Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | -= Z3X JTAG PLUS =- | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2006 Location: Bulgaria Asenovgrad Age: 39
Member: 239176 Status: Offline Sonork: 100.1602815 Thanks Meter: 851 | sony j10 elm not unlock but take credits OTP: LOCKED:1 CID:80 PAF:1 IMEI:35987403064100 CERT:RED LDR: 2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH SIGNATURE AUTH LDR: 2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature ... signature calculation not done,err: 144 Unlock FAILED Elapsed: 10 secs. DISCONNECT PHONE NOW REMOVE SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM361 PHONE READY TO PROCEED. GOT SEED: 001EADFF ACTIVATION COMPLETED. USERCODE RESET TO "0000" DO NOT DISCONNECT PHONE FROM CABLE UNTIL PHONE TURNS ON BY ITSELF Unlock DONE Elapsed: 131 secs. solved. Last edited by delchoni; 03-06-2015 at 09:34. Reason: Solved !!!! enable -disable flash mode for a2 phones |
![]() | #2 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2011 Location: Poland
Member: 1704846 Status: Offline Sonork: 1617108 Thanks Meter: 117 | 1. select proper model 2. on settings, check "signed mode", "do full unlock instead usercode reset", "disable flash mode activation for semc a2 phones", fill login details 3. back to semc a2 tab, press unlock 4. when prompted, install phone modem drivers (they can be found in drivers\Modem_Drivers or will be automatically installed if you install semc pc suite) 5. when you will get message "unlock done" - do not remove cable or battery, wait until phone automatically power on, otherwise you will get 5 locks and need to repeat procedure. you can not unlock last SEMC A2 phone ( j108 ) with CSCA method, use special bypass mode. you MUST flash r7cXXX firmware version to be able unlock w20 phone with CSCA method. |
