01-20-2010, 14:26 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Professional Mobile Unlocker Age: 41
Member: 617174 Status: Offline Sonork: 100.1622609 Thanks Meter: 579 | Post Here Successfull Flash/Unlock/Repair All SE w995 unlock done few in but Only 1 cradeit in one phone |
The Following 21 Users Say Thank You to vodafoneserver For This Useful Post: |
01-21-2010, 09:36 | #2 (permalink) |
Member: 617174 Status: Offline Sonork: 100.1622609 Thanks Meter: 579 | w595 unlock done few time no cradeit |
The Following 8 Users Say Thank You to vodafoneserver For This Useful Post: |
01-24-2010, 08:09 | #3 (permalink) |
Member: 617174 Status: Offline Sonork: 100.1622609 Thanks Meter: 579 | J105_NAITE Unlock Done . v0.915057/UNI CARD SERIAL: 00134356 Loaded 51 flash descriptors SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:110000000000 ChipID900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,53,1,35681303255608] OTP LOCKED:1 CID:53 PAF:1 IMEI:35681303255608 CERT:RED LDR:2009-07-31 10:42 1207-6250_DB3200_CS_LOADER_ACC_SDRAM_R2A084 LDR:2009-07-31 10:44 1207-6251_DB3200_CS_LOADER_APP_SDRAM_R2A084 GOT CHALLENGE GOT SEED:2614A1EA3580CD713580673E GOT RESPONSE signoff response ok P96 AUTH PASSED DEVICE KEYF6987409CC743470980039B2F886DB3 (0) RESTARTING... ChipID900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,53,1,35681303255608] OTP LOCKED:1 CID:53 PAF:1 IMEI:35681303255608 CERT:RED LDR:2009-04-21 18:27 1207-6247_DB3200_RESET_LOADER_ACC_SDRAM_R2A081 LDR:2009-04-21 18:28 1207-6248_DB3200_RESET_LOADER_APP_SDRAM_R2A081 GOT CHALLENGE GOT SEED:8B7D5C693580CD713580673E GOT RESPONSE signoff response ok P96 AUTH PASSED RESETTING SECURITY TO FACTORY STATE... RESTARTING... ChipID900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,53,1,35681303255608] OTP LOCKED:1 CID:53 PAF:1 IMEI:35681303255608 CERT:BROWN LDR:2009-07-31 10:49 1207-6245_DB3200_PRODUCTION_LOADER_ACC_SDRAM_R2A084 LDR:2009-07-31 10:50 1207-6246_DB3200_PRODUCTION_LOADER_APP_SDRAM_R2A084 WRITING SEMCBOOT... PREPARING SECURITY... WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "53603740" CHANGING DOMAIN TO "CURRENT" SIGNING... DEVICE KEY RESTORED Unlock FINISHED Elapsed: 44 secs. |
The Following 10 Users Say Thank You to vodafoneserver For This Useful Post: |
01-26-2010, 13:01 | #5 (permalink) |
Member: 617174 Status: Offline Sonork: 100.1622609 Thanks Meter: 579 | T303 unlock done ........... Elapsed: 19 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110000000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... EROM "R5A038" AID: 0001 SOFTWARE AID: 0001 SIMLOCK STATE: "NOT_TAMPERED" LOADER AID: 0002 FLASH ID: "0089/8904" LOADER VERSION: "R3A011" PHONE IMEI:35984302340801 GOT SEED:FE10FEED8B01E040C2007772 P96 AUTH PASSED Searching... SIMLOCK CHECK FOUND Writing... Unlock DONE |
The Following 5 Users Say Thank You to vodafoneserver For This Useful Post: |
01-30-2010, 06:46 | #6 (permalink) |
