Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SETool2
Old 12-30-2019, 19:31   #1 (permalink)
Member: 1677266
Thanks Meter: 90
Unlock U10i CID:81
I am trying to unlock a SonyEricsson U10i cid81 from Saturday, in the A2 server information is online, I have been charged the 3 credits but the server error always jumps ...
Do the servers still work? or when will they work? ...
Thank you
RUNNING v 1.1436/01.10/UNI
CARD SERIAL ********
USBFLASH DRIVER VERSION 02.02.00.05
SIGNED MODE (USING SERVER)
CFG:100010000000
short credits consumption list :
Services OFFLINE
S1 v1,v2,S1 OPEN AID 004,FLASHMODE activation
Services ONLINE
A1 phones, CSCA unlock/repair 03 credits
A2 phones, CSCA unlock/repair 03 credits
S1 OPEN, CSCA unlock/repair 03 credits
W100,W150 unlock codes 01 credits
S1 QSD8250,MSM7227,MSM8255 alternative bypass unlock/repair 01 credits
ST21,ST21i2,ST23,ST26,C150x,C160x alternative bypass unlock 01 credits
You CAN NOT unlock next phones, when S1 services offline:
u1/u5/u8 with loader AID 004,
LoCosto,Neptune-based phones with loader AID 004,
LoCosto,Neptune-based phones with damaged security zone,
w100,w150 full unlock,ck13,ck15,wt13,
any SONY phone, released from 2012 year,except
ST21,ST21i2,ST23,ST26,C150x,C160x phones
S1 QSD8250,MSM7227,MSM8255 alternative bypass STANDALONE activation 10 credits
ST21,ST21i2,ST23,ST26,C150x,C160x alternative bypass unlock/repair FREE, if you have this activation
current updater version: 0.95
current setool2 version: 1.1436
SERVER CREDITS LEFT/USED: 16/14
CARD COUNTERS: FLASH 0, UNLOCK 3863
Elapsed: 3 seconds
CFG:100010000000
ChipID: F002, EMP protocol: 0401
R7BA084_1223-3004_GENERIC_RA
PHONE DOMAIN: "RETAIL"
PHONE CID: 0081
OTP: LOCKED:1 CID:81 PAF:1 IMEI:***************** CERT:RED
LDR: 2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096
LDR CAPS: SYSTEM FLASH SIGNATURE AUTH
LDR: 2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096
LDR CAPS: SYSTEM FLASH GDFS FILESYSTEM TA
Executing CSCA-based unlock
Checking for signature ...
Waiting for calculation process ...
RESPONSE: "SUCCESS" [1038]
server error:remote dongle not available
Unlock FAILED
Elapsed: 15 seconds
CFG:100010000000
PHONE CID: 0081
OTP: LOCKED:1 CID:81 PAF:1 IMEI:****************** CERT:RED
signature found, skipping calculation
Unlock FAILED
Elapsed: 9 seconds
CFG:100010000000
PHONE CID: 0081
Unlock FAILED
Elapsed: 20 seconds
Old 01-03-2020, 21:29   #2 (permalink)
Member: 1677266
Thanks Meter: 90
setool is Dead ?
setool is Dead
Old 01-03-2020, 22:48   #3 (permalink)
:Aishur:'s Avatar
Member: 1315677
Thanks Meter: 1,439
No, sir
Please check post#3 https://support.setool.net/showthrea...2-BASED-PHONES
pay attention to CFG:110011000000, it will be magic
Old 01-03-2020, 23:07   #4 (permalink)
:Aishur:'s Avatar
Member: 1315677
Thanks Meter: 1,439
try first CFG:100011000000
Old 01-04-2020, 10:49   #5 (permalink)
Member: 1677266
Thanks Meter: 90
Unlock Done
:Aishur: Thank you very much for the information. I have totally forgotten this method when the server is offline.
https://support.setool.net/showthrea...-BASED-PHONES:
if s1 signature server offline, you can not use quick (without modem drivers) unlock.
instead, you should :
1.
select proper model
2.
on settings, check
"signed mode",
"do full unlock instead usercode reset",
"disable flash mode activation for semc a2 phones",
fill login details
3.
back to semc a2 tab, press unlock
4.
when prompted, install phone modem drivers
(they can be found in drivers\Modem_Drivers or will be automatically installed if you install semc pc suite)
5.
when you will get message "unlock done" - do not remove cable or battery,
wait until phone automatically power on, otherwise you will get 5 locks and need to repeat procedure.
Page generated in 0.26113 seconds with 8 queries
