10-07-2010, 00:06 | #1 (permalink) |
No Life Poster Join Date: Apr 2009
Member: 1012165 Status: Offline Thanks Meter: 116 | lg u8120 unlocked successfully with setool gave the log below but the phone was still lock but when i selected lg u8330 (but i lost the log for this)it unlocked by patching and the phone was then unlocked successfully,its an old trick but still very useful for newbies. RUNNING v 1.01/UNI CARD SERIAL 0004.... SIGNED MODE (USING SERVER) CFG:100000000000 PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Elapsed: 28 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:7100,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0017 skipping empty loader... FAILED TO SETUP PHONE Elapsed: 16 secs. SIGNED MODE (USING SERVER) CFG:100000000000 PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Elapsed: 24 secs. CFG:000000000000 ChipID:7100,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0017 Speed:921600 BAUDRATE DECREASED OTP: LOCKED:1 CID:17 PAF:0 IMEI:35511600673272 CERT:BROWN LDR:041214 0759 MATCXC1325712_PRODUCTION R2Z FLASH ID: 890D Setting up GDFS... WRITING CLEAR SIMLOCK UNITS... INSERT ANY SIM, ENTER 2945#*88110#, THEN GENERATED CODE ALL UNLOCK/LOCK CODES SET TO "71064808" SIGNING... Unlock FINISHED Elapsed: 8 secs. |
The Following 2 Users Say Thank You to tonywireless For This Useful Post: |
10-07-2010, 00:36 | #2 (permalink) | |
Freak Poster Join Date: Feb 2007 Location: MARS
Member: 444981 Status: Offline Thanks Meter: 45 | even so Quote:
06-20-2016, 23:06 | #4 (permalink) |
Junior Member Join Date: Aug 2013 Location: london
Member: 1994699 Status: Offline Thanks Meter: 6 | How do we unlock that phone, i mean are you guys using usb cable to unlock the phone? I have only u8110 rj45 cable that came with the box but phone is not connecting to computer with this cable? Would some of you guys share the full procedure like which cable and when connect the phone? |
06-21-2016, 11:05 | #5 (permalink) | |
No Life Poster Join Date: Oct 2005 Location: England
Member: 193192 Status: Offline Thanks Meter: 327 | Quote:
03-23-2020, 14:59 | #6 (permalink) | |
Freak Poster Join Date: Feb 2015
Member: 2349975 Status: Offline Thanks Meter: 51 | Quote:
RUNNING v 1.1411/01.14/UNI CARD SERIAL 001XXX53 USBFLASH DRIVER VERSION 03.00.00.00 Found 2 FTDI device(s). UFS #76741 READY CFG:000000000000 ChipID: 7100, EMP protocol: 0301 PHONE DOMAIN: "DEVELOPER" PHONE CID: 0017 SPEED: 115200 LDR: 040318 1450 LLECXC1325413_CERTLOADER R3J OTP: LOCKED:1 CID:17 PAF:0 IMEI:355116004XXX97 CERT:BROWN LDR: 041214 0759 MATCXC1325712_PRODUCTION R2Z FLASH ID: 890D LG3G patching started. patch #0 found patch #1 NOT found patch #2 NOT found patch #3 NOT found patch #4 found Setting up GDFS ... WRITING CLEAR SIMLOCK UNITS ... INSERT ANY SIM, ENTER 2945#*88110#, THEN GENERATED CODE IF THIS WON'T WORK, SELECT U8330 AS MODEL AND REPEAT UNLOCK SIMLOCK CODES SET TO "45281614" SIGNING ... Unlock DONE Elapsed: 99 secs. The above is my successful lg u8120 unlock logs. I connected my setool2 box and my ufs box. Open setool2 software and choose model lg8330 and under port setting choose ufs and click unlock and repair tab then connect your phone via rj45 cable attached to ufs box and wait till unlock is done as per above longs that takes about 100 seconds, | |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