Member: 617174 Status: Offline Sonork: 100.1622609 Thanks Meter: 579 | W302 unlock done ...... v0.915057/UNI SIGNED MODE (USING SERVER) CFG:100000000000 SERVER CREDITS LEFT/USED: 11/19 CARD COUNTERS: FLASH 59, UNLOCK 15 Elapsed: 3 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110000000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... EROM "R7A021" AID: 0001 SOFTWARE AID: 0001 SIMLOCK STATE: "NOT_TAMPERED" LOADER AID: 0002 FLASH ID: "00EC/220C" LOADER VERSION: "R3A011" PHONE IMEI:35653502640038 GOT SEED:FD529967830100132F0326F2 P96 AUTH PASSED Searching... SIMLOCK CHECK FOUND Writing... Unlock DONE Elapsed: 54 secs. |
The Following 6 Users Say Thank You to vodafoneserver For This Useful Post: |
01-31-2010, 06:53 | #7 (permalink) |
Member: 617174 Status: Offline Sonork: 100.1622609 Thanks Meter: 579 | S312 Unlock Done ............... SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110000000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... EROM "R7A024" AID: 0001 SOFTWARE AID: 0001 SIMLOCK STATE: "NOT_TAMPERED" LOADER AID: 0002 FLASH ID: "0001/307E" LOADER VERSION: "R3A011" PHONE IMEI:35427003478785 GOT SEED:3E21FD7883010007268C08E6 P96 AUTH PASSED Searching... SIMLOCK CHECK FOUND Writing... Unlock DONE Elapsed: 47 secs. |
The Following 4 Users Say Thank You to vodafoneserver For This Useful Post: |
01-31-2010, 09:49 | #8 (permalink) |
Member: 617174 Status: Offline Sonork: 100.1622609 Thanks Meter: 579 | SEMCA2 J105_NAITE Unlock Done ...1 Cerdits SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:110000000000 ChipID900,EMP protocol:0401 PHONE STATE: "RETAIL" FLASH CID: 0053 OTP LOCKED:1 CID:53 PAF:1 IMEI:35681303167619 CERT:RED PLEASE CONNECT PHONE IN "BOOTROM" MODE Elapsed: 77 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:110000000000 ChipID900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,53,1,35681303167619] OTP LOCKED:1 CID:53 PAF:1 IMEI:35681303167619 CERT:RED LDR:2009-07-31 10:42 1207-6250_DB3200_CS_LOADER_ACC_SDRAM_R2A084 LDR:2009-07-31 10:44 1207-6251_DB3200_CS_LOADER_APP_SDRAM_R2A084 server step1 error:No server found. Elapsed: 35 secs. SIGNED MODE (USING SERVER) CFG:110000000000 SERVER CREDITS LEFT/USED: 9/21 CARD COUNTERS: FLASH 63, UNLOCK 15 Elapsed: 3 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:110000000000 ChipID900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,53,1,35681303167619] OTP LOCKED:1 CID:53 PAF:1 IMEI:35681303167619 CERT:RED LDR:2009-07-31 10:42 1207-6250_DB3200_CS_LOADER_ACC_SDRAM_R2A084 LDR:2009-07-31 10:44 1207-6251_DB3200_CS_LOADER_APP_SDRAM_R2A084 GOT CHALLENGE GOT SEED:A46FDE393580CD713530EC28 GOT RESPONSE signoff response ok P96 AUTH PASSED DEVICE KEY:94F80220C4044DD3B330237C3648B84C (1) RESTARTING... ChipID900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,53,1,35681303167619] OTP LOCKED:1 CID:53 PAF:1 IMEI:35681303167619 CERT:RED LDR:2009-04-21 18:27 1207-6247_DB3200_RESET_LOADER_ACC_SDRAM_R2A081 LDR:2009-04-21 18:28 1207-6248_DB3200_RESET_LOADER_APP_SDRAM_R2A081 GOT CHALLENGE GOT SEED:6D7CDB0E3580CD713530EC28 GOT RESPONSE signoff response ok P96 AUTH PASSED RESETTING SECURITY TO FACTORY STATE... RESTARTING... ChipID900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,53,1,35681303167619] OTP LOCKED:1 CID:53 PAF:1 IMEI:35681303167619 CERT:BROWN LDR:2009-07-31 10:49 1207-6245_DB3200_PRODUCTION_LOADER_ACC_SDRAM_R2A084 LDR:2009-07-31 10:50 1207-6246_DB3200_PRODUCTION_LOADER_APP_SDRAM_R2A084 WRITING SEMCBOOT... PREPARING SECURITY... WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "86028804" CHANGING DOMAIN TO "CURRENT" SIGNING... DEVICE KEY RESTORED Unlock FINISHED Elapsed: 41 secs. |
