10-16-2017, 15:21 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: EGYPT
Member: 601566 Status: Offline Sonork: 100.1637134 Thanks Meter: 551 | k800 after flash configuration error otb locked cid"51 paf :1 imei 35570401680279 cert :red activ cid :51 color red model from gdfs k800i brand o2 mapp cxc article R1CB001 DEFAULT VERSION R1CB001 PRIVIDER 272-02F I WANT TO FLASH ARABI FIRMWARW THIS ERROR AFTER FLASH |
10-16-2017, 15:51 | #2 (permalink) |
Member: 601566 Status: Offline Sonork: 100.1637134 Thanks Meter: 551 | SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:111110001000 ChipID: 9900, EMP protocol: 0301 PHONE DOMAIN: "RETAIL" PHONE CID: 0053 SPEED: 115200 LDR: 071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M OTP: LOCKED:1 CID:51 PAF:1 IMEI:35570401680279 CERT:RED CURRENT CID: 53 COLOR: RED FLASH ID: 897E Downgrading security ... DETACH CABLE FROM PHONE, THEN CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") ChipID: 9900, EMP protocol: 0301 BOOTROM MODE DETECTED SPEED: 115200 RESET: 070703 1106 NPACXC1250329_DB2020_CERTRESETLOADER_P3AA GOT SEED: 603E1CFB2380786D157015A6 P96 AUTH PASSED Restarting ... DETACH CABLE FROM PHONE, THEN CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") ChipID: 9900, EMP protocol: 0301 BOOTROM MODE DETECTED SPEED: 115200 LDR: DB2020 LOADER FOR SETOOL2 CURRENT CID: 49 COLOR: BROWN writing "L:\SONY K800I\R8BF003_1250210_GENERIC_WI.ssw" CURRENT FLASH FILE CID: 53 SSW uses full hash, hash len is: 9200 Will flash 460 blocks ... writing "L:\SONY K800I\R8BF003_FS_C_ASIA_WI_RED_CID53.SOFTWARE" CURRENT FLASH FILE CID: 53 SSW uses full hash, hash len is: 4660 Will flash 233 blocks ... Setting up GDFS ... WRITING CLEAR SIMLOCK UNITS ... SIMLOCK CODES SET TO "48487813" SIGNING ... CHANGE CID NOT ALLOWED FOR THIS PHONE CERTIFICATE CHANGE FAILED Elapsed: 401 seconds |
10-16-2017, 16:12 | #3 (permalink) |
Member: 601566 Status: Offline Sonork: 100.1637134 Thanks Meter: 551 | SPEED: 115200 LDR: 071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M OTP: LOCKED:1 CID:51 PAF:1 IMEI:35570401680279 CERT:RED CURRENT CID: 53 COLOR: RED LDR: 071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0 LDR: 080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015012 0 FLASH ID: 897E Downgrading security ... DETACH CABLE FROM PHONE, THEN CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") ChipID: 9900, EMP protocol: 0301 BOOTROM MODE DETECTED SPEED: 115200 RESET: 070703 1106 NPACXC1250329_DB2020_CERTRESETLOADER_P3AA GOT SEED: A6EF999D2380786D157015A6 P96 AUTH PASSED Restarting ... DETACH CABLE FROM PHONE, THEN CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") ChipID: 9900, EMP protocol: 0301 BOOTROM MODE DETECTED SPEED: 115200 LDR: DB2020 LOADER FOR SETOOL2 CURRENT CID: 49 COLOR: BROWN writing "L:\SONY K800I\New folder\R1KG001_1250211_VODAFONE_WI.ssw" CURRENT FLASH FILE CID: 53 SSW uses full hash, hash len is: 9200 Will flash 460 blocks ... writing "L:\SONY K800I\New folder\R1KG001_FS_M_EAST_N_AFR_WI_RED_CID53.SOFTWA RE" CURRENT FLASH FILE CID: 53 SSW uses full hash, hash len is: 4420 Will flash 221 blocks ... Elapsed: 416 seconds |
10-16-2017, 17:24 | #6 (permalink) |
Super Moderator Join Date: Aug 2005 Location: UK.... Age: 57
Member: 173077 Status: Offline Sonork: 100.1594293 Thanks Meter: 2,784 | Why did you downgrade the cid to brown 49...? In what state is the phone at the moment..
__________________ Wbr THE CLASH |
The Following User Says Thank You to THE CLASH For This Useful Post: |
10-31-2017, 18:04 | #11 (permalink) |
Member: 601566 Status: Offline Sonork: 100.1637134 Thanks Meter: 551 | SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110000110000 ChipID: 9900, EMP protocol: 0301 PHONE DOMAIN: "RETAIL" PHONE CID: 0053 SPEED: 115200 LDR: 071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M FLASH ID: 897E OTP: LOCKED:1 CID:51 PAF:1 IMEI:35570401680279 CERT:RED ACTIVE CID: 53 COLOR: RED Model (from GDFS): K800i MAPP CXC article: R1KG001 prgCXC1250211_VODAFONE_WI MAPP CXC version: R1KG001 Language Package: EUROPE_2 CDA article: CDA102511/40 CDA version: R7A Default article: cxc1250490 Default version: R1CB001 SIMLOCKS NOT DETECTED PROVIDER: 000-000 SECURITY UNITS BACKUP CREATED Elapsed: 21 seconds |
10-31-2017, 18:10 | #12 (permalink) |
Member: 601566 Status: Offline Sonork: 100.1637134 Thanks Meter: 551 | SPEED: 115200 LDR: 071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M OTP: LOCKED:1 CID:51 PAF:1 IMEI:35570401680279 CERT:RED CURRENT CID: 53 COLOR: RED LDR: 071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0 LDR: 080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015012 0 FLASH ID: 897E Downgrading security ... DETACH CABLE FROM PHONE, THEN CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") ChipID: 9900, EMP protocol: 0301 BOOTROM MODE DETECTED SPEED: 115200 RESET: 070703 1106 NPACXC1250329_DB2020_CERTRESETLOADER_P3AA GOT SEED: 7BC9D77B2380786D157015A6 P96 AUTH PASSED Restarting ... DETACH CABLE FROM PHONE, THEN CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") ChipID: 9900, EMP protocol: 0301 BOOTROM MODE DETECTED SPEED: 115200 LDR: DB2020 LOADER FOR SETOOL2 CURRENT CID: 49 COLOR: BROWN Elapsed: 55 seconds |
11-01-2017, 12:47 | #13 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Russia Age: 44
Member: 9519 Status: Offline Thanks Meter: 2,150 | select USB as interface select K800 as model press "clear" button in firmware selection area on options tab, check ONLY "signed mode", "customize phone during flash" back to Sony Ericsson tab, press flash |
11-01-2017, 19:29 | #15 (permalink) |
Member: 173077 Status: Offline Sonork: 100.1594293 Thanks Meter: 2,784 | Look..... Untill now you have not shown prof of customised in any logs... Do as you have been advised by the Laser and me..
