03-29-2010, 13:57 | #1 (permalink) |
Major Poster Join Date: Sep 2007 Location: Salvador-BA
Member: 591385 Status: Offline Thanks Meter: 25 | Repair GDFS V1.01 As we all know the repair GDFS can only be accomplished by using the Test Point or the new version using the Log! This tutorial will show how to make the same without Test Point or even log a User on the server. BeSegundo step is to perform the Recovery. Check the option Use Server. Clicking recovey. Wait until the end. Upon conclusion recovey will be an automatic downgrade is possible to work with the GDFS of that! Then depart for tab Empty Fill & Repair and this area will do the repair.
Notice that I emphasized the format of the GDFS that is in SSW. Do not forget that the entire procedure is necessary to rewrite the original imei. Wait until the end ... Concluding that item will return to the CID, which will be your preference, CID51, 52 or 53. This will be done with the writing of Erom which is also located in the SeTool3. Same procedure above.
Completing this procedure read the information of the device. When reading it and having this same image with everything right just apply a firmware and DONE. Log of the same successful repair By Michael Carvalho™ |
The Following 24 Users Say Thank You to MaikonPhone For This Useful Post: |
04-27-2010, 14:44 | #8 (permalink) | ||
Member: 591385 Status: Offline Thanks Meter: 25 | Quote:
Yes! | ||
Which version Repair GDFS FREEEEE | vistasamir | SETool2 | 6 | 03-29-2010 22:14 |
v1.01 gdfs write | bowei | SETool2 | 1 | 03-23-2010 03:40 |
k800 IMEI MISMATCH ! GDFS solved by v1.01 setool | charletan | SETool2 | 8 | 03-14-2010 13:20 |
..:: 29/07/2008 - New Release - Cruiser Suite GDFS Backuper & Restorer v1.01 ::.. | Mizar | Cruiser Suite | 42 | 10-12-2008 23:17 |
..:: Cruiser DB2020 GDFS Reader v1.01 ::.. | Mainboard | Cruiser Suite | 82 | 06-02-2008 21:52 |
