05-31-2008, 08:18 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: England
Member: 575900 Status: Offline Thanks Meter: 3,177 | REPAIRING EROM GUIDES for most sonyericsson phones your erom only really needs repairing if it's dead or damaged, a sign of a dead erom is normally a blinking red led in the infra red port. Do NOT Flash different EROM Phone Model to your phone, You need to use same CID in EROM as your phone EROM CID. example:You can NOT flash K800 CID51 EROM to a K800 CID49 Phone.You can flash K800 CID49 EROM to a K800 CID49 Phone Verify which is your EROM's version, it will be in xs++ logs or setool logs, or connect to xs++ and it will tell you look for this EROM CID: . xs++3.1 guide needed files xs++3.1, 4shared.com - online file sharing and storage - download XS++.rar usb flash drivers for dcu-60 cable, 4shared.com - online file sharing and storage - download gg-setup.exe cruiser drivers, http://www.4shared.com/file/27294476/b8e97...ble_driver.html eroms, WOTANSERVER guide needed files wotan , http://www.4shared.com/file/32041706/e9fae...otanClient.html usb flash drivers for dcu-60 cable 4shared.com - online file sharing and storage - download gg-setup.exe SETOOL 2 LITE 1.10 guide needed files setool 2 lite 1.10, http://www.4shared.com/file/33508971/4c73bb89/setool2lite.html"]http://www.4shared.com/file/33508971/4c73bb89/setool2lite.html drivers , when you extract setool there will be a folder called drivers all drivers are in there far+sepf guide needed files db2010, cid:36 erom, http://www.4shared.com/file/32126040/b8718...0_00020000.html farmanager 1.07, http://www.4shared.com/file/27136179/48b00...Manager170.html sepf 10.0.44, http://www.4shared.com/file/27135996/5a2ac...SEFP010044.html sepf 10.0.51, http://www.4shared.com/file/27555816/87e09...SEFP_01051.html usb flash drivers for dcu-60 cable, 4shared.com - online file sharing and storage - download gg-setup.exe Gflash guide needed files usb flash drivers for dcu-60 cable, 4shared.com - online file sharing and storage - download gg-setup.exe gflash 206, http://www.4shared.com/file/32043297/e3fd6...GFlash20b6.html SEKING guide needed files SEKING, http://www.4shared.com/file/32042512/e6bd6...53_English.html usb flash drivers for dcu-60 cable, 4shared.com - online file sharing and storage - download gg-setup.exe kulankendi guide needed files kulankendi, ..:: www.kulankendi.com ::.. usb flash drivers for dcu-60 cable 4shared.com - online file sharing and storage - download gg-setup.exe |
The Following 4 Users Say Thank You to NADEEM GONDAL For This Useful Post: |
05-31-2008, 08:19 | #2 (permalink) |
Member: 575900 Status: Offline Thanks Meter: 3,177 | REPAIRING EROM GUIDES for most sonyericsson phones PART 2 xs++3.1 erom repair guide, works with dcu-60, cruiser, works with db2010 cid 36, cid 49, db2012 cid 50 cid 51 cid52, db2020 cid 49 cid 51 cid 52 step A selecting the correct erom, the erom must be in a .bin format. a.Turn off the phone, remove the battery, sim and memory card, b.run xs++.exe and press connect, if your using a cruiser cable you must select the correct com port from the drop down select port box. c.now reinsurt your battery and connect the phone holding down C. d.you are now connected to xs++. e. , i have highlighted what needs to match when choosing your new erom. Platform: <<<some erom files don't contain this information, but longs u match up the rest of the information it will be fine. EROM CID: <<< very important must match your erom file 100% Don't confuse with the OTP CID. EROM Color: <<< most eroms and phones are red Phone ID: <<< very important must match your erom file 100% STEP B flashing the erom 1.Turn off the phone, remove the battery, sim and memory card, 2.run xs++.exe and press connect, if your using a cruiser cable you must select the correct com port from the drop down select port box. 3.now reinsurt your battery and connect the phone holding down C. 4.you are now connected to xs++. 