02-08-2010, 14:09 | #1 (permalink) |
No Life Poster Join Date: Apr 2009 Location: where love is Age: 33
Member: 1002000 Status: Offline Sonork: 100.1604575 Thanks Meter: 90 | K530i cid 53 after unlock dead flash lock PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35602702259872 CERT:RED FLASH CID:53 COLOR:RED PATCH:071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID:897E writing "D:\Program files\Se-tool\Flash files\K530\cid53\r8be001_cxc1250912_nc_red_cid53.s oftware" CURRENT FLASH FILE CID:53 SSW uses full hash, hash len is: 9200 Will flash 460 blocks... writing "D:\Program files\Se-tool\Flash files\K530\cid53\r8be001_fs_europe_4_nc_red_cid53. software" CURRENT FLASH FILE CID:53 SSW uses full hash, hash len is: 3220 Will flash 161 blocks... LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed USERCODE RESET TO "0000" using GENERIC phone customization tpa/preset/custom/C3_PCA_G3v2.cer tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm tpa/preset/custom/customize.xml tpa/preset/custom/DESKTOP_HOOK_2.itm tpa/preset/custom/Entrust.net Root Certificate.cer tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt tpa/preset/custom/FM_PICTURES_HOOK_3.itm tpa/preset/custom/FM_SOUNDS_HOOK_3.itm tpa/preset/custom/FM_THEMES_HOOK_3.itm tpa/preset/custom/FM_VIDEOS_HOOK_3.itm tpa/preset/custom/GAMES_HOOK_3.itm tpa/preset/custom/GTE_CyberTrust_Root.cer tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt tpa/preset/custom/Root.cer tpa/preset/custom/SEMC_E2E_Root_CA.crt tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm tpa/preset/custom/ThawtePremium.der tpa/preset/custom/ThawteServerCA.cer tpa/preset/custom/Utiroot.cer tpa/preset/custom/VeriSignClass3Root.cer tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt Phone detached Elapsed: 400 secs. SIGNED MODE (USING SERVER) PRELOADER SECURITY BYPASS ENABLED CFG:101000000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35602702259872 CERT:RED FLASH CID:53 COLOR:RED PATCH:071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID:897E LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM9 PHONE READY TO PROCEED EXECUTOR STARTED REMOVE CABLE FROM PHONE REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK FINALLY PRESS "READY" ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 Starting embedded bootloader... INT LDRB2020_PRELOADER_FOR_SETOOL2 LDRB2020 LOADER FOR SETOOL2 FLASH ID:897E FOUND VERSION "R8BE001_CXC1250912_GENERIC_NC" can't open file "D:\Program files\Se-tool\rest\R8BE001_CXC1250912_GENERIC_NC" USERCODE RESET TO "0000" Searching... Firmware SIMLOCK check determined. Unlock FINISHED Elapsed: 189 secs. |
The Following User Says Thank You to rockindheeraj For This Useful Post: |
02-09-2010, 01:46 | #5 (permalink) | |
Freak Poster Join Date: Aug 2007 Location: Kpg Hulu,Sri Aman,SERAWAK
Member: 558761 Status: Offline Thanks Meter: 5 | Quote:
That is why your phone dead. best regards | |
02-09-2010, 09:57 | #8 (permalink) |
No Life Poster Join Date: Nov 2008 Location: RVIII
Member: 890926 Status: Offline Thanks Meter: 2,055 | Rest File is Located in SE Tool Uni REST folder but in your case its absent so you need to Add this File "R8BE001_CXC1250912_GENERIC_NC" then Identify to have REST file or Fash to Generic version then Identify if REST File is present. You have to be sure REST File & Bypass Package are Present so it can be Unlock. |
02-09-2010, 10:23 | #10 (permalink) |
Member: 1002000 Status: Offline Sonork: 100.1604575 Thanks Meter: 90 | One more doubt if any sony erricsson mobile if want to unlock restoration file must be present orelse i have to make restoration file for unlock process by selecting main file and then identify.then mobile will be unlocked safely without any bla bla bla....... |
k530i cid 53 problem sim lock | mtechstation | Sony Ericsson Hardware Repair | 16 | 12-28-2011 17:50 |
W995 cid 53 after unlock no network | denard | Cruiser Suite | 9 | 10-23-2010 18:14 |
how to repair gdfs k530i cid 53 ? help cruiser team | kyaw8719 | Cruiser Suite | 3 | 03-01-2010 08:10 |
plz i need gdfs for k530i cid 53 | med26 | Sony Ericsson | 1 | 02-28-2010 21:21 |
K800 CID 52 after unlock can't flash :( | Sakura | Universalbox | 3 | 08-31-2007 09:17 |
