03-03-2016, 11:40 | #1 (permalink) |
Junior Member Join Date: May 2006 Location: russia
Member: 279194 Status: Offline Thanks Meter: 3 | d855 unlock error OS Version: Windows XP [NT 5.1] Service Pack 3 Administrative privileges: yes Locale: RussianFederation / Russian CPU frequency: 3092 MHz Total memory: 3538 MB Free memory: 2136 MB Free space on system disk C:\: 20.00 GB Free space on disk D:\: 47.00 GB Free space on disk E:\: 32.00 GB Free space on disk F:\: 113.00 GB Free space on disk I:\: 660.00 GB Connecting with D855 Please type 277634#*# and select "SVC menu" -> "Port Check Test" -> "Enabled". Please select MTP in USB Connection Dialog on phone. Connected Receiving phone info Getting phone info Model: D855 Platform: LG Qualcomm Software Platform: Android SDRAM Size: 2 GB NAND Flash Size: 16 GB CPU: MSM8974 Firmware Released: Dec 17 2015 12:52:06 Firmware Compiled: Dec 03 2015 05:00:00 Firmware Version: D855/MPSS.DI.2.0.1.c1.13-00106-M8974AAAAANPZM-1 IMEI: 357513-06-785649-3 Connect mode: Normal Info received Receiving phone info Getting phone info Model: D855 Platform: LG Qualcomm Software Platform: Android SDRAM Size: 2 GB NAND Flash Size: 16 GB CPU: MSM8974 Firmware Released: Dec 17 2015 12:52:06 Firmware Compiled: Dec 03 2015 05:00:00 Firmware Version: D855/MPSS.DI.2.0.1.c1.13-00106-M8974AAAAANPZM-1 IMEI: 357513-06-785649-3 Connect mode: Normal Info received Unlocking phone Unlock: Start Backuping NVM to file: Backups\D855_nvm_357513067856493_2016-3-3_13-4-8.sbf Dump NVM: Start Getting phone info... Getting phone info: OK Switching to NVM mode... Switching to NVM mode: OK Dumping NVM... Dumping NVM: OK Switching to normal mode... Switching to normal mode: OK Dump NVM: Finish Backuping EFS to file: Backups\D855_efs_357513067856493_2016-3-3_13-9-6.sbf Downloading file /nv/item_files/CoreCpu/CoreAll/Startup/Algorithm.txt 12 bytes Downloading file /nv/item_files/CoreCpu/CoreAll/Startup/LogSize.uint 4 bytes Downloading file /nv/item_files/CoreCpu/Default/Fixed/MIPS.uint 4 bytes Downloading file /nv/item_files/CoreCpu/Default/Startup/AVSEnable.uint 4 bytes Downloading file /nv/item_files/CoreCpu/Default/Startup/Algorithm.txt 8 bytes Downloading file /nv/item_files/CoreCpu/Default/Startup/LogSize.uint 4 bytes Downloading file /nv/item_files/CoreCpu/Default/qdsp_classic/HighThresholdBusyPct.uint 4 bytes Downloading file /nv/item_files/CoreCpu/Default/qdsp_classic/SamplePeriod.uint 4 bytes Downloading file /nv/item_files/conf/cgps_me.conf 1.34 Kb Downloading file /nv/item_files/conf/cgps_pdcomms.conf 212 bytes Downloading file /nv/item_files/conf/cgps_pe.conf 214 bytes Downloading file /nv/item_files/conf/cgps_sm.conf 1020 bytes Downloading file /nv/item_files/conf/cgps_tle_tlm.conf 710 bytes Downloading file /nv/item_files/conf/cgps_tle_xtm.conf 1.17 Kb Downloading file /nv/item_files/conf/data_config_info.conf 3.62 Kb Downloading file /nv/item_files/conf/geran.conf 641 bytes Downloading file /nv/item_files/conf/hdrcp_config_info.conf 465 bytes Downloading file /nv/item_files/conf/hdrmac_config_info.conf 41 bytes Downloading file /nv/item_files/conf/hdrsrch_config_info.conf 418 bytes Downloading file /nv/item_files/conf/ims.conf 2.91 Kb Downloading file /nv/item_files/conf/lte_a2.conf 348 bytes Downloading file /nv/item_files/conf/lte_ml1_ant_switch.conf 45 bytes Downloading file /nv/item_files/conf/lte_ml1_ant_switch_band.conf 50 bytes Downloading file /nv/item_files/conf/lte_rrc.conf 3.69 Kb Downloading file /nv/item_files/conf/mc.conf 644 bytes Downloading file /nv/item_files/conf/mcfg.conf 176 bytes Downloading file /nv/item_files/conf/mcpm.conf 101 bytes Downloading file /nv/item_files/conf/mcs_cxm_coex.conf 40 bytes Downloading file /nv/item_files/conf/mcs_limitsmgr.conf 4.79 Kb Downloading file /nv/item_files/conf/mcs_tcxomgr.conf 502 bytes Downloading file /nv/item_files/conf/mmgsdi.conf 1.40 Kb Downloading file /nv/item_files/conf/mmode.conf 1.53 Kb Downloading file /nv/item_files/conf/nas_mm.conf 1.21 Kb Downloading file /nv/item_files/conf/onex_mux.conf 47 bytes Downloading file /nv/item_files/conf/onex_srch.conf 227 bytes Downloading file /nv/item_files/conf/pbm.conf 238 bytes Downloading file /nv/item_files/conf/ps_config_info.conf 316 bytes Downloading file /nv/item_files/conf/qmi_data.conf 88 bytes Downloading file /nv/item_files/conf/reg.conf 1.13 Kb Downloading file /nv/item_files/conf/rrc_feature.conf 43 bytes Downloading file /nv/item_files/conf/tdscdma_l1.conf 1.42 Kb Downloading file /nv/item_files/conf/tdscdma_rrc.conf 2.00 Kb Downloading file /nv/item_files/conf/thin_ui_config.conf 41 bytes Downloading file /nv/item_files/conf/uimdrv.conf 542 bytes Downloading file /nv/item_files/conf/wcdma_csg_efs_1.conf 3.63 Kb Downloading file /nv/item_files/conf/wcdma_csg_efs_2.conf 3.63 Kb Downloading file /nv/item_files/conf/wcdma_csg_efs_3.conf 