06-14-2010, 13:46 | #1 (permalink) |
Freak Poster Join Date: Jul 2008 Location: tangub
Member: 823842 Status: Offline Thanks Meter: 33 | K610i red blink help i try to tick recovery, and now the phone totally died even red led blink none.. now i try to identify again the error like below..... RUNNING v 1.01/UNI CARD SERIAL 00133391 CFG:000000000000 PROCEDURE WAS STOPPED BY USER Can't load ID loader ! Elapsed: 48 secs. CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:115200 FLASH ID: 897E OTP: LOCKED:1 CID:49 PAF:1 IMEI:35170901338317 CERT:N/A phoneID error (1) Error during phone id. Elapsed: 19 secs. |
06-14-2010, 15:23 | #6 (permalink) | |
Freak Poster Join Date: Jan 2007 Location: Phillipines
Member: 437090 Status: Offline Thanks Meter: 131 | Quote:
empty refill tab select model settings tab check sign mode back to empty refill tab tick recovery still in empty refill tab load gdfs and erom tick flash check phone if working..if not goto sony ericssons tab and flash main and fs.... br | |
The Following 2 Users Say Thank You to macoy0916 For This Useful Post: |
06-14-2010, 15:41 | #7 (permalink) |
Freak Poster Join Date: Jul 2009 Location: pakistan
Member: 1085109 Status: Offline Sonork: 100.1585163 Thanks Meter: 223 | BROTHER NO NEED CREDIT USE V1.01 VERSION OF SE TOOL ITS 100% FREE FOLLOW THIS LINK AND THEN ALL OK http://forum.gsmhosting.com/vbb/f473...1-01-a-964232/ GOOD LUCK |
The Following User Says Thank You to abdullah sheikh For This Useful Post: |
06-15-2010, 10:00 | #8 (permalink) |
Member: 823842 Status: Offline Thanks Meter: 33 | pLS HELP I TRY TO follow this procedure my problem there is error on flashing in mian and fs empty refill tab select model settings tab check sign mode back to empty refill tab tick recovery still in empty refill tab load gdfs and erom tick flash check phone if working..if not goto sony ericssons tab and flash main and fs.... in flashing gdfs and erom here is the logs SIGNED MODE (USING SERVER) CFG:100000000000 RESET MODE STARTED ChipID:9900,EMP protocol:0301 Speed:115200 RESET:070703 1106 NPACXC1250329_DB2020_CERTRESETLOADER_P3AA FLASH ID: 897E GOT SEED:BE2DA4D42180DD5D15D09852 P96 AUTH PASSED OTP: LOCKED:1 CID:49 PAF:1 IMEI:35170901338317 CERT:N/A PHONE SUCCESSFULLY RESET TO DEVELOPER STATE Elapsed: 10 secs. CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:115200 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35170901338317 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID: 897E writing "D:\se tool file\gdfs_in_ssw_format\db2020\K610_GDFS_SSW.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 640 Will flash 32 blocks... Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "70762201" SIGNING... Elapsed: 217 secs. CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:115200 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35170901338317 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID: 897E writing "D:\se tool file\eroms\db2020\DB2020EROM_BROWN49_BROWN_CID49_D B2020.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 80 Will flash 4 blocks... Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "50831286" SIGNING... Elapsed: 44 secs. flashing logs pls. error CFG:000000000000 ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:115200 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35170901338317 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID: 897E writing "D:\se tool file\SE Flash Files\K610\R1EJ001_1250374_GENERIC_TH.ssw.cry" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 9100 HDR block not accepted,error: 19 Elapsed: 10 secs. |
06-26-2010, 12:26 | #10 (permalink) |
Member: 823842 Status: Offline Thanks Meter: 33 | thanks to all problem done by this procedure by roney nexus select k610 * mark only SIGN MODE ( 1.01 version already gdfs repair free) * press RECOVERY * connect phone with usb or com port * you get brown 49 k610 after successful RECOVERY * switch to empty board tab * select k610 * add k610_GDFS_SSW.ssw * add DB2020EROM_CNV_RED52_BROWN_CID49_DB2020.ssw * click flash * now u get red 52 k610 * flash with red 52 firmware check on settings signed mode "customize phone after flash" * DONE. |
Winlock 1.10 - Help | rdmfs | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-25-1999 08:21 |
