r300 imei damage how to repair RUNNING v 1.01/UNI CARD SERIAL 00145166 PLEASE UPGRADE USBFLASH DRIVER 02.02.00.00 SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110100100100 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... PROCEDURE WAS STOPPED BY USER supported phone was not detected FAILED TO SETUP PHONE Elapsed: 417 secs. SIGNED MODE (USING SERVER) CFG:100100100100 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... PROCEDURE WAS STOPPED BY USER supported phone was not detected Can't load ID loader ! Elapsed: 13 secs. SIGNED MODE (USING SERVER) CFG:100100100100 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... PROCEDURE WAS STOPPED BY USER supported phone was not detected Can't load ID loader ! Elapsed: 14 secs. CFG:000100100100 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... ROM version: 0502 Locosto HS detected, booting... FLASH ID: 0089/8904 (00040000) Can't get IMEI PHONE IMEI:DAMAGED Elapsed: 29 secs. CFG:000100100100 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... ROM version: 0502 Locosto HS detected, booting... FLASH ID: 0089/8904 (00040000) Can't get IMEI PHONE IMEI:DAMAGED writing "F:\setool flashfile\se\R300\R2BA005_LEI_ENTRY08_PHILIPPINE_1 209_4568_BROWN.software" block not confirmed error while flashing "F:\setool flashfile\se\R300\R2BA005_LEI_ENTRY08_PHILIPPINE_1 209_4568_BROWN.software" Elapsed: 52 secs. ALTERNATIVE SECURITY BYPASS DISABLED ! ENABLE "SIGNED MODE" CFG:010100100100 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... ROM version: 0502 Locosto HS detected, booting... FLASH ID: 0089/8904 (00040000) Can't get IMEI PHONE IMEI:DAMAGED writing "F:\setool flashfile\se\R300\R2BA005_LEI_ENTRY08_PHILIPPINE_1 209_4568_BROWN.software" block not confirmed error while flashing "F:\setool flashfile\se\R300\R2BA005_LEI_ENTRY08_PHILIPPINE_1 209_4568_BROWN.software" Elapsed: 62 secs. SIGNED MODE (USING SERVER) CFG:100100100100 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... PROCEDURE WAS STOPPED BY USER supported phone was not detected FAILED TO SETUP PHONE Elapsed: 25 secs. CFG:000100100100 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... ROM version: 0502 Locosto HS detected, booting... FLASH ID: 0089/8904 (00040000) Can't get IMEI PHONE IMEI:DAMAGED CAN'T FIND SIMLOCK CHECK SIMLOCK PATCH FAILED,MAYBE ALREADY PATCHED Updating TA... refusing to write empty TA Can't update TA ! FAILED ! Elapsed: 38 secs. CFG:000000000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... ROM version: 0502 Locosto HS detected, booting... FLASH ID: 0089/8904 (00040000) Can't get IMEI PHONE IMEI:DAMAGED writing "C:\setool v101\eroms\S1\R300_R306_T303_S1_LOCOSTO_HS_R5A031_ 128.SIN" Elapsed: 38 secs. CFG:000000000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... ROM version: 0502 Locosto HS detected, booting... FLASH ID: 0089/8904 (00040000) Can't get IMEI PHONE IMEI:DAMAGED Elapsed: 27 secs. CFG:000000000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... ROM version: 0502 Locosto HS detected, booting... FLASH ID: 0089/8904 (00040000) Can't get IMEI PHONE IMEI:DAMAGED writing "C:\setool v101\gdfs_in_ssw_format\S1\R300_TA.SSW" block not confirmed error while flashing "C:\setool v101\gdfs_in_ssw_format\S1\R300_TA.SSW" Elapsed: 49 secs. CFG:000000000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... ROM version: 0502 Locosto HS detected, booting... FLASH ID: 0089/8904 (00040000) Can't get IMEI PHONE IMEI:DAMAGED Elapsed: 33 secs. CFG:000000000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... ROM version: 0502 Locosto HS detected, booting... FLASH ID: 0089/8904 (00040000) Can't get IMEI PHONE IMEI:DAMAGED writing "F:\setool flashfile\se\R300\r300_full_repair.ssw" block not confirmed error while flashing "F:\setool flashfile\se\R300\r300_full_repair.ssw" Elapsed: 51 secs. CFG:000000000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... ROM version: 0502 Locosto HS detected, booting... FLASH ID: 0089/8904 (00040000) Can't get IMEI PHONE IMEI:DAMAGED writing "F:\setool flashfile\se\R300\r300_full_repair.ssw" block not confirmed error while flashing "F:\setool flashfile\se\R300\r300_full_repair.ssw" Elapsed: 67 secs. error in flashing |
anyone know how to fix this? is this still a software or hardware problem?? |
i thinks that is hardware problem |
if not help then its hardware flash IC , power IC i think thx......... |
