**** Sony Ericsson J108 5 Lock Down Fix :D 100% **** Quick Guide To Fix 5 Locks :D 1. Download the FLASH FILE from support : R7EA011.APP_SW_1239_0125_GENERIC_HO_REDBR OWNBLUE_CID81_80_53_52_49_DB3350.SOFTWARE R7EA011.FS_CENTRAL_EUROPE_HO_REDBROWNBLUE _CID81_80_53_52_49.SOFTWARE 2. Flash the firmware to J108 click SETTING tab SIGN MODE & CUSTOMIZE PHONE. 3. Once the mobile has been flashed power up the mobile until all the setting are restored then power off the mobile. 4. Click SEMC A2 tab click J108_CEDAR 5. Click SETTING tab chose SIGN MODE, PERFORM FULL UNLOCK & DISABLE FLASH MODE. 6. CLICK UNLOCK, FOLLOW THE INSTRUCTIONS ON SETOOL AND MAKE SURE YOU DON'T DISCONNECT THE CABLE AFTER UNLOCK IS COMPLETED WAIT UNTIL POWERS UP PLEASE NOTE FLASH FILE MAY BE INCORRECT, PLEASE LET ME KNOW AS I HAVE RUSHED THIS GUIDE :D & I WILL DOUBLE CHECK WHEN I GET BACK HOME |
Quick Guide To Blabla with 5 locks you can NOT fullfill Code: |
Lmfao try before you post bulls***t let me get hold of j108 tmrw i will close all locks and unlock the j108 using this method. |
any 1 out there has tried this soultion please post or having problems contact me. also may take credits which i forget to mention :D |
from the software owner (the_laser) if you can not enter phone menu, you can not unlock it. your steps 1 to 5 and 6 are described in the faqs, so nothing of special. how to unlock j108 phone without s1 signature server to be online No more time to spend in this thread no regards |
There is nothing special about this thread i am here to help people with locked j108 and yes you are right about 1,5 & 6 in the faq, but i am sure the faq does not mention about which file to flash with and gets random seed even when the s1 server is offline which i was shocked :D There is no harm of trying its not like the mobile is going to bl*w, you will see the result your self. |
Correct Flash Files These are the correct flash flies r7ea011.app_sw_1239_0125_generic_ho_redbrownblue_c id81_80_53_52_49_db3350.software r7ea011.fs_adriatic_ho_redbrownblue_cid81_80_53_52 _49.software |
Log RUNNING v 1.1289/01.15/UNI CARD SERIAL 00010963 USBFLASH DRIVER VERSION 03.00.00.00 SIGNED MODE (USING SERVER) CFG:101000000000 ChipID: F100, EMP protocol: 0401 PHONE DOMAIN: "RETAIL" PHONE CID: 0081 OTP LOCKED: 1 CID: 81 PAF: 1 IMEI: 01261100449264 CERT: RED LDR: 2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH SIGNATURE AUTH LDR: 2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH GDFS FILESYSTEM TA writing "C:\Documents and Settings\Computer 2\Desktop\Sony\Flash\J108\R7EA011.APP_SW_1239_0125 _GENERIC_HO_REDBROWNBLUE_CID81_80_53_52_49_DB3350. SOFTWARE" ALLOWED DOMAINS: BLUE BROWN RED MAXIMUM CID: 81 Will flash 1009 blocks ... ssw file accepted writing "C:\Documents and Settings\Computer 2\Desktop\Sony\Flash\J108\R7EA011.FS_ADRIATIC_HO_R EDBROWNBLUE_CID81_80_53_52_49.SOFTWARE" ALLOWED DOMAINS: BLUE BROWN RED MAXIMUM CID: 81 Will flash 2338 blocks ... ssw file accepted using GENERIC phone customization tpa/preset/custom/CONTENT_DOWNLOAD_HOOK.itm tpa/preset/custom/FM_PICTURES_HOOK_3.itm tpa/preset/custom/FM_SOUNDS_HOOK_3.itm tpa/preset/custom/FM_THEMES_HOOK_3.itm tpa/preset/custom/FM_VIDEOS_HOOK_3.itm tpa/preset/custom/GAMES_HOOK_3.itm tpa/preset/custom/MC_MUSIC_HOOK_3.itm tpa/preset/custom/MC_PHOTO_HOOK_3.itm tpa/preset/custom/MC_VIDEO_HOOK_3.itm tpa/preset/custom/ORG_APPLICATIONS_HOOK_3.itm tpa/preset/custom/preloaded_config.xml tpa/preset/custom/SETT_RINGTONE_HOOK_1.itm tpa/preset/custom/SETT_SCREENSAVER_HOOK_1.itm tpa/preset/custom/SETT_STARTSHOW_HOOK_1.itm tpa/preset/custom/SETT_WALLPAPER_HOOK_1.itm tpa/preset/custom/Customize.xml Elapsed: 442 secs. SIGNED MODE (USING SERVER) CFG:100011000000 ChipID: F100, EMP protocol: 0401 PHONE DOMAIN: "RETAIL" PHONE CID: 0081 OTP LOCKED: 1 CID: 81 PAF: 1 IMEI: 01261100449264 CERT: RED LDR: 2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH SIGNATURE AUTH LDR: 2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature ... Waiting for calculation process ... RESPONSE: "SUCCESS" [1038] Backup security data ... Erasing locks ... DISCONNECT PHONE NOW REMOVE SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM103 PHONE READY TO PROCEED. GOT SEED: 00FFDED5 ACTIVATION COMPLETED. USERCODE RESET TO "0000" DO NOT DISCONNECT PHONE FROM CABLE UNTIL PHONE TURNS ON BY ITSELF Unlock DONE Elapsed: 83 secs. |
Great and interesting finding ! Indeed, after unique j108 bypass method, phone security units written such way, that activation command became unblocked in R7EA011 firmware and you can "fix" ( unlock ) such phone via standard CSCA way ( signed mode, do full unlock, disable flash mode activation ) it is no need to reflash phone again, enough just perform CSCA unlock procedure. No any credits required, of course, if phone was unlocked by setool2 server. If user by mistake flashed other that r7ea011 firmware to such "locked" phone, it still can be fixed by flashing r7ea011 firmware and perform CSCA unlock. notice, that all that only correct for phones, which unlocked via j108 bypass way. |
Bet you feel good with your blabla now? Better to say nothing if you dont understand what people saying.......... WBR yeldar ;) |
Also you need to read the notice (Restriction) and try to understand a bit how to deal with it for a 5 locked phone. Quote:
J1o8 5 locks closed unlocked successfully Quote:
for this post i have successfully unlocked j108 5 locks closed thank you very much |
You should have the SIM card working for phone and data.http://www.jonneale.info/9.jpg |
