07-25-2008, 12:33 | #1 (permalink) |
Junior Member Join Date: Jun 2007
Member: 519797 Status: Offline Thanks Meter: 6 | K800i CID 53 unlock successfully k800i cid53 unlock successfully...........thanks se-tool team here is logs v0.914037/UNI CARD SERIAL: 00022812 Loaded 51 flash descriptors SIGNED MODE (USING SERVER). ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:53 Speed:921600 Flash ID check:897E Flash props sent ok OTP LOCKED:1 CID:51 PAF:1 IMEI:35427102130360 CERT:RED FLASH CID:53 COLOR:RED no ack during gdfs_readvar ! Can't read SCRC unit Elapsed: 84 secs. SIGNED MODE (USING SERVER). ChipID:9900,EMP protocol:0301 erom_readvar: error reading unit 0/18 error while reading security units SECURITY UNITS CAN'T BE READ ! DAMAGED FIRMWARE,GDFS OR EMPTY PHONE Can't load ID loader ! Elapsed: 11 secs. SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. PRELOADER SECURITY BYPASS ENABLED. ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:53 Speed:921600 Flash ID check:897E Flash props sent ok OTP LOCKED:1 CID:51 PAF:1 IMEI:35427102130360 CERT:RED FLASH CID:53 COLOR:RED Model:K800i Brand:O2 MAPP CXC article: R8BF003 prgCXC1250210_GENERIC_WI MAPP CXC version: R8BF003 Language Package:EUROPE_2 CDA article: CDA102511/40 CDA version: R7A Default article: cxc1250490 Default version: R8BF003 PROVIDER: 272-02 Network LOCKED RESTORATION FILE PRESENT FOR DETECTED FIRMWARE BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE SECURITY UNITS BACKUP CREATED. Elapsed: 18 secs. SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. PRELOADER SECURITY BYPASS ENABLED. ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:53 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35427102130360 CERT:RED FLASH CID:53 COLOR:RED PATCH:071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 Flash ID check:897E Flash props sent ok LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed wrong response, break. loader GDFS startup failed, that is fatal Elapsed: 189 secs. SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:53 Speed:921600 phone pre-boot failed,possible RECOVERY needed. Elapsed: 19 secs. SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:53 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35427102130360 CERT:RED FLASH CID:53 COLOR:RED PATCH:071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 Flash ID check:897E Flash props sent ok LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN BE SURE THAT YOU SET PHONE IN "PHONE MODE" IF ASKED, INSTALL PHONE DRIVERS SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM83 PHONE READY TO PROCEED EXECUTOR STARTED REMOVE CABLE FROM PHONE REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:53 Speed:921600 Trying to launch embedded bootloader... INT LDRB2020_PRELOADER_FOR_SETOOL2 Flash ID check:897E Flash props sent ok FOUND: R8BF003_CXC1250210_GENERIC_WI Restore from:R8BF003_CXC1250210_GENERIC_WI full sig complete. USERCODE RESET TO "0000" Searching... Firmware SIMLOCK check determined. Unlock DONE Elapsed: 329 secs. |
The Following User Says Thank You to Mjabbar For This Useful Post: |
k800i CID 53 Unlocked via Patch | ..::Mr999::.. | SETool2 | 30 | 09-08-2009 14:04 |
K800i - CID 53 Unlocking | harmansaggu | Sony Ericsson | 16 | 06-21-2009 21:57 |
w200 cid 53 unlock successfully by setool | aleem26 | SETool2 | 4 | 01-17-2009 10:47 |
K800i CID 53 UNLOCK | alamgarh | Cruiser Suite | 6 | 07-02-2008 12:55 |
K800i CID 53 UNLOCK SUCSESSFULY | alamgarh | Cruiser Suite | 3 | 06-30-2008 22:32 |