3.63 Kb Downloading file /nv/item_files/conf/wcdma_csg_efs_4.conf 3.63 Kb Downloading file /nv/item_files/conf/wcdma_csg_efs_5.conf 3.63 Kb Downloading file /nv/item_files/conf/wcdma_csg_efs_db.conf 54 bytes Downloading file /nv/item_files/conf/wcdma_rrc_external.conf 1003 bytes Downloading file /nv/item_files/conf/wl1_ant_nv.conf 35 bytes Downloading file /nv/item_files/conf/wl1_ant_switch_band_nv.conf 47 bytes Downloading file /nv/item_files/conf/wl1_cme.conf 171 bytes Downloading file /nv/item_files/conf/wl1_dl_nv.conf 37 bytes Downloading file /nv/item_files/conf/wl1_fet.conf 41 bytes Downloading file /nv/item_files/conf/wl1_rxd.conf 995 bytes Downloading file /nv/item_files/conf/wl1ul.conf 43 bytes Downloading file /nv/item_files/conf/wms.conf 410 bytes Downloading file /nv/item_files/gps/cgps/me/gnss_config 4 bytes Downloading file /nv/item_files/mcs/cxm/coex_config_data 2.09 Kb Downloading file /nv/item_files/mcs/lmtsmgr/battery/bcl_gsm2_high_lte_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/battery/bcl_gsm2_high_tdscdma_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/backoff/im_desense_1x_victim_hdr_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/backoff/im_desense_1x_victim_lte_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/backoff/im_desense_gps_victim_1x_lte_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/backoff/im_desense_hdr_victim_1x_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/backoff/im_desense_lte_victim_1x_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/backoff/non_im_desense_1x_victim_lte_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/backoff/non_im_desense_gsm_victim_lte_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/backoff/non_im_desense_gsm_victim_tdscdma_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/1x_victim_gsm_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/disable_sw_mitigation 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm1_victim_gsm2_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm1_victim_gsm3_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm2_victim_gsm1_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm2_victim_gsm3_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm3_victim_gsm1_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm3_victim_gsm2_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm_victim_1x_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm_victim_hdr_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm_victim_tdscdma_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm_victim_wcdma_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/hdr_victim_gsm_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/tdscdma_victim_gsm_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/wcdma_victim_gsm_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_1x_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_1x_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_1x_high_hdr_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_1x_high_lte_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_1x_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_hdr_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_lte_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_tdscdma_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_wcdma_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_1x_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_hdr_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_lte_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_tdscdma_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_wcdma_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_hdr_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_hdr_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_lte_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_lte_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_tdscdma_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_tdscdma_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_wcdma_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_wcdma_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_gpio_settings 