GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   SETool2 (https://forum.gsmhosting.com/vbb/f473/)
-   -   Need Help To Convert K610 Cid 49 To 52 (https://forum.gsmhosting.com/vbb/f473/need-help-convert-k610-cid-49-52-a-499478/)
addictz 02-08-2008 05:01
hi..can someone help me convert SE k610 cid 49 to cid 52..i have setool...
thnx..
nhey_killuah 02-08-2008 05:07
1 Attachment(s)
just download the attachment file
joauz 02-08-2008 05:15
if you have jaf p-key use jafseflaher
addictz 02-08-2008 05:45
i got cid 49..can i use this process?thnx for response..
prasse 02-08-2008 06:00
write this "db2020 to cid52.txt" script with setool, next flash cid52 file from support or update phone sw via sonyericsson.com update service and your phone will be cid52
addictz 02-08-2008 06:03
ok sir..thnx for the info..
nhey_killuah 02-08-2008 06:09
1 Attachment(s)
you dont have write the attached file..
its a instruction guide for you..
you just have to read it..
put the attach file on misc then write it
addictz 02-08-2008 07:37
ok i'll try sir..i'll post result...
addictz 02-08-2008 07:43
v0.914023/UNI
CARD SERIAL: 000*****
Loaded 51 flash descriptors
Open COM port OK
ChipID:9900,EMP protocol:0301
Speed:921600
Can't load ID loader !
Elapsed:5 secs.
Open COM port OK
Speed:921600
Flash ID check:897E
Flash props sent ok
OTP LOCKED:1 CID:49 PAF:1 IMEI:353*********** CERT:N/A
FLASH CID:51 COLOR:RED
Model:K610i
MAPP CXC article: R1ED001 prgCXC1250374_GENERIC_TH
MAPP CXC version: R1ED001
Language Package:C_ASIA
CDA article: CDA102295/1
CDA version: R2A
Default article: cxc1250376
Default version: R1ED001
PROVIDER: 000-00
SIMLOCKS NOT DETECTED
RESTORATION FILE PRESENT FOR DETECTED FIRMWARE
Elapsed:3 secs.
phone was converted to cid 51 sir...
addictz 02-08-2008 07:51
i wrote script 2 times and phone was converted to cid 52..
thnx u guys...
papoo 02-14-2008 23:18
Thanks Man
Thanks Man
Thanks Man
octavyus 02-15-2008 00:15
cross CID ........... very easy
your solution is very easy, you can make change CID with two methods
Best Regard
aly2ko3 02-15-2008 00:21
use xs++ heres the link http://rapidshare.com/files/83734607..._unlocking.rar
Page generated in 0.20045 seconds with 5 queries
