11-13-2017, 11:59 | #46 (permalink) |
No Life Poster Join Date: Sep 2008 Location: Philippines
Member: 853601 Status: Offline Thanks Meter: 251 | |
The Following User Says Thank You to DELRO For This Useful Post: |
11-13-2017, 12:07 | #47 (permalink) |
Insane Poster Join Date: Jul 2014
Member: 2228280 Status: Offline Thanks Meter: 7 | Hello Its Simple and Easy Run Wordpad or Notepad Any editior in Admin mode, Goto File and Follow the path %windir%\System32\drivers\etc\hosts Open the Host File Add the Lines as the_laser Said Above.. And Save it . Restart PC and All Good , Br, |
The Following User Says Thank You to devinegsm For This Useful Post: |
11-13-2017, 12:07 | #48 (permalink) |
No Life Poster Join Date: Jan 2010 Location: Kushtia,Bangladesh Age: 36
Member: 1217358 Status: Offline Sonork: 100.1605541 Thanks Meter: 156 | same problem no login forum any one upload parfect host file Last edited by alpona_su; 11-13-2017 at 12:15. |
The Following User Says Thank You to alpona_su For This Useful Post: |
11-13-2017, 17:30 | #49 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Tunisia
Member: 261437 Status: Offline Sonork: no Thanks Meter: 922 | just copy this file hosts to path C:\Windows\System32\drivers\etc ... or edit manually your hosts and put : 192.162.139.82 setool.net 192.162.139.82 support.setool.net 192.162.139.82 files.setool.net without # |
The Following 63 Users Say Thank You to noure30 For This Useful Post: |
11-13-2017, 19:09 | #50 (permalink) | |
Freak Poster Join Date: Apr 2005 Age: 43
Member: 138234 Status: Offline Thanks Meter: 78 | Quote:
what about (SERVER IP) in setool soft? to check credits and do some server operations! Thx | |
11-13-2017, 19:57 | #51 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Russia Age: 44
Member: 9519 Status: Offline Thanks Meter: 2,150 | setool2 credits server is down for unknown time. if you did not updated your card, you can not unlock any sony phone. |
The Following User Says Thank You to the_laser For This Useful Post: |
11-14-2017, 09:20 | #53 (permalink) |
Freak Poster Join Date: May 2007 Location: Romania
Member: 513613 Status: Offline Thanks Meter: 25 | I can acces support but cannot unlock phones PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... RUNNING S1_BOOT VER "R10D030" ACTIVE_COMP_AID : 0002 HWCONF_AID : 0002 LOADER_AID : 0002 BOOT_AID : 0002 [ llcomm: 00010000,00080000 ] DEVICE ID: DA56C79D768D184753A16E46BD8C128DD848F1A8 FLASH ID: "00FE/004E003F" LOADER VERSION: R5D030 PHONE IMEI : 35264006378327 Checking for signature ... CAN'T CONNECT TO SERVER. signature calculation not done,err: 144 Unlock FAILED Elapsed: 27 seconds |
11-14-2017, 11:56 | #54 (permalink) |
No Life Poster Join Date: Dec 2005 Location: Al-Madina Communication Age: 45
Member: 206532 Status: Offline Sonork: 100.1622270 Thanks Meter: 874 | thanks its working .......................................... |
The Following User Says Thank You to alis For This Useful Post: |
11-15-2017, 12:06 | #57 (permalink) |
No Life Poster Join Date: Apr 2008 Location: -=Cellulare Zone Europ-EGYPT=-
Member: 762055 Status: Offline Sonork: -=664053=- Thanks Meter: 778 | 192.162.139.82 setool.net 192.162.139.82 support.setool.net 192.162.139.82 files.setool.net Thank you working ok ................. -=MR_GSM=- |
The Following User Says Thank You to -=MR_Gsm=- For This Useful Post: |
11-15-2017, 13:54 | #58 (permalink) |
Freak Poster Join Date: May 2006 Location: Slovakia
Member: 272319 Status: Offline Thanks Meter: 99 | support site and forum works, now, but when i try to unlock st21i setool 1.1431 it end with error Code: Checking for signature ... CAN'T CONNECT TO SERVER. signature calculation not done,err: 144 Unlock FAILED |
11-16-2017, 00:38 | #59 (permalink) | |
Freak Poster Join Date: Mar 2007 Location: The Earth
Member: 459470 Status: Offline Thanks Meter: 20 | Quote:
don't forget to restart your comp | |
11-16-2017, 07:08 | #60 (permalink) |
No Life Poster Join Date: Jan 2008
Member: 683463 Status: Offline Thanks Meter: 188 | # Copyright (c) 1993-2009 Microsoft Corp. # # This is a sample HOSTS file used by Microsoft TCP/IP for Windows. # # This file contains the mappings of IP addresses to host names. Each # entry should be kept on an individual line. The IP address should # be placed in the first column followed by the corresponding host name. # The IP address and the host name should be separated by at least one # space. # # Additionally, comments (such as these) may be inserted on individual # lines or following the machine name denoted by a '#' symbol. # # For example: # # 102.54.94.97 rhino.acme.com # source server # 38.25.63.10 x.acme.com # x client host # localhost name resolution is handled within DNS itself. # 127.0.0.1 localhost # ::1 localhost 192.162.139.82 setool.net 192.162.139.82 support.setool.net 192.162.139.82 files.setool.net already i edit my host and restart my computer help still cannot log in on support firmware plese help both suite can't access to support v1.1431 and 1.1425 |
