Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SETool2
Old 10-16-2017, 15:21   #1 (permalink)
Member: 601566
Sonork: 100.1637134
Thanks Meter: 551
k800 after flash configuration error
configuration error pleas contact your network operator or service centre
otb locked cid"51 paf :1 imei 35570401680279 cert :red
activ cid :51 color red
model from gdfs k800i
brand o2
mapp cxc article R1CB001
DEFAULT VERSION R1CB001
PRIVIDER 272-02F
I WANT TO FLASH ARABI FIRMWARW THIS ERROR AFTER FLASH
Old 10-16-2017, 15:51   #2 (permalink)
Member: 601566
Sonork: 100.1637134
Thanks Meter: 551
SIGNED MODE (USING SERVER)
ALTERNATIVE SECURITY BYPASS ENABLED
CFG:111110001000
ChipID: 9900, EMP protocol: 0301
PHONE DOMAIN: "RETAIL"
PHONE CID: 0053
SPEED: 115200
LDR: 071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M
OTP: LOCKED:1 CID:51 PAF:1 IMEI:35570401680279 CERT:RED
CURRENT CID: 53 COLOR: RED
FLASH ID: 897E
Downgrading security ...
DETACH CABLE FROM PHONE, THEN
CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5")
BOOTROM MODE DETECTED
SPEED: 115200
RESET: 070703 1106 NPACXC1250329_DB2020_CERTRESETLOADER_P3AA
GOT SEED: 603E1CFB2380786D157015A6
P96 AUTH PASSED
Restarting ...
SPEED: 115200
LDR: DB2020 LOADER FOR SETOOL2
CURRENT CID: 49 COLOR: BROWN
writing "L:\SONY K800I\R8BF003_1250210_GENERIC_WI.ssw"
CURRENT FLASH FILE CID: 53
SSW uses full hash, hash len is: 9200
Will flash 460 blocks ...
writing "L:\SONY K800I\R8BF003_FS_C_ASIA_WI_RED_CID53.SOFTWARE"
SSW uses full hash, hash len is: 4660
Will flash 233 blocks ...
Setting up GDFS ...
WRITING CLEAR SIMLOCK UNITS ...
SIMLOCK CODES SET TO "48487813"
SIGNING ...
CHANGE CID NOT ALLOWED FOR THIS PHONE
CERTIFICATE CHANGE FAILED
Elapsed: 401 seconds
Old 10-16-2017, 16:12   #3 (permalink)
Member: 601566
Sonork: 100.1637134
Thanks Meter: 551
SPEED: 115200
LDR: 071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0
LDR: 080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015012 0
FLASH ID: 897E
SPEED: 115200
GOT SEED: A6EF999D2380786D157015A6
P96 AUTH PASSED
Restarting ...
SPEED: 115200
writing "L:\SONY K800I\New folder\R1KG001_1250211_VODAFONE_WI.ssw"
writing "L:\SONY K800I\New folder\R1KG001_FS_M_EAST_N_AFR_WI_RED_CID53.SOFTWA RE"
SSW uses full hash, hash len is: 4420
Will flash 221 blocks ...
Elapsed: 416 seconds
Old 10-16-2017, 16:33   #4 (permalink)
GSM.WIZARD's Avatar
Member: 2751525
Thanks Meter: 28
k800i
complete after flash,that normally does the job
Old 10-16-2017, 17:13   #5 (permalink)
Member: 601566
Sonork: 100.1637134
Thanks Meter: 551
i tray this but not solve
Old 10-16-2017, 17:24   #6 (permalink)
Super Moderator
THE CLASH's Avatar
Member: 173077
Sonork: 100.1594293
Thanks Meter: 2,784
Why did you downgrade the cid to brown 49...?
In what state is the phone at the moment..
__________________
Wbr
THE CLASH
The Following User Says Thank You to THE CLASH For This Useful Post:
Old 10-16-2017, 18:07   #7 (permalink)
Member: 601566
Sonork: 100.1637134
Thanks Meter: 551
phone working wiyhout sim when i insert sim show this
Old 10-16-2017, 18:18   #8 (permalink)
Super Moderator
THE CLASH's Avatar
Member: 173077
Sonork: 100.1594293
Thanks Meter: 2,784
Your log does not show that you have customised the phone after flashing..
__________________
Wbr
THE CLASH
Old 10-16-2017, 21:05   #9 (permalink)
Member: 601566
Sonork: 100.1637134
Thanks Meter: 551
i customised after flash but not solve problem
Old 10-16-2017, 23:25   #10 (permalink)
Super Moderator
THE CLASH's Avatar
Member: 173077
Sonork: 100.1594293
Thanks Meter: 2,784
Please show the Log..
__________________
Wbr
THE CLASH
Old 10-31-2017, 18:04   #11 (permalink)
Member: 601566
Sonork: 100.1637134
Thanks Meter: 551
CFG:110000110000
PHONE CID: 0053
SPEED: 115200
FLASH ID: 897E
ACTIVE CID: 53 COLOR: RED
Model (from GDFS): K800i
MAPP CXC article: R1KG001 prgCXC1250211_VODAFONE_WI
MAPP CXC version: R1KG001
Language Package: EUROPE_2
CDA article: CDA102511/40
CDA version: R7A
Default article: cxc1250490
Default version: R1CB001
SIMLOCKS NOT DETECTED
PROVIDER: 000-000
SECURITY UNITS BACKUP CREATED
Elapsed: 21 seconds
Old 10-31-2017, 18:10   #12 (permalink)
Member: 601566
Sonork: 100.1637134
Thanks Meter: 551
SPEED: 115200
FLASH ID: 897E
SPEED: 115200
GOT SEED: 7BC9D77B2380786D157015A6
P96 AUTH PASSED
Restarting ...
SPEED: 115200
Elapsed: 55 seconds
Old 11-01-2017, 12:47   #13 (permalink)
Member: 9519
Thanks Meter: 2,150
select USB as interface
select K800 as model
press "clear" button in firmware selection area
on options tab, check ONLY "signed mode", "customize phone during flash"
back to Sony Ericsson tab, press flash
Old 11-01-2017, 15:47   #14 (permalink)
Member: 601566
Sonork: 100.1637134
Thanks Meter: 551
same problem ...
when insert sim
Old 11-01-2017, 19:29   #15 (permalink)
Super Moderator
THE CLASH's Avatar
Member: 173077
Sonork: 100.1594293
Thanks Meter: 2,784
Look..... Untill now you have not shown prof of customised in any logs...
Do as you have been advised by the Laser and me..
__________________
Wbr
THE CLASH
Page generated in 0.31013 seconds with 9 queries