01-31-2010, 11:04 | #9 (permalink) |
No Life Poster Join Date: Jan 2010 Location: Bangladesh Age: 34
Member: 1217931 Status: Offline Sonork: 100.1604251 Thanks Meter: 267 | W395 UNLOCK DONE SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110000000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... EROM "R7A024" AID: 0001 SOFTWARE AID: 0001 SIMLOCK STATE: "NOT_TAMPERED" LOADER AID: 0002 FLASH ID: "00EC/220C" LOADER VERSION: "R3A011" PHONE IMEI:35790603783693 GOT SEED:EA0094A18201D023268C2C5E P96 AUTH PASSED Searching... SIMLOCK CHECK FOUND Writing... Unlock DONE Elapsed: 44 secs. |
The Following 3 Users Say Thank You to md_amin For This Useful Post: |
02-02-2010, 14:43 | #10 (permalink) |
Member: 617174 Status: Offline Sonork: 100.1622609 Thanks Meter: 579 | C510 Unlock done............free..... C510 v0.915057/UNI CARD SERIAL: 00134356 Loaded 51 flash descriptors SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:110000000000 ChipID:C802,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,52,1,35893601546061] OTP LOCKED:1 CID:52 PAF:1 IMEI:35893601546061 CERT:RED LDR:2009-06-26 15:53 CXC1250778_DB31XX_PRODUCTION_LOADER_APP_SDRAM_R2A0 82 DEVICE KEY:517C6AC541005E12D9EC0EA4FED96E8E (0) LDR:2009-04-21 18:17 CXC1250781_DB31XX_RESET_LOADER_ACC_SDRAM_R2A081 LDR:2009-04-21 18:18 CXC1250782_DB31XX_RESET_LOADER_APP_SDRAM_R2A081 GOT SEED:792C1CD83480187A15D05085 P96 AUTH PASSED RESETTING SECURITY TO FACTORY STATE... RESTARTING... ChipID:C802,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,52,1,35893601546061] OTP LOCKED:1 CID:52 PAF:1 IMEI:35893601546061 CERT:BROWN LDR:2009-06-26 15:52 CXC1250777_DB31XX_PRODUCTION_LOADER_ACC_SDRAM_R2A0 82 LDR:2009-06-26 15:53 CXC1250778_DB31XX_PRODUCTION_LOADER_APP_SDRAM_R2A0 82 WRITING SEMCBOOT... PREPARING SECURITY... WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "37744363" CHANGING DOMAIN TO "CURRENT" SIGNING... DEVICE KEY RESTORED Unlock FINISHED Elapsed: 30 secs. |
The Following 3 Users Say Thank You to vodafoneserver For This Useful Post: |
02-02-2010, 14:44 | #11 (permalink) |
Member: 617174 Status: Offline Sonork: 100.1622609 Thanks Meter: 579 | C902 Unlock done ......free....... v0.915057/UNI CARD SERIAL: 00134356 Loaded 51 flash descriptors SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:110000000000 ChipID:C900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,52,1,35362603776810] OTP LOCKED:1 CID:52 PAF:1 IMEI:35362603776810 CERT:RED LDR:2009-06-26 15:53 CXC1250778_DB31XX_PRODUCTION_LOADER_APP_SDRAM_R2A0 82 DEVICE KEY:23A764B9FCE7F84080D7D0AEBCD1E165 (0) LDR:2009-04-21 18:17 CXC1250781_DB31XX_RESET_LOADER_ACC_SDRAM_R2A081 LDR:2009-04-21 18:18 CXC1250782_DB31XX_RESET_LOADER_APP_SDRAM_R2A081 GOT SEED:C5E0622534805A6535A0A6BD P96 AUTH PASSED RESETTING SECURITY TO FACTORY STATE... RESTARTING... ChipID:C900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,52,1,35362603776810] OTP LOCKED:1 CID:52 PAF:1 IMEI:35362603776810 CERT:BROWN LDR:2009-06-26 15:52 CXC1250777_DB31XX_PRODUCTION_LOADER_ACC_SDRAM_R2A0 82 LDR:2009-06-26 15:53 CXC1250778_DB31XX_PRODUCTION_LOADER_APP_SDRAM_R2A0 82 WRITING SEMCBOOT... PREPARING SECURITY... WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "23368865" CHANGING DOMAIN TO "CURRENT" SIGNING... DEVICE KEY RESTORED Unlock FINISHED Elapsed: 31 secs. |
