sony ericsson w850i not power on i have sony w850i in whit light blinking after power on.befor that identified with setool its show modal k700. i replace flex cable & front key pad board but same.after that i recover & write gdfs & eaprom its show modal right. but still same prob white light blink.i try to fully flash but not done same.:confused: identified logs: >>>>> Elapsed: 20 secs. CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 FLASH ID: 897E OTP: LOCKED:1 CID:49 PAF:1 IMEI:35240101263884 CERT:N/A FLASH CID:51 COLOR:RED Model (from GDFS):K700 MAPP CXC article: R1GB001 prgCXC1250200_GENERIC_CY MAPP CXC version: R1GB001 Language Package: EUROPE_4 CDA article: CDA102568/13 CDA version: R2A Default article: cxc1250489 Default version: R1ED001 PROVIDER: 000-00 SIMLOCKS NOT DETECTED RESTORATION FILE NOT PRESENT "R1GB001_CXC1250200_GENERIC_CY" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED |
Download Br naeem |
Hello, 1st perform correct reset procedure like this. CID 50,51,52,53 that is so-called reset procedure. 1. go to emptyboard tab 2. select proper model 3. on settings, check "signed mode" 4. press recovery 5. after succeful recovery 6. on settings uncheck all 7. if gdfs totally damaged, add to firmware area proper gdfs in ssw format,otherwise skip that step 8. add to firmware area proper EROM (EROM CID >= OTP CID) 9. press flash 10. if needed,reflash phone on usual semc tab with needed settings. If this not work than change lcd and post result. BR |
Change flex cable and upper keypad board, then flash ur phone thats all, ur phone is 100% ok.............. |
try to explain it nicely bro i don't understand |
