): K700i
Brand: Generic Trade
Language Package: EMEA_6
CDA article: CDA102298/85
CDA version: R11A
Default version: R2AE033
PROVIDER: 000-00
USERCODE: 7903
Old 09-10-2020, 10:05   #5 (permalink)
Member: 1562854
Sonork: 1245
Thanks Meter: 147
Helpe me k700dead
CFG:110000000000
ChipID: 8000, EMP protocol: 0301
PHONE DOMAIN: "DEVELOPER"
PHONE CID: 0051
Elapsed: 5 seconds
CFG:000000000000
PROCEDURE WAS STOPPED BY USER
Elapsed: 25 seconds
CFG:000000000000
PHONE CID: 0051
SPEED: 921600
LDR: DB2010_RESPIN_PRODLOADER_SETOOL2
OTP: LOCKED:1 CID:29 PAF:1 IMEI:35401000750097 CERT:BROWN
FLASH ID: 890D
writing "C:\Documents and Settings\Administrateur\Bureau\k700custpack.rar"
UNSUPPORTED FILE
Elapsed: 11 seconds
Old 09-10-2020, 11:03   #6 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: OEM Lock : ON
Thanks Meter: 3,979
read the FAQ from start
The Following User Says Thank You to Mr.3. For This Useful Post:
Old 09-10-2020, 11:08   #7 (permalink)
Member: 1562854
Sonork: 1245
Thanks Meter: 147
Solved problem
SPEED: 921600
skipped: 0001 bytes
LDR: 040319 0923 LLECXC1326739_COMPACTCERTLOADER R2E
OTP: LOCKED:1 CID:29 PAF:1 IMEI:35401000750097 CERT:RED
LDR: 041214 0816 LLECXC1326743_COMPACTPRODUCTION R2ABPڈâ
FLASH ID: 890D
writing "C:\Documents and Settings\Administrateur\Bureau\k700r2ae_fs.emea1.c ry"
Elapsed: 135 seconds
CFG:000000000000
PHONE DOMAIN: "RETAIL"
PHONE CID: 0029
SPEED: 921600
skipped: 0001 bytes
FLASH ID: 890D
writing "C:\Documents and Settings\Administrateur\Bureau\MRT_V3.57\k700_red_ cid16_main.cry"
CURRENT FLASH FILE CID: 16
Converting firmware ...
SSW uses static hash,and number of used blocks is:209
Will flash 209 blocks ...
writing "C:\Documents and Settings\Administrateur\Bureau\MRT_V3.57\k700_red_ cid16_fs.emea1.cry"
SSW uses static hash,and number of used blocks is:97
Will flash 97 blocks ...
Elapsed: 384 seconds
need to flash 6110 paulomt1 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 08-16-2019 19:37
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-03-2015 04:41
what prog changes imei on 6110 and how do i do it? Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 07-31-2012 20:09
SIM restriction pending -- what does it mean? Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 07-17-2011 10:05
Page generated in 0.35074 seconds with 8 queries
