11-08-2011, 10:15 | #1 (permalink) |
Freak Poster Join Date: Oct 2004 Location: 03453007200
Member: 86994 Status: Offline Sonork: 100.1584487 Thanks Meter: 124 | Xperia X10 Call Ended I got one x10 from a customer when ever i try to make a call on it it straight away gives the option of "Call Ended" similarly i wont be able to do text messaging. Only i can use data services from nework provider. So i need solution from gurus of SE. at last what i tried 1. Reset it all. 2. Erase all data. 3. Update it with seus. 4. Update it with Setool. 5. Check different operators connection. 6. And at i checked from the operator its not barred as well. so help would really be appriciated thnx Br, Qaiser |
11-10-2011, 14:11 | #2 (permalink) |
Junior Member Join Date: Nov 2011
Member: 1686835 Status: Offline Thanks Meter: 0 | Hi, I have the same problem and it has been a week already. I have tried: + RESET and REPAIR the OS Android 2.3 + ERASE all data on SD card Nothing has changed yet sadly. and I noticed that: + after you take picture, there are 4-5 gaps (BLANK) before your recently taken photo + Call cannot be made (CALL ENDED) and Code does not work (Connection problem or invalid MMI code) and ULTIMATELY, cannot receive call >.< + However, 3G works fine Obviously, it is the phone problem as: _ I tried this simcard onto another phone and it works normally, can make call, can receive call So, I wondered if you have the same problem? |
11-10-2011, 14:22 | #4 (permalink) | |
Member: 1686835 Status: Offline Thanks Meter: 0 | Quote:
then Caller ID/ Call waiting options: shaded (cannot be tapped on) (what i have done is Settings> Call settings> Additional settings) + SIM card is alright, I checked with another phone and it works fine + Network is ok, as I still can connect to 3G => Is my phone GMS receiver problem? Last edited by nhanlm0601; 11-10-2011 at 14:26. Reason: Additional Information | |
End address of 5110 v5.29 | odartei | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-22-2001 18:59 |
Unlocked network on 5110v5.28 does not make calls, but other network does? | Prodigal | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 03-01-2001 16:43 |
6150 no outgoing calls | edis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-20-2000 20:19 |
Nokia 6110 without net. couldnīt call 911 either! | DennisT | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 05-09-2000 11:37 |
