LT18i unlock done by setool using testpoint DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Unlock FAILED Elapsed: 64 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000010 DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE PROCESSING ... REMOVE TESTPOINT NOW, THEN PRESS "READY" PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... RUNNING S1_LOADER VER "R4A069" LOADER AID: 0001 FLASH ID: "002C/00B3" LOADER VERSION: "r4A069" PHONE IMEI : 35850604242826 Checking for signature ... Waiting for calculation process ... RESPONSE: "SUCCESS" [1256] WRITING SEMCBOOT ... Unlock DONE Procedure: 1. prepare for testpoint operation. check testpoints location for your phone model in dist\docs\s1_qualcomm_uart_cables or use GPG cable set open testpoints for access if you do not have GPG cable set, get some needle with wire, connect it to phone gnd ( battery minus ) or to usb cable shield, etc. 2. select proper phone model. select COM as interface. on settings check signed mode, use alternative security bypass, do full unlock instead usercode reset, use testpoint (gnd type) fill login/password and check if account valid. press unlock when prompted, execute steps in EXACT order:
how to unlock without setol sony ericsson KT18i |
SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000010 DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE PROCESSING ... llbug: write error: "The device does not recognize the command" llbug: blk write fail.fatal qcSendPacket: can't send packet. FAILED TO SETUP PHONE Unlock FAILED Elapsed: 64 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000010 DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE PROCESSING ... REMOVE TESTPOINT NOW, THEN PRESS "READY" qcReceivePacket: can't get packet start. FAILED TO SETUP PHONE Unlock FAILED Elapsed: 180 secs. |
where can find s1_qualcomm_uart_cables or use GPG cable??i only have E20.X10.E16.E10 GPG cable,but not use in LT18i |
Because the cable is not needed, go to youtube and find how to unlock phone via SETool. |
can you show us the picture with the test point please, and i hear that this model LT18i canīt be unlocked, models made in 2012 can not be unlock. thx for some aclarations pls |
CARD COUNTERS: FLASH 174, UNLOCK 54 Elapsed: 2 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000010 DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE PROCESSING ... REMOVE TESTPOINT NOW, THEN PRESS "READY" qcReceivePacket: can't get packet start. FAILED TO SETUP PHONE Unlock FAILED Elapsed: 107 secs. how can solve this error? |
new security (99.99%) if erom >=r9xxxx and YearwWeek >=12w14 read post #12 HOW TO WORK WITH SEMC PDA PHONES - Page 2 |
28/05/2016 17:20:21 RUNNING v 1.1404/01.15/UNI 28/05/2016 17:20:21 CARD SERIAL 00236xxx 28/05/2016 17:20:21 USBFLASH DRIVER VERSION 03.00.00.00 28/05/2016 17:26:12 SIGNED MODE (USING SERVER) 28/05/2016 17:26:12 ALTERNATIVE SECURITY BYPASS ENABLED 28/05/2016 17:26:12 CFG:110010000000 28/05/2016 17:26:12 28/05/2016 17:26:12 DETACH USB CABLE FROM PHONE 28/05/2016 17:26:12 REMOVE BATTERY FROM PHONE 28/05/2016 17:26:12 ATTACH TESTPOINT 28/05/2016 17:26:12 PRESS "READY", THEN ATTACH USB CABLE TO PHONE 28/05/2016 17:26:12 28/05/2016 17:28:03 PROCESSING ... 28/05/2016 17:28:04 REMOVE TESTPOINT NOW, THEN PRESS "READY" 28/05/2016 17:28:04 28/05/2016 17:28:12 PLEASE ATTACH TURNED OFF PHONE NOW 28/05/2016 17:28:12 PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... 28/05/2016 17:28:14 28/05/2016 17:28:14 RUNNING S1_LOADER VER "R4A069" 28/05/2016 17:28:14 28/05/2016 17:28:14 EROM_AID : 0001 28/05/2016 17:28:14 LOADER_AID : 0001 28/05/2016 17:28:14 HWCONF_AID : 0001 28/05/2016 17:28:14 ACTIVE_LOADER_AID : 0001 28/05/2016 17:28:14 28/05/2016 17:28:18 DEVICE ID: 18A5E74DCEEED365ED81393AC49DBCD1B171D1F7 28/05/2016 17:28:18 FLASH ID: "002C/00B3" 28/05/2016 17:28:18 LOADER VERSION: "r4A069" 28/05/2016 17:28:18 28/05/2016 17:28:18 PHONE IMEI : 35850604218325 28/05/2016 17:28:20 Checking for signature ... 28/05/2016 17:28:21 WRITING SEMCBOOT ... 28/05/2016 17:28:22 Unlock DONE 28/05/2016 17:28:22 Elapsed: 130 secs. |
how to connect the test point , please diagram |
DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE will use DLOAD protocol ... 0806010100900000 0D1450424C5F446F776E6C6F6164657256455231 030006 030006 030006 PROCESSING ... REMOVE TESTPOINT NOW, THEN PRESS "READY" qcReceivePacket: can't get packet start IF TESTPOINT DONE OK,THIS IS NOT SUPPORTED MCU REVISION FAILED TO SETUP PHONE Unlock FAILED Elapsed: 30 seconds Not done |
