10-12-2007, 19:20 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Location: india
Member: 239168 Status: Offline Thanks Meter: 104 | K800i Dead-its Gdfs Region Damaged-help i got one k800i dead.customer said that removed battery when turn on(i mean without turn off) .then never can not turn on. when clicked in identify got as below Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 Flash ID check:2019 Flash props sent ok OTP LOCKED:1 CID:49 PAF:1 IMEI:35399601775701 CERT:RED FLASH CID:49 COLOR:RED set_gdfs_props failed, exiting Elapsed:7 secs. then i tried to flash using 49 files after tick two options in SETTINGS. complete the phone and use server for unlock/flash and got as below Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35399601775701 CERT:RED FLASH CID:49 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 Flash ID check:2019 Flash props sent ok writing E:\may2007\students cd\25.SE TOOL\flash files\k800\FROM SETOOL NET\R1EJ001_1250568_HUTCHISON_WI.ssw.cry CURRENT FLASH FILE CID:49 SSW uses complete hash, hash len is:9100 Will flash 455 blocks... SSW loading returns:0 writing E:\may2007\students cd\25.SE TOOL\flash files\k800\FROM SETOOL NET\R1EJ001_HUTCH_1_fs.ssw.cry CURRENT FLASH FILE CID:49 SSW uses complete hash, hash len is:4420 Will flash 221 blocks... SSW loading returns:0 CSloader version: 061027 1723 HANCXC1250562_DB2020_CSLOADER_R3A005 loader startup: executed loader filesystem startup: executed csloader refused to start GDFS services,error is:29 loader GDFS startup failed, that is fatal Elapsed:613 secs. flashing main and fs no problem.but an error during complete the phone . '''''''loader filesystem startup: executed csloader refused to start GDFS services,error is:29 loader GDFS startup failed, that is fatal'''''''''' FROM FAQ I UNDERSTOOD THAT GDFS SERVICES ERROR 29 IS DUE TO EROM. using 4in1 cable.got the log as below """"""DB2020 EROM UPGRADE STARTED Open COM port OK OTP LOCKED:1 CID:49 PAF:1 IMEI:35399601775701 CERT:RED FLASH CID:49 COLOR:RED Flash ID check:2019 Flash props sent ok EROM UPGRADE CAN'T FIND QUALIFIED PART Elapsed:4 secs.""""""""""""" after erom upgrade using 4in1 cable-flashed-same error as above CS LOADER REFUSED TO START GDFS SERVICES,ERROR IS 29 LOADER GDFS STARTUP FAILED,THAT IS FATAL HAVE U ANY IDEA OF MY PROBLEM? |
The Following 3 Users Say Thank You to zonetrichur For This Useful Post: |
12-20-2007, 22:40 | #4 (permalink) |
Junior Member Join Date: Jan 2006
Member: 222144 Status: Offline Thanks Meter: 2 | I had the same problem Ensure that the files you write to phone the SSW ones are not READ ONLY you did copy it from a CD, I see it in your patch, so they should be now read only this stupidy SSW not to be read only confuzed me a week I got the same error you get by flashing that way, flash it again and unlock and it will work here a log of a phone i "killed" thad way v0.914021/UNI CARD SERIAL: 00041678 Loaded 51 flash descriptors ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:115200 Flash ID check:897E Flash props sent ok OTP LOCKED:1 CID:51 PAF:1 IMEI:35945101073650 CERT:RED FLASH CID:52 COLOR:RED Model:K810i Brand:Era MAPP CXC article: R8BA024 prgCXC1250811_GENERIC_SM MAPP CXC version: R8BA024 Language Package:CENT_EUROPE CDA article: CDA102779/19 CDA version: R4A Default article: cxc1250813 Default version: R8BA024 Network LOCKED Operator: 260-02 RESTORATION FILE NOT PRESENT "R8BA024_CXC1250811_GENERIC_SM" YOU MUST PERFORM FULL FLASHING FOR PATCH UNLOCK SECURITY UNITS BACKUP CREATED. Elapsed:16 secs. SERVER SUPPORT ENABLED. ALTERNATIVE SECURITY BYPASS ENABLED. ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:115200 OTP LOCKED:1 CID:51 PAF:1 IMEI:35945101073650 CERT:RED FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok CID52 BYPASS PROCEDURE STARTED Processing part1... Processing part2... Processing part3.... OTP LOCKED:1 CID:51 PAF:1 IMEI:35945101073650 CERT:RED FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok REMOVE CABLE FROM PHONE REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" HOLD "C" BUTTON AND ATTACH PHONE CID52 BYPASS PROCEDURE FINISHED bypassing security... ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:921600 Trying to launch embedded bootloader... Embedded flashloader: DB2020_PRELOADER_FOR_SETOOL2 Flash ID check:897E Flash props sent ok writing E:\setool\SE\K810\CID52\r8ba024\R8BA024_1250811_GE NERIC_SM.ssw CURRENT FLASH FILE CID:52 SSW uses complete hash, hash len is:9200 Will flash 460 blocks... SSW loading returns:0 writing E:\setool\SE\K810\CID52\r8ba024\R8BA024_FS_BALTIC_ SM_RED_CID52.ssw CURRENT FLASH FILE CID:52 SSW uses complete hash, hash len is:4340 Will flash 217 blocks... SSW loading returns:0 full sig complete. USERCODE RESET TO "0000" Searching... Firmware lock check determined. LDR:060426 1726 HANCXC1329133_DB2020_FILESYSTEMLOADER_P5G loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed writing tpa/preset/custom/C3_PCA_G3v2.cer writing tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm writing tpa/preset/custom/customize.xml writing tpa/preset/custom/DESKTOP_HOOK_2.itm writing tpa/preset/custom/Entrust.net Root Certificate.cer writing tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt writing tpa/preset/custom/FM_PICTURES_HOOK_3.itm writing tpa/preset/custom/FM_SOUNDS_HOOK_3.itm writing tpa/preset/custom/FM_THEMES_HOOK_3.itm writing tpa/preset/custom/FM_VIDEOS_HOOK_3.itm writing tpa/preset/custom/GAMES_HOOK_3.itm writing tpa/preset/custom/GTE_CyberTrust_Root.cer writing tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt writing tpa/preset/custom/Root.cer writing tpa/preset/custom/SEMC_E2E_Root_CA.crt writing tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm writing tpa/preset/custom/ThawtePremium.der writing tpa/preset/custom/ThawteServerCA.cer writing tpa/preset/custom/Utiroot.cer writing tpa/preset/custom/VeriSignClass3Root.cer writing tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt Phone detached Elapsed:980 secs. and now it works always make a copy of GDFS and security with the free cruiser tool or simply by reading GDFS in setool hope it helps |
The Following User Says Thank You to CR0N0 For This Useful Post: |
07-06-2008, 07:43 | #5 (permalink) |
Freak Poster Join Date: Mar 2007 Location: Karachi
Member: 471955 Status: Offline Thanks Meter: 201 | K800i cid 51 Dead-its Gdfs Region Damaged-help Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 Flash ID check:2019 Flash props sent ok OTP LOCKED:1 CID:51 PAF:1 IMEI:35471601926015 CERT:N/A FLASH CID:51 COLOR:RED IMEI MISMATCH ! GDFS IMEI:35220601088401 Model:K790i Brand:Sony Ericsson MAPP CXC article: R1CC003 prgCXC1250477_GENERIC_EV MAPP CXC version: R1CC003 Language Package:S_ASIA_LEVAN CDA article: CDA102568/110 CDA version: R4A Default article: cxc1250491 Default version: R1CC003 PROVIDER: 000-00 SIMLOCKS NOT DETECTED RESTORATION FILE PRESENT FOR DETECTED FIRMWARE Elapsed: 3 secs. |
07-06-2008, 07:53 | #6 (permalink) |
No Life Poster Join Date: Sep 2005
Member: 183043 Status: Offline Thanks Meter: 68 | why did you write k790 gdfs into k800. use new version and new tp cable by setool and your problems is solved |
The Following User Says Thank You to W4r10rD For This Useful Post: |
07-07-2008, 15:23 | #7 (permalink) |
Major Poster Join Date: Apr 2008
Member: 755881 Status: Offline Sonork: InfiEx Thanks Meter: 2 | Elapsed:7 secs. ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:53 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:354271****** CERT:RED FLASH CID:53 COLOR:RED Can't build loaders chain ;( Elapsed:8 secs. any help here on this CID 53? thanks |
07-07-2008, 15:25 | #8 (permalink) |
Member: 755881 Status: Offline Sonork: InfiEx Thanks Meter: 2 | Profiling SEMC phone... 15:05:36| Platform: DB2020 15:05:36| OTP CID: 51 15:05:36| EROM CID: 53 15:05:36| EROM Color: Red 15:05:36| IMEI: 35427102****** 15:05:36| Phone ID: K800 15:05:36| Region: EUROPE_2 15:05:36| CDA: CDA102511/187 R3A 15:05:36| Firmware Version: R8BF003 15:05:36| EROM: R3A022 |
The Following User Says Thank You to InfintyExplorer For This Useful Post: |
How To Repair damaged security units, damaged gdfs area,damaged EROM Of A1 Phone. | sarfaraghussain | Sony Ericsson | 0 | 02-26-2010 17:40 |
unable to write GDFS region in P990i | SurvivaL | Sony Ericsson | 0 | 03-27-2009 10:26 |
K800i turning its self off | Bean1uk | KULANKENDI Server | 3 | 07-27-2007 04:22 |
can i write gdfs from one k800i to another?is it damage the permanentley? | zonetrichur | Cruiser Suite | 6 | 05-29-2007 00:00 |
CAn 8360 have its GDFS written without test point? | Burnt Cobba | VygisToolbox | 0 | 02-08-2006 15:01 |
