05-20-2008, 12:58 | #7 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Capetown
Member: 91045 Status: Offline Thanks Meter: 8,696 | Unlock process for this is same as other new altbypass like db2020 db2012..pnx5230 standalone from v33 now K320 Cid50 u can use cross cid flashing...that needs one log |
05-20-2008, 13:43 | #8 (permalink) |
Member: 91045 Status: Offline Thanks Meter: 8,696 | only one change in order to enable NEW (STANDALONE) alternative security bypass, you MUST check ALSO "enable preloader security bypass". otherwise server-based security bypass will be used. |
05-21-2008, 22:54 | #9 (permalink) |
Freak Poster Join Date: Feb 2008
Member: 714778 Status: Offline Thanks Meter: 13 | plz help me .. I have implemented all steps in order to Unlock My K320 CID 50 by using latest V33 of Setool ,but Unlock Failed .. here is it Log SIGNED MODE (USING SERVER). ChipID:8040,EMP protocol:0301 NEW SECURITY MODEL DETECTED PHONE IS RED RETAIL PRODUCT FLASH CID detected:50 Speed:921600 Flash ID check:897E Flash props sent ok OTP LOCKED:1 CID:50 PAF:1 IMEI:35670601066638 CERT:RED FLASH CID:50 COLOR:RED Model:K320i Brand:TMN MAPP CXC article: R4EA031 prgCXC1250682_GENERIC_MA MAPP CXC version: R4EA031 Language Package:EUROPE_1 CDA article: CDA102728/71 CDA version: R3A Default article: cxc1250690 Default version: R4EA031 PROVIDER: 268-06 Network LOCKED USERCODE:0000 RESTORATION FILE PRESENT FOR DETECTED FIRMWARE Elapsed: 11 secs. SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. PRELOADER SECURITY BYPASS ENABLED. ChipID:8040,EMP protocol:0301 NEW SECURITY MODEL DETECTED PHONE IS RED RETAIL PRODUCT FLASH CID detected:50 Speed:921600 OTP LOCKED:1 CID:50 PAF:1 IMEI:35670601066638 CERT:RED LDR:060712 1520 HAN_DB2012_FLASHLOADER_R1A002_CXC1250695 Flash ID check:897E Flash props sent ok LDR:070410 1405 HANCXC1327364_COMPACT_SEMC_CS_LOADER_1_R3B009 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN BE SURE THAT YOU SET PHONE IN "PHONE MODE" IF ASKED, INSTALL PHONE DRIVERS SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM71 PHONE READY TO PROCEED EXECUTOR STARTED REMOVE CABLE FROM PHONE REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" ChipID:8040,EMP protocol:0301 NEW SECURITY MODEL DETECTED PHONE IS RED RETAIL PRODUCT FLASH CID detected:50 Speed:921600 Trying to launch embedded bootloader... INT LDR:COMPACT_ID_LOADER_CRIPPLED_SETOOL2_R2 Flash ID check:897E Flash props sent ok FOUND: R4EA031_CXC1250682_GENERIC_MA Restore from:R4EA031_CXC1250682_GENERIC_MA Searching... Can't find SIMLOCK check Unlock FAILED Elapsed: 172 secs. |
HOW TO UNLOCK K320 ,Z310 and W200 CID 50,CID 51,CID52 | Eagle7 | SETool2 | 56 | 03-31-2011 22:27 |
Sucsses flash k320 cid 51 | DJ sutanto | SETool2 | 2 | 02-03-2010 01:54 |
Video to inlock cid 49, cid 50, cid 51, but not cid 52. Where can we find instruction | gsmnice | FuriousGold | 6 | 12-11-2007 22:10 |
can i flash se k618i cid 51 with k610 flash cid 51 | hossam_on_line | Sony Ericsson | 4 | 08-26-2007 16:05 |
K320 CID 51 no flash file.. | burgerhan | MT-BOX | 3 | 07-25-2007 19:14 |
