01-04-2010, 17:21 | #1 (permalink) |
No Life Poster Join Date: Feb 2004 Age: 49
Member: 52828 Status: Offline Sonork: KHADIM100 Thanks Meter: 1,212 | <<< K770i Phone Lock - can i remove without full flashing? >>> here is log. 1/4/2010 8:12:09 PM v0.914037/UNI 1/4/2010 8:12:09 PM CARD SERIAL: 00092xxx 1/4/2010 8:12:09 PM Loaded 51 flash descriptors 1/4/2010 8:12:23 PM ChipID:9900,EMP protocol:0301 1/4/2010 8:12:24 PM 1/4/2010 8:12:24 PM PHONE IS RED RETAIL PRODUCT 1/4/2010 8:12:24 PM FLASH CID detected:52 1/4/2010 8:12:24 PM Speed:921600 1/4/2010 8:12:24 PM Flash ID check:897E 1/4/2010 8:12:24 PM Flash props sent ok 1/4/2010 8:12:24 PM OTP LOCKED:1 CID:51 PAF:1 IMEI:351600034xxxxx CERT:RED 1/4/2010 8:12:24 PM FLASH CID:52 COLOR:RED 1/4/2010 8:12:25 PM 1/4/2010 8:12:25 PM Model:K770i 1/4/2010 8:12:25 PM MAPP CXC article: R8BC004 prg1201-7602_TMOBILE_VI 1/4/2010 8:12:25 PM MAPP CXC version: R8BC004 1/4/2010 8:12:25 PM Language Package:T_MOB_INT_A 1/4/2010 8:12:25 PM CDA article: 1203-0002 1/4/2010 8:12:25 PM CDA version: R3A 1/4/2010 8:12:25 PM Default article: 1201-7603 1/4/2010 8:12:25 PM Default version: R8BC004 1/4/2010 8:12:25 PM PROVIDER: 000-00 1/4/2010 8:12:25 PM SIMLOCKS NOT DETECTED 1/4/2010 8:12:26 PM 1/4/2010 8:12:26 PM RESTORATION FILE NOT PRESENT 1/4/2010 8:12:26 PM "R8BC004_1201-7602_TMOBILE_VI" 1/4/2010 8:12:26 PM YOU MUST PERFORM FULL FLASHING 1/4/2010 8:12:26 PM WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED 1/4/2010 8:12:26 PM 1/4/2010 8:12:26 PM BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE 1/4/2010 8:12:26 PM 1/4/2010 8:12:26 PM SECURITY UNITS BACKUP CREATED. 1/4/2010 8:12:26 PM Elapsed: 8 secs. 1/4/2010 8:12:44 PM ChipID:9900,EMP protocol:0301 1/4/2010 8:12:45 PM 1/4/2010 8:12:45 PM PHONE IS RED RETAIL PRODUCT 1/4/2010 8:12:45 PM FLASH CID detected:52 1/4/2010 8:12:45 PM Speed:921600 1/4/2010 8:12:45 PM OTP LOCKED:1 CID:51 PAF:1 IMEI:351600034xxxxxxx CERT:RED 1/4/2010 8:12:45 PM FLASH CID:52 COLOR:RED 1/4/2010 8:12:46 PM PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 1/4/2010 8:12:46 PM LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 1/4/2010 8:12:46 PM Flash ID check:897E 1/4/2010 8:12:46 PM Flash props sent ok 1/4/2010 8:12:46 PM phone CID not supported in that mode 1/4/2010 8:12:46 PM Elapsed: 7 secs. |
01-04-2010, 17:53 | #4 (permalink) |
No Life Poster Join Date: Sep 2002 Location: ALGERIA
Member: 15439 Status: Offline Sonork: 100.43816 Thanks Meter: 52 | just tick USE SERVER and clic unlock it will reset code to 0000 and disable it from phone menu later . |
The Following User Says Thank You to BLIDA For This Useful Post: |
01-04-2010, 20:58 | #5 (permalink) |
Freak Poster Join Date: Aug 2006
Member: 339455 Status: Offline Sonork: 100.1589401 Thanks Meter: 86 | Hello just check signed mode box in settings tab and use usb as interface and press unlock/repair key security code will change to 0000 |
The Following User Says Thank You to mazmaz1 For This Useful Post: |
Get your phone lock code/security code without reset or format(nokia BB5 phones teste | ashraf_bcs | Nokia Base Band 5 ( BB-5 ) | 21 | 11-01-2015 15:47 |
sagem my401x phone lock will be removed | Satyam321 | KULANKENDI Server | 4 | 06-10-2008 12:12 |
6300 can not unlock, downgraded, full flashed, not helped! It's Lock!! | Wais777 | BB5BOX | 3 | 04-25-2008 21:15 |
x700 user lock can be removed? | Raklm | Infinity-Box | 3 | 03-14-2007 14:11 |
How to clear timer on 3315 without full flash | fancyvpp | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 10-01-2004 17:37 |