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_1x_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_1x_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_1x_high_hdr_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_1x_high_lte_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_1x_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_hdr_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_lte_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_tdscdma_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_wcdma_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_1x_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_hdr_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_lte_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_tdscdma_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_wcdma_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_hdr_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_hdr_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_lte_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_lte_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_tdscdma_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_tdscdma_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_wcdma_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_wcdma_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_qmi_comp_key 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sem/sem_thresh_gsm_1x 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sem/sem_thresh_gsm_hdr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sem/sem_thresh_gsm_tdscdma 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sem/sem_thresh_gsm_wcdma 0 bytes Downloading file /nv/item_files/mcs/tcxomgr/ft_table 768 bytes Downloading file /nv/item_files/modem/lte/rrc/cap/diff_fdd_tdd_fgi_enable 1 bytes Downloading file /nv/item_files/modem/lte/rrc/cap/disable_r9_redirection 1 bytes Downloading file /nv/item_files/modem/lte/rrc/csp/sec_inactive_rlf_recovery 1 bytes Downloading file /nv/item_files/modem/lte/rrc/lte_tdd_prune 1 bytes Downloading file /nv/item_files/modem/mmode/sd/loc_base_bsr_mcc_list 204 bytes Downloading file /nv/item_files/modem/mmode/sd/sdssscr_timers 204 bytes Downloading file /nv/item_files/modem/mmode/sw_version 61 bytes Downloading file /nv/item_files/modem/nas/allowed_csg_list 602 bytes Downloading file /nv/item_files/modem/tdscdma/rrc/acq_list 992 bytes Downloading file /nv/item_files/modem/uim/gstk/rat_priority_config 26 bytes Downloading file /nv/item_files/modem/uim/uimdrv/uim_hw_config 256 bytes Downloading file /nv/item_files/modem/uim/uimdrv/uim_sys_info 256 bytes Downloading file /nv/item_files/rfnv/00022957 773 bytes Downloading file /nv/item_files/rfnv/00022958 1.58 Kb Downloading file /nv/item_files/rfnv/00022959 1.66 Kb Downloading file /nv/item_files/rfnv/00022960 1.68 Kb Downloading file /nv/item_files/rfnv/00022961 751 bytes Downloading file /nv/item_files/rfnv/00022962 758 bytes Downloading file /nv/item_files/rfnv/00022967 749 bytes Downloading file /nv/item_files/rfnv/00022975 733 bytes Downloading file /nv/item_files/rfnv/00022976 1.26 Kb Downloading file /nv/item_files/rfnv/00022977 1.23 Kb Downloading file /nv/item_files/rfnv/00022978 739 bytes Downloading file /nv/item_files/rfnv/00022982 529 bytes Downloading file /nv/item_files/rfnv/00024964 161 bytes Downloading file /nv/item_files/rfnv/00024965 161 bytes Downloading file /nv/item_files/rfnv/00024966 161 bytes Downloading file /nv/item_files/rfnv/00024967 161 bytes Downloading file /nv/item_files/rfnv/00024972 2.97 Kb Downloading file /nv/item_files/rfnv/00024973 2.97 Kb Downloading file /nv/item_files/rfnv/00024974 2.49 Kb Downloading file /nv/item_files/rfnv/00024975 2.49 Kb Downloading file /nv/item_files/rfnv/00025004 192 bytes Downloading file /nv/item_files/rfnv/00025005 192 bytes Downloading file /nv/item_files/rfnv/00025006 192 bytes Downloading file /nv/item_files/rfnv/00025007 192 bytes Downloading file /nv/item_files/rfnv/00025044 160 bytes Downloading file /nv/item_files/rfnv/00025045 160 bytes Downloading file /nv/item_files/rfnv/00025046 160 bytes Downloading file /nv/item_files/rfnv/00025047 160 bytes Downloading file /nv/item_files/rfnv/00025506 384 bytes Downloading file /nv/item_store/rfnv/rfc.bl 5 bytes Downloading file /nv/item_store/rfnv/rfnv.bl 20 bytes Downloading file /nv/reg_files/modem/lte/rrc/csp/acq_db 344 bytes Backuping SNV [1] to file: Backups\D855_snv1_357513067856493_2016-3-3_13-11-42.sbf Dump SNV [1]: Start Getting phone info... Getting phone info: OK Switching to SNV mode... Reading SPC... Reading SPC: OK Sending SPC... Sending SPC: OK Switching to SNV mode: OK Dumping SNV [1]... Dumping SNV [1]: OK Switching to normal mode... Switching to normal mode: OK Dump SNV [1]: Finish Backuping SNV [2] to file: Backups\D855_snv2_357513067856493_2016-3-3_13-15-28.sbf Dump SNV [2]: Start Getting phone info... Getting phone info: OK Switching to SNV mode... Reading SPC... Reading SPC: OK Sending SPC... Sending SPC: OK Switching to SNV mode: OK Dumping SNV [2]... Dumping SNV [2]: OK Switching to normal mode... Switching to normal mode: OK Dump SNV [2]: Finish Checking Emergency Mode... Mode: Normal Switching to Emergency Mode... Mode: Emergency Checking connect in LAF-Emergency Mode... Checking... Checking connect in LAF-Emergency Mode: OK Protocol: Invalid response:Bad HELO resp[PROTOVER]: 48454c4f0300000101000010000080000200000000000000f8 880000b7bab3b0 |
