Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SETool2
Old 07-06-2010, 12:18   #1 (permalink)
visionmaster20's Avatar
Member: 214200
Thanks Meter: 35
How to connect GT400
Please, how to connect GT400 for unlock and driver usb
Thanks
The Following 2 Users Say Thank You to visionmaster20 For This Useful Post:
Old 07-06-2010, 12:41   #2 (permalink)
Member: 476287
Sonork: 100.1587961
Thanks Meter: 834
Conect phone to bootrom mode with volum up driver same as semc A2
The Following 3 Users Say Thank You to adelgsm For This Useful Post:
Old 07-06-2010, 14:10   #3 (permalink)
Member: 1322811
Thanks Meter: 46
after unlock your phone using setool box your phone is daed tested by me
meracl phone revived by octopus
for unlock your phone press + volum poton and conetc usb cable using octopus v1.40 tested by me
Old 07-15-2010, 09:58   #4 (permalink)
allGSMcode's Avatar
Member: 947842
Sonork: 100.114141
Thanks Meter: 126
tjheris no miracle u can revive it by setool also just flash gt40x_boot_fix.ssw
Old 07-21-2010, 16:43   #5 (permalink)
malikzahidawan's Avatar
Member: 251421
Sonork: 100.1609329
Thanks Meter: 439
FOR CONNECTING USE VOLUME UP BUTTON PRESSED AND CONNECT WITH MICRO IF U USE 1.085 U DONT NEED TO FLASH PHONE AFTER UNLOCK
I JUST UNLOCKED A GT400
ALL I DONE USED 1.085 SETUP
1. SELECT GT400
2. SIGNED MODE CHECK
3. CLICK UNLOCK & CONNECT PHONE USING MICRO USB PRESS & HOLD CAMERA & VOLUME DOWN BUTTON WHILE PHONE IS SWITCHED OFF.
UNLOCK IS DONE
NO NEED TO FLASH AFTER UNLOCK
LOG IS HERE
RUNNING v 1.085/UNI
CARD SERIAL 0010XXXX
USBFLASH DRIVER VERSION 02.02.00.05
SIGNED MODE (USING SERVER)
CFG:100000000000
ChipID900,EMP protocol:0401
BOOTROM MODE DETECTED
OTP DBG: [1,54,0,35XXXXXXXXXXX]
OTP LOCKED:1 CID:54 PAF:0 IMEI:35XXXXXXXXX7 CERT:RED
LDR:YTRCXC1723918_C2_DB3200_PRODUCTION_LOADER_ACC_ SDRAM_SETOOL2
LDR CAPS:SYSTEM FLASH SIGNATURE
LDR:YTRCXC1723919_1C2_DB3200_PRODUCTION_LOADER_APP _SDRAM_JEFF_CABS_SETOOL2
LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM
WRITING CLEAR SIMLOCK UNITS...
SIMLOCK CODES SET TO "87747047"
SIGNING...
LDR:100119 1522 MATCXC1723917_3E2_DB3200_FLASH_LOADER_APP_SDRAM_CA BS_GDFS_ALL_R1A
Unlock DONE
Elapsed: 73 secs.
The Following 6 Users Say Thank You to malikzahidawan For This Useful Post:
Old 07-21-2010, 16:43   #6 (permalink)
Member: 251421
Sonork: 100.1609329
Thanks Meter: 439
HOPE IT WILL HELP U, sORRY IT WAS DOUBLE POST SO I CHANGED IT
Old 07-31-2010, 16:15   #7 (permalink)
Member: 232050
Thanks Meter: 23
I've got one that just wont connect! push and hold up volume , insert cable and the phone switches on - i must have tried 20 times! any ideas?
Old 07-31-2010, 16:51   #8 (permalink)
Member: 232050
Thanks Meter: 23
not to worry guys, must need a full battery - worked perfectly when powered using power supply! thanks anyway...
The Following User Says Thank You to canny2 For This Useful Post:
Old 07-31-2010, 17:07   #9 (permalink)
DaWizard's Avatar
Member: 61557
Thanks Meter: 130
bro what cable to use and pinout please tnx.
Old 07-31-2010, 21:55   #10 (permalink)
roney_nexus's Avatar
Member: 288504
Sonork: .:100.1587032:.
Thanks Meter: 2,266
Its Micro USB cable Bro Thx.
Old 08-08-2010, 10:47   #11 (permalink)
GSM SNIPER's Avatar
Member: 27291
Thanks Meter: 81
1. SELECT GT400
UNLOCK IS DONE
LOG IS HERE
RUNNING v 1.085/UNI
CFG:100000000000
SIGNING...
Unlock DONE
Elapsed: 73 secs.
the phone won't connect ! tried many times your procedure but in vain
Old 10-09-2010, 16:49   #12 (permalink)
BCcommunication's Avatar
Member: 76456
Sonork: 100.1678368
Thanks Meter: 60
1. SELECT GT400
UNLOCK IS DONE
LOG IS HERE
RUNNING v 1.085/UNI
CFG:100000000000
SIGNING...
Unlock DONE
Elapsed: 73 secs.
nice job brother i did unlock
Old 10-12-2010, 13:59   #13 (permalink)
Member: 17351
Thanks Meter: 41
Drivers here
Hope it helps took me a while to find them!
http://www.the-emz.com/temp/GT400.zip
Just to add a Nokia CA-101 cable works perfectly and press up on volume as described to connect!
The Following User Says Thank You to The Dog For This Useful Post:
Old 10-12-2010, 14:36   #14 (permalink)
Hacker84's Avatar
Member: 789804
Sonork: 100.1591611
Thanks Meter: 147
Thanks
Here is the info
http://forum.gsmhosting.com/vbb/f473...l-box-1114546/
Old 10-12-2010, 19:08   #15 (permalink)
Member: 1229990
Thanks Meter: 5
Need drivers gt400
plz help me! I need drivers for ericsson mobille platform ( gt400 )
semc A2 drivers
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-27-2015 11:57
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 18:29
Copy from one 6110 to another Leif Nielsen Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-10-1999 22:36
Page generated in 0.37865 seconds with 9 queries