5.Select your EROM's file in .bin format with the box Flash Main Firmware like this 6.press FLASH. WOTANSERVER, erom repair guide, dcu-60 db2020 phones only a.Turn off the phone, remove the battery, sim and memory card, 1.download wotan 2.run wotan.exe 3.erase all log-in information 4.Press start button 5.Insert the battery then connect the phone while holding down 2+5 6.Release the buttons then wotan should update your erom. SETOOL 2 LITE 1.10 erom repair guide dcu-60 or cruiser, supported DB2010/DB2012 CID49/50/51/52, DB2020 CID49/51/52 a.Turn off the phone, remove the battery, sim and memory card, 1.unzip and run setool2 lite 1.10 2.select phone type from phone type drop-down list, 3.press identify 4.reinsurt battery and holding down 2+5 connect the phone 5.press the unlock/repair button far+sepf, dcu-60 or cruiser db2010 cid:36 only can also be used to convert from brown to red. a.download erom_db2010_red36_44000000_00020000.zip and unzip it, b.Turn off the phone, remove the battery, sim and memory card, 1.install farmanager 2.go to programme files/Far/plugins 3.extract sepf 10.0.44 here 4.now extract sepf 10.0.51 in extactly the same place as 10.0.44 5.now run farmanager and press F11 6.select SEFP 0.10.51 FAR should look like 7.select DCU-60 under device,921600 under speed,then ur phone e.g k750_w800_cid:36 8.now press enter the matrix, reinsurt your phones battery and connect your phone holding down C 9.with the right side of far find erom_db2010_red36_44000000_00020000.raw 10.drag and drop it onto the FLASH folder on the left side 11.Select Flash raw image option and check that address is 44000000 and length is 20000 Press Flash 12.Confirm flashing erom by pressing Yes Gflash, dcu-60 db2010 cid:36 only can also be used to convert from brown to red. a.Turn off the phone, remove the battery, sim and memory card, 1.download gflash 2.0 beta6 2.run glash.exe 3.select the Repair/GDFS/Patching tab along the top 4.click flash EROM 5.then press the button and select RED_CID36.EROM 6.press the Repair/Read/Patch button 7.reinsurt the battery and connect your phone holding down C. SEKING, dcu-60/crusier cable a.Turn off the phone, remove the battery, sim and memory card, 1.download seking 2.run seking 3.under port option press com port from crusier cable, and press DCU-60 USB for DCU-60 4.under select option select your phone model from the drop-down box 5.under Operation option select Repair EROM 6.then press identify now reinsurt the battery and connect your phone holding down C 7.now with a tick in the Repair EROM box, press GO. VIDEO guide for SEKING here http://www.4shared.com/file/32126053...r_Up_EROM.html[/B[/url]] kulankendi dcu-60 cable a.Turn off the phone, remove the battery, sim and memory card, [b]1.open kulankendi tick the EROM Update 2.press the Flash Phone button 3.remove then reinsurt the battery & connect the phone holding down C 4.you erom will be updated. |
The Following User Says Thank You to NADEEM GONDAL For This Useful Post: |
05-31-2008, 08:27 | #3 (permalink) |
Freak Poster Join Date: Jul 2007 Location: SOUTH AFRICA GUAR
Member: 553264 Status: Offline Thanks Meter: 594 | Thank you for a very informative post bro. Excellent work, keep it up With your permission, I would like to share your post with some of my associates. Is that ok with you? Regards, Nazty |
06-01-2008, 08:26 | #5 (permalink) |
No Life Poster Join Date: Apr 2007
Member: 485779 Status: Offline Thanks Meter: 135 | NADEEM GONDAL many links not work can u upload it again http://www.4shared.com/file/32126053...r_Up_EROM.html link not work some reload it ..... thanks |
06-01-2008, 09:54 | #6 (permalink) | |
Member: 575900 Status: Offline Thanks Meter: 3,177 | some video here Quote:
06-01-2008, 11:28 | #10 (permalink) |
Member: 575900 Status: Offline Thanks Meter: 3,177 | Pnx5230 PNX5230: Unlock CID51 IMEI Change CID52 free patch unlock (video by beto251172) http://rapidshare.com/files/119272833/pnx5230.rar.html |
06-01-2008, 11:32 | #11 (permalink) |
Member: 575900 Status: Offline Thanks Meter: 3,177 | Smartphones Smartphones Old Security: Flash Unlock New Security: Unlock http://rapidshare.com/files/11927366...tfone.rar.html |
::.:: Free REPAIRING EROM GUIDES for most sonyericsson phones ::.:: | ::.::RAMJAN::.:: | Sony Ericsson | 97 | 09-10-2011 13:25 |
Hardware solution guide for china mobile phones. | hmyeamin | Chinese Models & Cloned Phones | 0 | 01-25-2010 07:56 |
27.09.2008 - DB2020 inside v5.3 : Added repair boot support for J110/J120 phones | bestncheap | Service Products News & Updates | 0 | 09-27-2008 12:54 |
For all you EROM searchers.. All/most SE models | brokencobba | HWK | 2 | 02-05-2006 04:58 |
Free logs for Unlocking SonyEricsson phones with R6C005 Firmware! | maxxnskk | Phone Unlocking Codes & Maps | 26 | 08-21-2004 16:19 |
