Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SETool2
Old 03-04-2009, 14:01   #1 (permalink)
sniper007's Avatar
Member: 722656
Sonork: 100.1584918
Thanks Meter: 294
K800 red blinking
hi every one. i got a K800 phone which was dead. i tried to flash the phone but it was giving me following message:
2/19/2009 6:17:48 PM v0.915021/UNI
2/19/2009 6:17:48 PM CARD SERIAL: 00086217
2/19/2009 6:17:48 PM Loaded 51 flash descriptors
2/19/2009 6:18:24 PM ChipID:9900,EMP protocol:0301
2/19/2009 6:18:24 PM BOOTROM MODE DETECTED
2/19/2009 6:18:24 PM Speed:921600
2/19/2009 6:18:24 PM Flash ID check:897E
2/19/2009 6:18:24 PM Flash props sent ok
2/19/2009 6:18:24 PM OTP: LOCKED:1 CID:51 PAF:1 IMEI:35xxxxxxxxxxxxxxxxxx CERT:N/A
2/19/2009 6:18:24 PM FLASH CID:53 COLOR:RED
2/19/2009 6:19:30 PM setGDFS_params failed
2/19/2009 6:19:30 PM failed to setup GDFS
2/19/2009 6:19:30 PM Elapsed: 95 secs.
2/19/2009 6:21:07 PM SIGNED MODE (USING SERVER).
2/19/2009 6:25:31 PM FAILED TO SETUP PHONE
2/19/2009 6:25:31 PM PROCEDURE WAS STOPPED BY USER
2/19/2009 6:25:31 PM Elapsed: 263 secs.
but know i am even not able to identify the phone, i tried both usb and com cables but no result.
the battery is fully charged.
the phone is not water damaged
i know it can be fixed with testpoint but the problem is that the phone is not communicating with software
Old 03-04-2009, 14:06   #2 (permalink)
Miftah_Lutfi's Avatar
Member: 638396
Sonork: 100.1615405
Thanks Meter: 170
you need to repair gdfs via TP..,
br..,
Old 03-04-2009, 14:36   #3 (permalink)
sniper007's Avatar
Member: 722656
Sonork: 100.1584918
Thanks Meter: 294
yeah thats right. but as i said the phone is not connecting to the computer (no communication with the software)
v0.915034/UNI
TESTPOINT REPAIR STAGE #1 STARTED
Open COM port OK
but nothing after that, i press the power on, remove battery, cable but no response, only red blinking in infrared
Old 03-04-2009, 14:40   #4 (permalink)
sniper007's Avatar
Member: 722656
Sonork: 100.1584918
Thanks Meter: 294
v0.915034/UNI
Open COM port OK
Old 03-04-2009, 15:48   #5 (permalink)
Mohsin-*'s Avatar
Member: 417298
Sonork: 100.1578269
Thanks Meter: 18,268
that mean ur gdfs area is corrupted
in this post ur mobile connected with soft after this not connect check connector+cable+hardware
Old 03-04-2009, 16:19   #6 (permalink)
sniper007's Avatar
Member: 722656
Sonork: 100.1584918
Thanks Meter: 294
the cable is working fine as i unlocked/flashed 3 phone with the same cable today. connector is also ok as it blinks red when i connect com cable. hardware i am not sure, what i need to check on hardware, but it was giving me above logs so dont think that it is hardware.
Old 03-04-2009, 16:33   #7 (permalink)
Mohsin-*'s Avatar
Member: 417298
Sonork: 100.1578269
whats result on com cable can u check on com cable
Old 03-04-2009, 17:42   #8 (permalink)
sniper007's Avatar
Member: 722656
Sonork: 100.1584918
Thanks Meter: 294
YAH AS MENTIONED ABOVE.
v0.915034/UNI
Open COM port OK
AND AFTER THIS IT SAYS THE PRESS POWER BUTTONS SHORTLY AND DONT GO FURTHER, I HAVE TRIED IT WITH REMOVING THE BATTERY AND PUTTING IT BACK PLUG/UNPLUG CABLE BUT NO COMMUNICATION WITH THE PHONE AT ALL
Old 03-04-2009, 17:45   #9 (permalink)
raezak's Avatar
Member: 260632
Thanks Meter: 639
use com cable .. short the clock battery atleast 3 to 5 secs then post the results sir
br
Old 03-04-2009, 18:30   #10 (permalink)
sniper007's Avatar
Member: 722656
Sonork: 100.1584918
Thanks Meter: 294
can u tell me plz how to short eh clock battery
Old 03-04-2009, 19:37   #11 (permalink)
Member: 278166
Thanks Meter: 4
OTP CID: 51
Phone CID: 52
Phone color: Red
Sending applet...
Applet ID: 061205 1523 HANCXC9876543210_DB2020...
Sending applet...
Applet ID: 061201 1314 HANCXC1329129_DB2020_FL...
RSA protection state cannot be determined for this CID.
Phone hardware initialized OK
[ --- Customize File System --- ]
Sending CS applet...
Applet ID: 070410 1557 HANCXC1250562_DB2020_CS...
Initializing CS applet...
Baudrate = 921600Bd
Starting up GDFS service...
Could not start GDFS service
any solution on cruiser
Old 03-04-2009, 19:47   #12 (permalink)
Member: 278166
Thanks Meter: 4
k800i red led blinking
on flash
full flash ok but when i customize it
there is problem gdfs could not start
any solution
Old 03-04-2009, 20:05   #13 (permalink)
sniper007's Avatar
Member: 722656
Sonork: 100.1584918
Thanks Meter: 294
br
Open COM port OK
Speed:921600
OTP: LOCKED:1 CID:51 PAF:1 IMEI:35612802000633 CERT:N/A
LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015
PREPARING...
