Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SETool2
Old 09-05-2008, 17:51   #1 (permalink)
ikram tabassum1's Avatar
Member: 681574
Sonork: 100.1614243
Thanks Meter: 138
k530
After Flashing And Unlocking K530 No Net Work ????????????
Old 09-05-2008, 18:23   #2 (permalink)
Member: 470292
Thanks Meter: 147
Post full log. We can only see your operation and problem by log....
Old 09-05-2008, 19:20   #3 (permalink)
NADEEM GONDAL's Avatar
Member: 575900
Thanks Meter: 3,177
Solution:You'll have to rewrite the original GDFS. Sadly, most users never back it up before proceeding with whatever operation they intended to do in the first place. This is done through the "Read GDFS" button in SETool, btw . it will produce a .bin-file named with the phones IMEI and can be found in your SETool basedir. Take good care of it.
Old 09-05-2008, 19:28   #4 (permalink)
Member: 681574
Sonork: 100.1614243
Thanks Meter: 138
SIGNED MODE (USING SERVER).
ALTERNATIVE SECURITY BYPASS ENABLED.
PRELOADER SECURITY BYPASS ENABLED.
ChipID:9900,EMP protocol:0301
PHONE IS RED RETAIL PRODUCT
FLASH CID detected:52
Speed:921600
OTP LOCKED:1 CID:51 PAF:1 IMEI:35780401749267 CERT:RED
FLASH CID:52 COLOR:RED
PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0
LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005
Flash ID check:2019
Flash props sent ok
LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013
loader startup: executed
loader GDFS startup: executed
loader filesystem startup: executed
loader unlock: executed
DISCONNECT PHONE NOW
INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN
BE SURE THAT YOU SET PHONE IN "PHONE MODE"
IF ASKED, INSTALL PHONE DRIVERS
SEARCHING FOR PHONE, "STOP" TO ABORT
PHONE FOUND AT COM26
PHONE READY TO PROCEED
EXECUTOR STARTED
REMOVE CABLE FROM PHONE
REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK
THEN PRESS "READY"
Speed:921600
Trying to launch embedded bootloader...
INT LDRB2020_PRELOADER_FOR_SETOOL2
Flash ID check:2019
Flash props sent ok
FOUND: R6BC002_CXC1250912_GENERIC_NC
Restore from:R6BC002_CXC1250912_GENERIC_NC
writing F:\download files\SONYERICSSON\k530\cid 52\R6BC002_1250912_GENERIC_NC.ssw
CURRENT FLASH FILE CID:52
SSW uses complete hash, hash len is:9200
Will flash 460 blocks...
SSW loading returns:0
writing F:\download files\SONYERICSSON\k530\cid 52\R6BC002_FS_APAC_NC_RED_CID52.ssw
SSW uses complete hash, hash len is:3620
Will flash 181 blocks...
full sig complete.
USERCODE RESET TO "0000"
Searching...
Firmware SIMLOCK check determined.
LDR:060426 1726 HANCXC1329133_DB2020_FILESYSTEMLOADER_P5G
writing tpa/preset/custom/C3_PCA_G3v2.cer
writing tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm
writing tpa/preset/custom/customize.xml
writing tpa/preset/custom/DESKTOP_HOOK_2.itm
writing tpa/preset/custom/Entrust.net Root Certificate.cer
writing tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt
writing tpa/preset/custom/FM_PICTURES_HOOK_3.itm
writing tpa/preset/custom/FM_SOUNDS_HOOK_3.itm
writing tpa/preset/custom/FM_THEMES_HOOK_3.itm
writing tpa/preset/custom/FM_VIDEOS_HOOK_3.itm
writing tpa/preset/custom/GAMES_HOOK_3.itm
writing tpa/preset/custom/GTE_CyberTrust_Root.cer
writing tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt
writing tpa/preset/custom/Root.cer
writing tpa/preset/custom/SEMC_E2E_Root_CA.crt
writing tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm
writing tpa/preset/custom/ThawtePremium.der
writing tpa/preset/custom/ThawteServerCA.cer
writing tpa/preset/custom/Utiroot.cer
writing tpa/preset/custom/VeriSignClass3Root.cer
writing tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt
Phone detached
Elapsed: 498 secs.
K530 cid 52 unlock works 100% - tested Rezn Universalbox 10 10-13-2007 11:40
when k530 will be supported? Rezn Universalbox 6 10-10-2007 14:53
Is K530 supported? James_S Universalbox 7 09-10-2007 16:39
WotanServer: T650 K530 K818 and W810 K510 K310 CID50 support WotanServer.com WotanServer 0 08-07-2007 18:07
EMEA2 for Z300 and K530 Glavca1 Sony Ericsson 1 10-13-2006 07:09
Page generated in 0.17199 seconds with 9 queries
