09-03-2010, 15:06 | #1 (permalink) |
Freak Poster Join Date: May 2009
Member: 1023256 Status: Offline Thanks Meter: 48 | Need help to unlock W880i by setool CARD SERIAL xxxxxxxxxxx USBFLASH DRIVER VERSION 02.02.00.05 CFG:000000000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:115200 FLASH ID: 2019 OTP LOCKED:1 CID:51 PAF:1 IMEI:35777401670365 CERT:RED ACTIVE CID:52 COLOR:RED Model (from GDFS):W880i MAPP CXC article: R1KG001 prgCXC1250640_GENERIC_AI MAPP CXC version: R1KG001 Language Package: EUROPE_1 CDA article: CDA102568/10 CDA version: R3A Default article: cxc1250651 Default version: R8BA024 PROVIDER: MULTIPLE Network LOCKED RESTORATION FILE PRESENT FOR DETECTED FIRMWARE SECURITY UNITS BACKUP CREATED. Elapsed: 13 secs. |
09-03-2010, 17:59 | #2 (permalink) |
Member: 1023256 Status: Offline Thanks Meter: 48 | i tried many way to unlock but not unlock "network locked" finally i solved this way RUNNING v 1.086/UNI CARD SERIAL xxxxxxxxxxx USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) CFG:100000000000 RESET MODE STARTED ChipID:9900,EMP protocol:0301 Speed:115200 RESET:070703 1106 NPACXC1250329_DB2020_CERTRESETLOADER_P3AA FLASH ID: 2019 GOT SEED:847FB9F123808E7515D0A9A3 P96 AUTH PASSED OTP LOCKED:1 CID:51 PAF:1 IMEI:35777401670365 PHONE SUCCESSFULLY RESET TO DEVELOPER STATE Elapsed: 28 secs. CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:115200 OTP LOCKED:1 CID:51 PAF:1 IMEI:35777401670365 ACTIVE CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID: 2019 writing "D:\SETOOL\v1.086\gdfs_in_ssw_format\db2020\W880_G DFS_SSW.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 640 Will flash 32 blocks... Elapsed: 204 secs. CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:115200 OTP LOCKED:1 CID:51 PAF:1 IMEI:35777401670365 ACTIVE CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID: 2019 Setting up GDFS... IMEI MISMATCH ! ORIGINAL IMEI:35777401670365 CURRENT IMEI:35578501376525 WRITING CLEAR SIMLOCK UNITS... SIMLOCK CODES SET TO "75375117" SIGNING... Unlock DONE Elapsed: 17 secs. CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:115200 OTP LOCKED:1 CID:51 PAF:1 IMEI:35777401670365 ACTIVE CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID: 2019 writing "D:\SETOOL\v1.086\eroms\db2020\DB2020EROM_CNV_RED5 2_BROWN_CID49_DB2020.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 40 Will flash 2 blocks... Elapsed: 30 secs. CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:115200 FLASH ID: 2019 OTP LOCKED:1 CID:51 PAF:1 IMEI:35777401670365 ACTIVE CID:52 COLOR:RED Model (from GDFS):W880i Brand:Sony Ericsson MAPP CXC article: R6BC002 prgCXC1250640_GENERIC_AI MAPP CXC version: R6BC002 Language Package: EUROPE_4 CDA article: CDA102568/13 CDA version: R5A Default article: cxc1250651 Default version: R6BC002 PROVIDER: 000-00 SIMLOCKS NOT DETECTED RESTORATION FILE NOT PRESENT "R6BC002_CXC1250640_GENERIC_AI" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED Elapsed: 6 secs. SIGNED MODE (USING SERVER) CFG:101100000000 ChipID:9900,EMP protocol:0301 Speed:115200 OTP LOCKED:1 CID:51 PAF:1 IMEI:35777401670365 ACTIVE CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID: 2019 writing "D:\SETOOL\flash file\W880\cid-52\R8BC004\R8BC004_1250640_GENERIC_AI.ssw" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is: 9200 Will flash 460 blocks... writing "D:\SETOOL\flash