04-13-2021, 19:45 | #1 (permalink) |
Freak Poster Join Date: Dec 2014
Member: 2312682 Status: Offline Thanks Meter: 34 | need hellp w580 SIGNED MODE (USING SERVER) CFG:101000000000 ChipID: 9900, EMP protocol: 0301 BOOTROM MODE DETECTED SPEED: 115200 LDR: 071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M FLASH ID: 897E OTP: LOCKED:1 CID:51 PAF:1 IMEI:3525600xxxxxxx ACTIVE CID: 49 COLOR: BROWN packet not accepted (21) llbug: read error: "El dispositivo no reconoce el comando" can't get packet start no ACK during GDFS_ReadVar ! SCRC READ FAILURE Elapsed: 9 seconds |
04-21-2021, 00:58 | #2 (permalink) |
Member: 2312682 Status: Offline Thanks Meter: 34 | RUNNING v 1.1437/01.16/UNI CARD SERIAL 10106810 USBFLASH DRIVER VERSION 03.02.00.00 CFG:000000000000 ChipID: 9900, EMP protocol: 0301 BOOTROM MODE DETECTED SPEED: 115200 LDR: 071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M FLASH ID: 897E OTP: LOCKED:1 CID:51 PAF:1 IMEI:35256002668182 ACTIVE CID: 49 COLOR: BROWN packet not accepted (21) llbug: write error [Se ha especificado un dispositivo que no existe] no ACK during GDFS_ReadVar ! SCRC READ FAILURE Elapsed: 16 seconds SIGNED MODE (USING SERVER) CFG:100000000000 RESET MODE STARTED ChipID: 9900, EMP protocol: 0301 BOOTROM MODE DETECTED SPEED: 115200 RESET: 070703 1106 NPACXC1250329_DB2020_CERTRESETLOADER_P3AA FLASH ID: 897E GOT SEED: 0248FC7423803061256021A3 P96 AUTH PASSED OTP: LOCKED:1 CID:51 PAF:1 IMEI:35256002668182 PHONE SUCCESSFULLY RESET TO DEVELOPER STATE Elapsed: 18 seconds CFG:000000000000 file "gdfs.bin" can't be found or opened Elapsed: 0 seconds CFG:000000000000 ChipID: 9900, EMP protocol: 0301 BOOTROM MODE DETECTED SPEED: 115200 LDR: 071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M OTP: LOCKED:1 CID:51 PAF:1 IMEI:35256002668182 CURRENT CID: 49 COLOR: BROWN LDR: DB2020 LOADER FOR SETOOL2 FLASH ID: 897E writing "C:\Users\fredi\OneDrive\Escritorio\setool2 v1.1436\setool2 v1.1436\gdfs_in_ssw_format\db2020\W580_GDFS_SSW.ss w" CURRENT FLASH FILE CID: 49 SSW using full hash, hash len is: 640 Will flash 32 blocks ... Setting up GDFS ... OTP WRITE SKIPPED WRITING CLEAR SIMLOCK UNITS ... SIMLOCK CODES SET TO "71388140" SIGNING ... Elapsed: 28 seconds CFG:000000000000 ChipID: 9900, EMP protocol: 0301 BOOTROM MODE DETECTED SPEED: 115200 LDR: 071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M OTP: LOCKED:1 CID:51 PAF:1 IMEI:35256002668182 CURRENT CID: 49 COLOR: BROWN LDR: DB2020 LOADER FOR SETOOL2 FLASH ID: 897E writing "C:\Users\fredi\OneDrive\Escritorio\setool2 v1.1436\setool2 v1.1436\eroms\db2020\DB2020EROM_CNV_RED51_BROWN_CI D49_DB2020.ssw" CORRUPTED FILE Elapsed: 5 seconds CFG:000000000000 ChipID: 9900, EMP protocol: 0301 BOOTROM MODE DETECTED SPEED: 115200 LDR: 071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M OTP: LOCKED:1 CID:51 PAF:1 IMEI:35256002668182 CURRENT CID: 49 COLOR: BROWN LDR: DB2020 LOADER FOR SETOOL2 FLASH ID: 897E writing "C:\Users\fredi\OneDrive\Escritorio\setool2 v1.1436\setool2 v1.1436\eroms\db2020\DB2020EROM_CNV_RED49_BROWN_CI D49_DB2020.ssw" CORRUPTED FILE Elapsed: 12 seconds SIGNED MODE (USING SERVER) CFG:100000000000 llbug: [\\?\USB#VID_0BDB&PID_100E#5&1e7d8db7&0&9#{a5dcbf10-6530-11d2-901f-00c04fb951ed}] open error: "El sistema no puede encontrar el archivo especificado" FAILED TO SETUP PHONE Elapsed: 23 seconds SIGNED MODE (USING SERVER) CFG:100000000000 ChipID: 9900, EMP protocol: 0301 BOOTROM MODE DETECTED SPEED: 115200 LDR: 071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M OTP: LOCKED:1 CID:51 PAF:1 IMEI:35256002668182 CURRENT CID: 49 COLOR: BROWN LDR: DB2020 LOADER FOR SETOOL2 FLASH ID: 897E writing "C:\Users\fredi\OneDrive\Escritorio\setool2 v1.1436\setool2 v1.1436\eroms\db2020\DB2020EROM_CNV_RED49_BROWN_CI D49_DB2020.ssw" CORRUPTED FILE Elapsed: 18 seconds |
04-21-2021, 02:42 | #3 (permalink) |
Member: 2312682 Status: Offline Thanks Meter: 34 | FAILED TO SETUP PHONE Elapsed: 23 seconds SIGNED MODE (USING SERVER) CFG:100000000000 ChipID: 9900, EMP protocol: 0301 BOOTROM MODE DETECTED SPEED: 115200 LDR: 071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M OTP: LOCKED:1 CID:51 PAF:1 IMEI:35256002668182 CURRENT CID: 49 COLOR: BROWN LDR: DB2020 LOADER FOR SETOOL2 FLASH ID: 897E writing "C:\Users\fredi\OneDrive\Escritorio\setool2 v1.1436\setool2 v1.1436\eroms\db2020\DB2020EROM_CNV_RED49_BROWN_CI D49_DB2020.ssw" CORRUPTED FILE Elapsed: 18 seconds Report Post Reply With Quote not possible write erom faild corrupted file |
