05-18-2009, 00:01 | #1 (permalink) |
Junior Member Join Date: Feb 2009
Member: 977020 Status: Offline Thanks Meter: 3 | Please can anyone explain how to change cid 53 to 52 with Setool? I want to start work more with setool and need to start to learn from here. Maybe posted many times but i have tried to search without result. Thank you in advance! Br GSM_MANIAC |
05-18-2009, 00:08 | #2 (permalink) |
Freak Poster Join Date: Oct 2008 Location: Behind every bricked phone Age: 37
Member: 884199 Status: Offline Thanks Meter: 65 | As a junior member this would require you do test point on the phone. This process is not for beginners. As all newer phone are CID53 I suggest you learn with this version. |
05-18-2009, 00:20 | #3 (permalink) | |
Banned Join Date: Mar 2009 Location: Proud to be a GUARER
Member: 996201 Status: Offline Thanks Meter: 315 | Quote:
here is a good setool2g working tool. http://www.mediafire.com/file/ymdtygnozdn/Setool | |
05-18-2009, 00:32 | #4 (permalink) | ||
12-30-2009, 16:39 | #6 (permalink) |
No Life Poster Join Date: Jun 2006
Member: 289307 Status: Offline Thanks Meter: 44 | v0.915057/UNI CARD SERIAL: xxxxxxx Loaded 51 flash descriptors CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 FLASH ID:897E OTP: LOCKED:1 CID:51 PAF:1 IMEI:35160003383624 CERT:N/A FLASH CID:53 COLOR:RED can't get packet start. packet not acknowledged (17) setGDFS_params failed failed to setup GDFS |
12-30-2009, 17:38 | #7 (permalink) | |
Freak Poster Join Date: Dec 2006
Member: 417512 Status: Offline Thanks Meter: 46 | Quote:
GDFS corrupt you need to repair, no need testpoint, only credits. Code: q: how i can repair any software problem in db200x/db201x,db2020 phone ? phone totally damaged, identify not working, gdfs is corrupted, erom is absent, etc. a: that feature require release >= v0.915043. 1. make sure you have needed quantity of credits on your account 2. select proper model 3. on settings check only "signed mode (using server)" 4. if phone db200x,db201x select COM/UFS as interface. if phone is db2020 - you can select COM/UFS/USB as interface. if phone is db2020 and USB interface selected - you MUST boot phone in bootrom mode (hold "2+5" while inserting cable) 5. press "recovery". 6. if phone hardware okay (flash chip,ram,etc) - phone will be reset to developer status (brown) 7. phone is BROWN now. 8. staying on "emptyboard fill and repair" write correct gdfs_in_ssw format. 9. if flashing went fine, flash db2020 erom with needed CID, still on "emptyboard fill" tab 10. phone now retail and repaired. fullflash phone as usual. | |
01-02-2010, 02:05 | #11 (permalink) |
No Life Poster Join Date: Nov 2007 Location: inside nck
Member: 628112 Status: Offline Sonork: 100.1589052 Thanks Meter: 3,726 | no downgrade cid only if u do repair gdfs by testpoint or by 1 credit,after repair gdfs and erom u can change cid bRo toutou_gsm |
01-02-2010, 03:21 | #13 (permalink) |
Freak Poster Join Date: Mar 2009 Location: jamaica
Member: 1000658 Status: Offline Thanks Meter: 69 | all u will me is 1 setool log and make recovery operation http://forum.gsmhosting.com/vbb/showthread.php?t=822592 |
01-02-2010, 14:35 | #15 (permalink) | |
Freak Poster Join Date: Feb 2007 Location: Inside ARM...
Member: 457435 Status: Offline Thanks Meter: 24 | Quote:
you can post link for this version???setool v915043... or other version work for this method??? i have credits and versions 40,53,56, and 57 for setool... please help me... i need repair z530 gdfs.... tanks... ******.... | |
Good News!!! W200 CID 53 unlock success with setool ;) | mughalG | SETool2 | 27 | 04-02-2012 07:07 |
How to downgrade cid 53 to cid 52?? | songoten28 | DreamBox | 4 | 11-28-2009 14:44 |
How to change CID 49 to another ? | aminnovelty | DreamBox | 2 | 11-02-2009 07:55 |
How change CID 53 to CID52? | dwandy | Sony Ericsson | 6 | 09-29-2008 20:25 |
can anybody help how to change cid 52 to cid 53? | debmobile | Sony Ericsson | 9 | 09-05-2008 13:05 |
