Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SETool2
Old 10-24-2009, 17:24   #1 (permalink)
Member: 67260
Thanks Meter: 146
sony k530i dead failed to setup GDFS
Sony K530i dead
Loaded 51 flash descriptors
CFG:000000000000
ChipID:9900,EMP protocol:0301
Speed:921600
FLASH ID:897E
OTP: LOCKED:1 CID:51 PAF:1 IMEI:35901901797489 CERT:N/A
FLASH CID:52 COLOR:RED
can't get packet start.
packet not acknowledged (17)
setGDFS_params failed
Elapsed: 76 secs.
how to solve this problem..... ?
Old 10-24-2009, 19:11   #2 (permalink)
toutou_gsm's Avatar
Member: 628112
Sonork: 100.1589052
Thanks Meter: 3,726
Originally Posted by alexchairman View Post
Sony K530i dead
CFG:000000000000
Speed:921600
FLASH ID:897E
Elapsed: 76 secs.
flash ur phone with any firmware,must alive again
Old 10-24-2009, 22:35   #3 (permalink)
Mohsin-*'s Avatar
Member: 417298
Sonork: 100.1578269
Thanks Meter: 18,268
GDFS corrupted
repair with reset method for all information check FAQ
http://forum.gsmhosting.com/vbb/showthread.php?t=699462
post 51
Old 05-15-2010, 09:38   #4 (permalink)
Member: 1178099
Sonork: 143
Thanks Meter: 3
SIGNED MODE (USING SERVER)
CFG:100100000000
Will backup GDFS now.
Speed:921600
OTP: LOCKED:1 CID:51 PAF:1 IMEI:35901901551729 CERT:N/A
PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0
LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015
FLASH ID:897E
LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013
loader startup: executed
GDFS startup failed,error is 04 [1D]
loader GDFS startup failed, that is fatal
Elapsed: 21 secs.
CFG:100100000000
Will write GDFS now.
Speed:921600
FLASH ID:897E
Elapsed: 21 secs.
CFG:100100000000
Speed:921600
FLASH ID:897E
writing "I:\SETOOL-3\SONYERICSSON SETOOL FLASH FILES\SETOOL-LITE\K530\CID-52\K530_R8BB001_MAIN_GENERIC_NC_RED52.mbn"
CURRENT FLASH FILE CID:52
SSW uses full hash, hash len is: 9200
Will flash 460 blocks...
writing "I:\SETOOL-3\SONYERICSSON SETOOL FLASH FILES\SETOOL-LITE\K530\CID-52\K530_R8BB001_FS_BALTIC_RED52.fbn"
SSW uses full hash, hash len is: 3140
Will flash 157 blocks...
Elapsed: 815 secs.
Old 05-15-2010, 10:01   #5 (permalink)
Member: 1178099
Sonork: 143
Thanks Meter: 3
i will flashe k530i but loader startup: executed
Elapsed: 670 secs.
pls help me
Old 05-15-2010, 20:07   #6 (permalink)
roney_nexus's Avatar
Member: 288504
Sonork: .:100.1587032:.
Thanks Meter: 2,266
Do it first:
1. select proper model
2. on settings, check "signed mode"
3. press identify
4. after that Flash the phone with setting 1. check "signed mode" 2. customize phone after flash
if not done then:
1. go to emptyboard tab
2. select proper model
3. on settings, check "signed mode"
4. press recovery (Reset Procedure, Need 1 Credits)
5. after successful recovery
6. on settings uncheck all
7. if gdfs totally damaged, add to firmware area proper gdfs in ssw format,otherwise skip that step
8. add to firmware area proper EROM (EROM CID >= OTP CID)
9. press flash
10. if needed,reflash phone on usual semc tab with needed settings.
The Following User Says Thank You to roney_nexus For This Useful Post:
Old 05-15-2010, 20:32   #7 (permalink)
algerienbox's Avatar
Member: 591880
Thanks Meter: 561
Originally Posted by roney_nexus View Post
Do it first:
3. press identify
if not done then:
9. press flash
affter reset operation phone will be brown he can't flash it (reset operation is free)
Old 05-15-2010, 20:36   #8 (permalink)
Member: 288504
Thanks Meter: 2,266
yes bro free for 1.01 version thx.............
Old 05-20-2010, 08:37   #9 (permalink)
Member: 1178099
Sonork: 143
Thanks Meter: 3
CFG:000000000000
RECOVERY MODE STARTED
Speed:921600
REC:070703 1229 NPA4_CXC1329130_DB2020_SEMC_RECOVERY_P3N
can't open file "frec\marikabrowncid52.bin"
Recovery failed. Phone dead.
Elapsed: 2 secs.
Old 05-20-2010, 09:03   #10 (permalink)
Member: 288504
Thanks Meter: 2,266
Originally Posted by iamsreekanthk View Post
CFG:000000000000
Speed:921600
Elapsed: 2 secs.
4. press recovery
5. after succeful recovery
9. press flash
The Following 2 Users Say Thank You to roney_nexus For This Useful Post:
Old 06-24-2010, 19:43   #11 (permalink)
Member: 936481
Sonork: saeedbaco
Thanks Meter: 11
CFG:001010000000
Speed:921600
OTP LOCKED:1 CID:51 PAF:1 IMEI:35901901788418
ACTIVE CID:49 COLOR:BROWN
LDR:060721 1021 DB2020_SERVICE_LOADER
FLASH ID: 897E
writing "C:\Program Files\se\flash\K530i\r6bc002_cxc1250912_nc_red_cid 53.software"
CURRENT FLASH FILE CID:53
HDR block not accepted,error: 19
Elapsed: 13 secs.
please help bro
Old 06-24-2010, 20:00   #12 (permalink)
Member: 288504
Thanks Meter: 2,266
Exclamation
Originally Posted by saeedbaco View Post
CFG:001010000000
Speed:921600
FLASH ID: 897E
Elapsed: 13 secs.
please help bro
just properly finish reset operation, you only need to write EROM.
please check FAQ for details.
Old 06-25-2010, 07:20   #13 (permalink)
Member: 1074300
Thanks Meter: 3
Wink
Do it first:
3. press identify
if not done then:
9. press flash
yes if you follow it you can solved your problam by v1.01
Old 06-26-2010, 06:53   #14 (permalink)
Member: 936481
Sonork: saeedbaco
Thanks Meter: 11
CFG:001010000000
Speed:921600
FLASH ID: 897E
writing "C:\Program Files\se\flash\K530i\R8BB001_1250912_GENERIC_NC.ss w"
Elapsed: 22 secs.
please help bro
Old 06-26-2010, 07:48   #15 (permalink)
Member: 288504
Thanks Meter: 2,266
CFG:001010000000
Speed:921600
FLASH ID: 897E
Elapsed: 22 secs.
please help bro
Do It...
CID 50,51,52,53
that is so-called reset procedure.
4. press recovery
9. press flash
Try To Result Me Thx....
lost credit loss but failed to reconstuction gdfs k320(cid detect 51) sharky_tan Cruiser Suite 4 04-24-2010 10:24
W850 failed to setup phone dapinderjit Sony Ericsson 4 02-08-2010 18:05
j132 FAILED TO SETUP PHONE GMC SETool2 5 01-30-2010 01:13
Se w700 failed to setup phone ..::khaled::.. SETool2 1 01-26-2010 09:50
P1 cid 53 failed to setup GDFS Winston rio hum SETool2 3 11-26-2008 17:48
Page generated in 0.25479 seconds with 9 queries