02-02-2010, 14:44 | #12 (permalink) |
Member: 617174 Status: Offline Sonork: 100.1622609 Thanks Meter: 579 | W205 Unlock Done 1 Credits........ SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110000000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... EROM "R5A038" AID: 0001 SOFTWARE AID: 0001 SIMLOCK STATE: "NOT_TAMPERED" LOADER AID: 0002 FLASH ID: "0089/8904" LOADER VERSION: "R3A011" PHONE IMEI:35783803480869 GOT SEED:F74FE5AF88016034C2008620 P96 AUTH PASSED Searching... SIMLOCK CHECK FOUND Writing... Unlock DONE Elapsed: 40 secs. |
02-03-2010, 09:33 | #13 (permalink) |
Member: 617174 Status: Offline Sonork: 100.1622609 Thanks Meter: 579 | T280 Unlock Done ......free... v0.915057/UNI CARD SERIAL: 00134356 Loaded 51 flash descriptors CFG:000000000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... ROM version: 0502 Locosto HS detected, booting... FLASH ID: 0089/8904 (00040000) SECURITY AREA BACKUP CREATED. PHONE IMEI:35342202428266 USERLOCK RESET TO "0000" TOTAL CALL TIME RESET Firmware lock check determined. SIMLOCK PATCH EXECUTED Updating TA... Elapsed: 76 secs. |
02-06-2010, 07:04 | #14 (permalink) |
Member: 617174 Status: Offline Sonork: 100.1622609 Thanks Meter: 579 | W395 Unlock Done 1 Credits............. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110000000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... EROM "R7A024" AID: 0001 SOFTWARE AID: 0001 SIMLOCK STATE: "NOT_TAMPERED" LOADER AID: 0002 FLASH ID: "00EC/220C" LOADER VERSION: "R3A011" PHONE IMEI:35236203690915 GOT SEED:F68553B88001E01B267F5FC1 P96 AUTH PASSED Searching... SIMLOCK CHECK FOUND Writing... Unlock DONE Elapsed: 47 secs. |
The Following 2 Users Say Thank You to vodafoneserver For This Useful Post: |
02-06-2010, 07:49 | #15 (permalink) |
Member: 617174 Status: Offline Sonork: 100.1622609 Thanks Meter: 579 | T280 Unlock Done free........... v0.915057/UNI CARD SERIAL: 00134356 Loaded 51 flash descriptors CFG:000000000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... ROM version: 0502 Locosto HS detected, booting... FLASH ID: 0089/8904 (00040000) SECURITY AREA BACKUP CREATED. PHONE IMEI:35341102592609 USERLOCK RESET TO "0000" TOTAL CALL TIME RESET Firmware lock check determined. SIMLOCK PATCH EXECUTED Updating TA... Elapsed: 69 secs. |
Post Here Sucessfully Flashing / Unlocking / Version 1.09 | Chennairam | Fast Dongle Solution | 8 | 01-24-2010 06:38 |
.:: POST Here Successfull Unlock :. | DaWizard | UST Pro II | 2 | 06-19-2009 18:27 |
Post here successfull unlocked by 103 and thanx to zulea | zahid_gsm | Nokia Base Band 5 ( BB-5 ) | 4 | 04-01-2009 19:10 |
Post Here successfull Unlock [SL_2] | The_Dj | Trash | 0 | 03-10-2009 00:26 |