file\W880\cid-52\R8BC004\R8BC004_FS_EUROPE_4_AI_RED_CID52.ssw" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is: 2740 Will flash 137 blocks... LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader GDFS startup executed loader FILESYSTEM startup executed USERCODE RESET TO "0000" using GENERIC phone customization tpa/preset/custom/C3_PCA_G3v2.cer tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm tpa/preset/custom/customize.xml tpa/preset/custom/DESKTOP_HOOK_2.itm tpa/preset/custom/Entrust.net Root Certificate.cer tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt tpa/preset/custom/FM_PICTURES_HOOK_3.itm tpa/preset/custom/FM_SOUNDS_HOOK_3.itm tpa/preset/custom/FM_THEMES_HOOK_3.itm tpa/preset/custom/FM_VIDEOS_HOOK_3.itm tpa/preset/custom/GAMES_HOOK_3.itm tpa/preset/custom/GTE_CyberTrust_Root.cer tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt tpa/preset/custom/Root.cer tpa/preset/custom/SEMC_E2E_Root_CA.crt tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm tpa/preset/custom/ThawtePremium.der tpa/preset/custom/ThawteServerCA.cer tpa/preset/custom/Utiroot.cer tpa/preset/custom/VeriSignClass3Root.cer tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt Phone detached Elapsed: 3569 secs. |
09-03-2010, 18:17 | #3 (permalink) |
No Life Poster Join Date: Jun 2010 Age: 14
Member: 1315677 Status: Offline Thanks Meter: 1,439 | Follow carefully these steps CID 50,51,52,53 that is so-called reset procedure. 1. go to emptyboard tab 2. select W880 3. on settings, check "signed mode" 4. press recovery 5. after successful recovery 6. on settings uncheck all 7. Add to firmware area D:\SETOOL\v1.086\gdfs_in_ssw_format\db2020\W880_G DFS_SSW.ssw 8. add to firmware area D:\SETOOL\v1.086\eroms\db2020\DB2020EROM_CNV_RED52 _BROWN_CID49_DB2020.ssw 9. press flash 10. if needed,reflash phone on usual semc tab with needed settings. At the step 7. you should stay in emptyfill and repair tab. So flash the gdfs and the erom from emptyfill and repair tab instead of sonyericsson one That is all Use the usb cable or set the speed to 921000 |
09-14-2010, 04:58 | #4 (permalink) |
No Life Poster Join Date: Mar 2008
Member: 725834 Status: Offline Thanks Meter: 921 | w880 flash with unlock,,,,,,,,,,infoo here RUNNING v 1.02/UNI CARD SERIAL 00****** USBFLASH DRIVER VERSION 02.02.00.05 CFG:000000000000 ChipID:9900,EMP protocol:0301 OBSOLETE EROM,FORCING "CID49" erom_readvar: error reading unit 0/6 error while reading security units SECURITY UNITS CAN'T BE READ ! DAMAGED FIRMWARE,GDFS OR EMPTY PHONE CONTINUE ON YOUR OWN RISK PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:115200 Can't load ID loader !,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,bad infoo try again Elapsed: 73 secs. SIGNED MODE (USING SERVER) PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:100000000000 RESET MODE STARTED ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0051 PLEASE CONNECT PHONE IN "BOOTROM" MODE Elapsed: 8 secs. SIGNED MODE (USING SERVER) PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:100000000000 RESET MODE STARTED ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0051 PLEASE CONNECT PHONE IN "BOOTROM" MODE Elapsed: 7 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0051 Speed:115200 FLASH ID: 2019 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35578501262696 CERT:RED FLASH CID:51 