05-04-2010, 13:01 | #1 (permalink) |
No Life Poster Join Date: May 2008
Member: 770503 Status: Offline Thanks Meter: 1,215 | plz help this regars w580 Code: CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:115200 FLASH ID: 897E OTP: LOCKED:1 CID:51 PAF:1 IMEI:35923501214724 CERT:N/A FLASH CID:53 COLOR:RED Model (from GDFS):W580i MAPP CXC article: R8BE001 prgCXC1123476_CHINA_LA MAPP CXC version: R8BE001 Language Package: APAC CDA article: CDA102568/1 CDA version: R2A Default article: cxc1123364 Default version: R8BE001 PROVIDER: 234-33 Network LOCKED RESTORATION FILE NOT PRESENT "R8BE001_CXC1123476_CHINA_LA" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED Elapsed: 9 secs. UNLOCKING OF DB2020,PNX5230 PHONES standalone patch unlock method via alternative security bypass 1. select com/ufs/usb as interface 2. go to semc tab 3. select correct model 4. on settings tab, check "signed mode","alternative security bypass", "preloader security bypass" 5. back on semc tab 6. press unlock button i try but show this Code: CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:115200 FLASH ID: 897E OTP: LOCKED:1 CID:51 PAF:1 IMEI:35923501214724 CERT:N/A FLASH CID:53 COLOR:RED Model (from GDFS):W580i MAPP CXC article: R8BE001 prgCXC1123476_CHINA_LA MAPP CXC version: R8BE001 Language Package: APAC CDA article: CDA102568/1 CDA version: R2A Default article: cxc1123364 Default version: R8BE001 PROVIDER: 234-33 Network LOCKED RESTORATION FILE PRESENT FOR DETECTED FIRMWARE Elapsed: 6 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PRELOADER SECURITY BYPASS ENABLED CFG:111000000000 ChipID:9900,EMP protocol:0301 Speed:115200 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35923501214724 CERT:N/A FLASH CID:53 COLOR:RED PATCH:071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID: 897E LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader GDFS startup executed loader FILESYSTEM startup executed INSERT SIM CARD, FULLY TURN PHONE ON GO TO GAMES MENU AND RUN EXECUTOR AFTER PHONE TURNS OFF OR HANGS REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK FINALLY PRESS "READY" ChipID:9900,EMP protocol:0301 Speed:115200 STARTING BOOTLOADER... can't get packet start. FLASHLOADER NOT RESPONDING Elapsed: 163 secs. |
05-04-2010, 19:56 | #2 (permalink) |
No Life Poster Join Date: Sep 2007 Location: algeria
Member: 591880 Status: Offline Thanks Meter: 561 | do reset operation (use server +recovry) and flash correct erom (cid53) and your phone is full unlocked no need restor no need teste sim this is a new methode to unlock |
Winlock 1.10 - Help | rdmfs | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-25-1999 08:21 |
