08-26-2008, 16:02 | #1 (permalink) |
Freak Poster Join Date: Jun 2006 Location: Tunisia
Member: 296895 Status: Offline Thanks Meter: 33 | help with this k600 but phone can't start setool log : PHONE IS BROWN FLASH CID detected:36 Speed:115200 Flash ID check:200D Flash props sent ok OTP LOCKED:1 CID:36 PAF:1 IMEI:35657200472987 CERT:BROWN FLASH CID:36 COLOR:BROWN set_gdfs_props failed, exiting Elapsed: 7 secs. please help to solve this |
08-26-2008, 18:44 | #2 (permalink) | |
No Life Poster Join Date: May 2007 Location: "Alfa-Gsm"
Member: 507536 Status: Offline Thanks Meter: 75 | K600 Power Problem Quote:
regaRDs! ..::Alfa-Gsm::.. | |
The Following User Says Thank You to John(LMT) For This Useful Post: |
08-26-2008, 20:28 | #3 (permalink) |
No Life Poster Join Date: May 2007 Location: Shoaib Electronics
Member: 515273 Status: Offline Sonork: 100.1573940 Thanks Meter: 339 | Thanks John You do great job Help junier members Keep it up Bro. Regards Shoaib Electronics |
The Following User Says Thank You to dil_PAKISTANI For This Useful Post: |
10-17-2008, 04:39 | #5 (permalink) |
Freak Poster Join Date: Sep 2007 Location: ETIVAC
Member: 584832 Status: Offline Sonork: 100.1601217 Thanks Meter: 35 | can somebody share me a k600 cid 36 flash files for setool, support dosent have it even in v600 0r in k608, all available is for cid 49 your share is highly appreciated..... tia |
04-29-2010, 09:42 | #6 (permalink) |
No Life Poster Join Date: Sep 2006 Location: (¯Catch Me If U Can¯) Age: 50
Member: 360073 Status: Offline Thanks Meter: 2,181 | v0.915057/UNI CARD SERIAL: 0011**** Loaded 51 flash descriptors SIGNED MODE (USING SERVER) CFG:100110000000 ChipID:7100,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 BAUDRATE DECREASED OTP: LOCKED:1 CID:36 PAF:1 IMEI:35683000******CERT:RED LDR:050926 1419 NPA1CXC1250163_SEMC_FLASHLOADER R2A FLASH ID:890D SWITCHING TO "USB"... interface not changed writing "E:\se\v600 k600\r2af001_vfe1_fs.ssw.cry" CURRENT FLASH FILE CID:49 SSW uses dynamic hash, dynamic hash len is: 102 Will flash 102 blocks... writing "E:\se\v600 k600\r2af001_CXC1250074_EU_2_MI.ssw.cry" CURRENT FLASH FILE CID:49 SSW uses dynamic hash, dynamic hash len is: 326 Will flash 326 blocks... LDR:070418 2010 NPACXC1327363_SEMC_CS_LOADER_1_P4L loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed using GENERIC phone customization tpa/preset/custom/C3_PCA_G3v2.cer tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm tpa/preset/custom/customize.xml tpa/preset/custom/DESKTOP_HOOK_2.itm tpa/preset/custom/Entrust.net Root Certificate.cer tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt tpa/preset/custom/FM_PICTURES_HOOK_3.itm tpa/preset/custom/FM_SOUNDS_HOOK_3.itm tpa/preset/custom/FM_THEMES_HOOK_3.itm tpa/preset/custom/FM_VIDEOS_HOOK_3.itm tpa/preset/custom/GAMES_HOOK_3.itm tpa/preset/custom/GTE_CyberTrust_Root.cer tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt tpa/preset/custom/Root.cer tpa/preset/custom/SEMC_E2E_Root_CA.crt tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm tpa/preset/custom/ThawtePremium.der tpa/preset/custom/ThawteServerCA.cer tpa/preset/custom/Utiroot.cer tpa/preset/custom/VeriSignClass3Root.cer tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt Phone detached Elapsed: 737 secs. |
04-29-2010, 09:59 | #7 (permalink) |
can someone help with this one please | bar1bar1 | Nokia Multimedia | 1 | 11-07-2003 01:08 |
Need help with this patching problem | atifprince | Siemens-Benq Flash Patching | 3 | 10-17-2003 22:00 |
Help with this s45 map... | landy | Phone Unlocking Codes & Maps | 2 | 09-04-2002 20:50 |
SBFUNLC need help with this program!!!! | Me@n | Infineon C16X M51 & ARM7 M52 BASED | 2 | 01-17-2002 14:01 |