ATTACH TP #1 AND PRESS "READY"
RELEASE TP #1 AND PRESS "READY"
TP #1 INCORRECT
loader refused shutdown, remove and insert battery !
Elapsed: 27 secs.
Open COM port OK
Speed:921600
PREPARING...
TP #1 INCORRECT
Elapsed: 60 secs.
Open COM port OK
Speed:921600
PREPARING...
TP #1 INCORRECT
Elapsed: 27 secs.
Open COM port OK
Speed:921600
PREPARING...
TP #1 INCORRECT
Elapsed: 22 secs.
Open COM port OK
Speed:921600
PREPARING...
TP #1 INCORRECT
Elapsed: 114 secs.
Open COM port OK
Speed:921600
PREPARING...
TP #1 INCORRECT
Elapsed: 60 secs.
Open COM port OK
Speed:921600
PREPARING...
subblock 001 NAK, [44050000/00010000]
Elapsed: 7 secs.
Open COM port OK
Speed:921600
PREPARING...
TP #1 LOOKS OKAY
NOT EXPECTED ANSWER, TP #1 INCORRECT
Elapsed: 155 secs.
Open COM port OK
Speed:921600
PREPARING...
TP #1 INCORRECT
Elapsed: 27 secs.
Open COM port OK
Speed:921600
PREPARING...
TP #1 INCORRECT
Elapsed: 60 secs.
Open COM port OK
Speed:921600
PREPARING...
TP #1 INCORRECT
Elapsed: 27 secs.
Open COM port OK
Speed:921600
PREPARING...
TP #1 INCORRECT
Elapsed: 22 secs.
Open COM port OK
Speed:921600
PREPARING...
TP #1 INCORRECT
Elapsed: 114 secs.
Open COM port OK
Speed:921600
PREPARING...
TP #1 INCORRECT
Elapsed: 60 secs.
Open COM port OK
Speed:921600
PREPARING...
Elapsed: 7 secs.
Open COM port OK
Speed:921600
PREPARING...
TP #1 LOOKS OKAY
Elapsed: 155 secs.
Open COM port OK
Speed:921600
PREPARING...
TP #1 INCORRECT
Elapsed: 45 secs.
Open COM port OK
Speed:921600
PREPARING...
subblock 00E NAK, [44070000/0000FFF0]
Elapsed: 26 secs.
Open COM port OK
Speed:921600
PREPARING...
TP #1 INCORRECT
Elapsed: 43 secs.
Open COM port OK
Speed:921600
PREPARING...
TP #1 INCORRECT
Elapsed: 20 secs.
Open COM port OK
Speed:921600
PREPARING...
TP #1 INCORRECT
Elapsed: 23 secs.
Processing script "C:\Documents and Settings\abc\Desktop\Read_Security_Units.txt"...
Open COM port OK
Speed:921600
PATCH:071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0
Flash ID check:897E
Flash props sent ok
LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013
loader startup: executed
GDFS startup failed (1D)
loader GDFS startup failed, that is fatal
Elapsed: 13 secs.
Open COM port OK
Speed:921600
PREPARING...
TP #1 INCORRECT
Elapsed: 56 secs.
Open COM port OK
Speed:921600
PREPARING...
TP #1 INCORRECT
Elapsed: 26 secs.
Open COM port OK
Speed:921600
PREPARING...
TP #1 INCORRECT
Elapsed: 37 secs.
Open COM port OK
Speed:921600
PREPARING...
TP #1 INCORRECT
Elapsed: 21 secs.
Open COM port OK
Speed:921600
PREPARING...
TP #1 LOOKS OKAY
DONE
Elapsed: 38 secs.
TESTPOINT REPAIR STAGE #2 STARTED
Open COM port OK
Speed:921600
ATTACH TP #2 AND PRESS "READY"
Trying to launch embedded bootloader...
TP #2 INCORRECT OR STAGE #1 NOT EXECUTED
Elapsed: 199 secs.
Open COM port OK
Speed:921600
Elapsed: 55 secs.
Open COM port OK
Speed:921600
Elapsed: 328 secs.
Open COM port OK
Speed:921600
Elapsed: 215 secs.
Open COM port OK
Speed:921600
Elapsed: 172 secs.
Open COM port OK
Speed:921600
phone CID not supported in that mode
Elapsed: 1 secs.
Open COM port OK
Speed:921600
Flash ID check:897E
Flash props sent ok
writing D:\Softwears\1 unlocking drivers backup\setool V41\v0.915016\gdfs_in_ssw_format\db2020\K800_GDFS_ SSW.ssw
CURRENT FLASH FILE CID:49
SSW uses full hash, hash len is:640
HDR block not accepted,error: 19
Elapsed: 16 secs.
Old 03-04-2009, 21:40   #14 (permalink)
Registered User
Member: 493205
Sonork: 100.1581647
Thanks Meter: 526
can post here ic flash picture coz one off this ic conn't take testpoint
Old 03-05-2009, 10:01   #15 (permalink)
Member: 838770
Thanks Meter: 7
dear sniper u must use dreambox for repair gdfs in advance mode for solving your problem.good luck.
K800 red blink (cannot detected) llcoolr Sony Ericsson 49 01-16-2011 21:44
K800 red blink..DONE with SETOOL... rico_deep SETool2 2 11-17-2010 15:48
K800 red blink after unlock with code - can UB fix? James_S Universalbox 10 12-14-2007 10:01
K800 red blinking problem stk_ MT-BOX 1 11-23-2007 17:08
K800 Red Blink alamgarh Cruiser Suite 2 11-19-2007 08:07
Page generated in 0.42729 seconds with 9 queries