COLOR:RED Model (from GDFS):W880i Brand:Vodafone MAPP CXC article: R1JC002 prgCXC1250641_VODAFONE_AI MAPP CXC version: R1JC002 Language Package: VFE_LIVE_2 CDA article: CDA102719/81 CDA version: R7A Default article: cxc1250651 Default version: R1JC002 PROVIDER: 234-15 Network LOCKED RESTORATION FILE NOT PRESENT "R1JC002_CXC1250641_VODAFONE_AI" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED SECURITY UNITS BACKUP CREATED. Elapsed: 8 secs. SIGNED MODE (USING SERVER) CFG:100100000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0051 Speed:115200 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35578501262696 CERT:RED FLASH CID:51 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID: 2019 writing "L:\2= ALL SE TOOL SET UP\Setool 1\SeTool\DOWNLOAD\sony\w-880\51\R1JC002_1250640_GENERIC_AI.ssw" CURRENT FLASH FILE CID:51 SSW uses full hash, hash len is: 9200 Will flash 460 blocks... writing "L:\2= ALL SE TOOL SET UP\Setool 1\SeTool\DOWNLOAD\sony\w-880\51\R1JC002_FS_S_ASIA_LEVAN_AI_RED_CID51.ssw" CURRENT FLASH FILE CID:51 SSW uses full hash, hash len is: 2820 Will flash 141 blocks... LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader GDFS startup executed loader FILESYSTEM startup executed using GENERIC phone customization tpa/preset/custom/C3_PCA_G3v2.cer tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm tpa/preset/custom/customize.xml tpa/preset/custom/DESKTOP_HOOK_2.itm tpa/preset/custom/Entrust.net Root Certificate.cer tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt tpa/preset/custom/FM_PICTURES_HOOK_3.itm tpa/preset/custom/FM_SOUNDS_HOOK_3.itm tpa/preset/custom/FM_THEMES_HOOK_3.itm tpa/preset/custom/FM_VIDEOS_HOOK_3.itm tpa/preset/custom/GAMES_HOOK_3.itm tpa/preset/custom/GTE_CyberTrust_Root.cer tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt tpa/preset/custom/Root.cer tpa/preset/custom/SEMC_E2E_Root_CA.crt tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm tpa/preset/custom/ThawtePremium.der tpa/preset/custom/ThawteServerCA.cer tpa/preset/custom/Utiroot.cer tpa/preset/custom/VeriSignClass3Root.cer tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt Phone detached Elapsed: 394 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0051 Speed:115200 FLASH ID: 2019 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35578501262696 CERT:RED FLASH CID:51 COLOR:RED Model (from GDFS):W880i Brand:Generic MAPP CXC article: R1JC002 prgCXC1250640_GENERIC_AI MAPP CXC version: R1JC002 Language Package: S_ASIA_LEVAN CDA article: CDA102568/1 CDA version: R2A Default article: cxc1250651 Default version: R1JC002 PROVIDER: 234-15 Network LOCKED SEARCH:L:\2= ALL SE TOOL SET UP\Setool 1\SeTool\DOWNLOAD\sony\w-880\51\R1JC002_1250640_GENERIC_AI.ssw "R1JC002_CXC1250640_GENERIC_AI" CREATED SECURITY UNITS BACKUP CREATED. Elapsed: 17 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PRELOADER SECURITY BYPASS ENABLED CFG:111010000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0051 Speed:115200 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35578501262696 CERT:RED FLASH CID:51 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID: 2019 LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader GDFS startup executed loader FILESYSTEM startup executed DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PROCEDURE WAS STOPPED BY USER Can't find attached phone with IMEI "35578501262696" Elapsed: 68 secs. PRELOADER SECURITY BYPASS ENABLED CFG:001000000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0051 Speed:115200 STARTING BOOTLOADER... INT LDRB2020_PRELOADER_FOR_SETOOL2 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35578501262696 CERT:RED LDRB2020 LOADER FOR SETOOL2 FOUND VERSION "R1JC002_CXC1250640_GENERIC_AI" USERCODE RESET TO "0000" Searching... Firmware SIMLOCK check determined. Unlock FINISHED Elapsed: 36 secs. |
