Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | ★ Wholesale Unlock ★ | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) |
Temporary banned !! ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2009 Location: P.H Age: 37
Member: 1151970 Status: Offline Sonork: 100.1597000 Thanks Meter: 378 | sony Z550a 2pec lock to videotron sim restore unlock done via setools insert orig sim card goto unlock repair and run restore files unlock done my usb cable and Drivers Files here my restore Files R6GA004_CXC1250583_GENERIC_ML here logs ![]() ![]() v0.915056/UNI CARD SERIAL: 000**** Loaded 51 flash descriptors CFG:000000000000 ChipID:8040,EMP protocol:0301 NEW SECURITY (MARITA RESPIN) PHONE PHONE STATE: "RETAIL" FLASH CID: 0051 Speed:921600 FLASH ID:897E OTP: LOCKED:1 CID:51 PAF:1 IMEI:35350501479484 CERT:RED FLASH CID:51 COLOR:RED Model (from GDFS):Z550a Brand:Videotron MAPP CXC article: R6GA004 prgCXC1250583_GENERIC_ML MAPP CXC version: R6GA004 Language Package: ROGERS CDA article: CDA102731/35 CDA version: R2A Default article: cxc1250506 Default version: R6GA004 PROVIDER: 302-72 Network LOCKED USERCODE:0000 RESTORATION FILE PRESENT FOR DETECTED FIRMWARE SECURITY UNITS BACKUP CREATED. Elapsed: 6 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PRELOADER SECURITY BYPASS ENABLED CFG:111000000000 ChipID:8040,EMP protocol:0301 NEW SECURITY (MARITA RESPIN) PHONE PHONE STATE: "RETAIL" FLASH CID: 0051 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35350501479484 CERT:RED LDR:061205 1354 HAN_DB2012_FLASHLOADER_R2B012_CXC1326738 FLASH ID:897E LDR:070410 1405 HANCXC1327364_COMPACT_SEMC_CS_LOADER_1_R3B009 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM39 PHONE READY TO PROCEED EXECUTOR STARTED REMOVE CABLE FROM PHONE REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK FINALLY PRESS "READY" ChipID:8040,EMP protocol:0301 NEW SECURITY (MARITA RESPIN) PHONE PHONE STATE: "RETAIL" FLASH CID: 0051 Speed:921600 Starting embedded bootloader... INT LDR ![]() LDR ![]() FLASH ID:897E UPLOADING REST FILE "D:\BACKUP 1\SE TOOLS\rest\R6GA004_CXC1250583_GENERIC_ML"... Searching... Firmware SIMLOCK check determined. Unlock FINISHED Elapsed: 143 secs. ![]() ![]() ![]() |
![]() | #2 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Aug 2009 Location: Partap Mobile Point, Jalandhar
Member: 1088851 Status: Offline Thanks Meter: 17 | i have same model here.... in identify its showing me simlock-status is NOT DETECTED.........i also posting the logs here CFG:000000000000000 ChipID:8040,EMP protocol:0301 NEW SECURITY (MARITA RESPIN) PHONE PHONE STATE: "RETAIL" FLASH CID: 0051 Speed:921600 Flash ID check:897E Flash props sent ok OTP: LOCKED:1 CID:51 PAF:1 IMEI:35350501307437 CERT:RED FLASH CID:51 COLOR:RED Model (from GDFS):Z550a Brand:Fido MAPP CXC article: R6GA004 prgCXC1250583_GENERIC_ML MAPP CXC version: R6GA004 Language Package: ROGERS CDA article: CDA102731/14 CDA version: R10A Default article: cxc1250506 Default version: R6GA004 PROVIDER: 000-00 SIMLOCKS NOT DETECTED USERCODE:0000 RESTORATION FILE PRESENT FOR DETECTED FIRMWARE SECURITY UNITS BACKUP CREATED. Elapsed: 7 secs. |
samsung sghf266 lock to fido sim unlock via z3x | KIKO_GSM | Z3X-Team Products | 0 | 12-23-2009 09:29 |
822p unlock done,,,,,via red sim..... | crv_shop | Panasonic | 4 | 10-16-2009 02:17 |
-=t303 unlock done by setools via logs=- | daveiant | SETool2 | 0 | 06-02-2009 10:40 |
-=t303 unlock done by setools via logs=- | daveiant | SETool2 | 0 | 06-02-2009 10:35 |
K300i Unlock Successfully Done Via SETool | redwolf | SETool2 | 5 | 09-14-2008 08:12 |