04-24-2013, 07:06 | #5 (permalink) |
No Life Poster Join Date: Dec 2007 Location: pakistan Age: 41
Member: 653398 Status: Offline Thanks Meter: 669 | W880 unlock done via com cable RUNNING v 1.1297/01.15/UNI CARD SERIAL 00078213 USBFLASH DRIVER VERSION 03.00.00.00 ALTERNATIVE SECURITY BYPASS ENABLED CFG:010000000000 ChipID: 9900, EMP protocol: 0301 SPEED: 921600 STARTING BOOTLOADER ... PROCEDURE WAS STOPPED BY USER FLASHLOADER NOT RESPONDING Unlock FAILED Elapsed: 282 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110000000000 ChipID: 9900, EMP protocol: 0301 SPEED: 921600 LDR: 071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M OTP: LOCKED:1 CID:51 PAF:1 IMEI:35777401621963 CURRENT CID: 52 COLOR: RED FLASH ID: 897E Downgrading security ... ChipID: 9900, EMP protocol: 0301 SPEED: 921600 RESET: 070703 1106 NPACXC1250329_DB2020_CERTRESETLOADER_P3AA GOT SEED: EBA96D4323808E7515B0D897 P96 AUTH PASSED Restarting ... ChipID: 9900, EMP protocol: 0301 SPEED: 921600 LDR: DB2020 LOADER FOR SETOOL2 CURRENT CID: 49 COLOR: BROWN Setting up GDFS ... WRITING CLEAR SIMLOCK UNITS ... SIMLOCK CODES SET TO "11887508" SIGNING ... Unlock DONE Elapsed: 41 secs. |
09-04-2013, 18:54 | #6 (permalink) |
Crazy Poster Join Date: May 2007
Member: 510497 Status: Offline Thanks Meter: 18 | unlock ok!!! by Com port Elapsed: 102 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110000000000 ChipID: 9900, EMP protocol: 0301 SPEED: 921600 LDR: 071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M OTP: LOCKED:1 CID:51 PAF:1 IMEI:35777401520927 CURRENT CID: 52 COLOR: RED FLASH ID: 897E Downgrading security ... ChipID: 9900, EMP protocol: 0301 SPEED: 921600 RESET: 070703 1106 NPACXC1250329_DB2020_CERTRESETLOADER_P3AA GOT SEED: 06A1017223808E7515F02D7F P96 AUTH PASSED Restarting ... ChipID: 9900, EMP protocol: 0301 SPEED: 921600 LDR: DB2020 LOADER FOR SETOOL2 CURRENT CID: 49 COLOR: BROWN Setting up GDFS ... WRITING CLEAR SIMLOCK UNITS ... SIMLOCK CODES SET TO "12872212" SIGNING ... Unlock DONE Elapsed: 27 secs. |
08-07-2015, 12:54 | #7 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Unlock done by comport... PLEASE CONNECT PHONE IN "BOOTROM" MODE Unlock FAILED Elapsed: 18 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000000 ChipID: 9900, EMP protocol: 0301 SPEED: 115200 LDR: 071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M OTP: LOCKED:1 CID:51 PAF:1 IMEI:35777401060994 CURRENT CID: 51 COLOR: RED FLASH ID: 897E Downgrading security ... ChipID: 9900, EMP protocol: 0301 SPEED: 115200 RESET: 070703 1106 NPACXC1250329_DB2020_CERTRESETLOADER_P3AA GOT SEED: 663C469823808E751520E40E P96 AUTH PASSED Restarting ... ChipID: 9900, EMP protocol: 0301 SPEED: 115200 LDR: DB2020 LOADER FOR SETOOL2 CURRENT CID: 49 COLOR: BROWN Setting up GDFS ... WRITING CLEAR SIMLOCK UNITS ... SIMLOCK CODES SET TO "17228840" SIGNING ... Unlock DONE Elapsed: 78 secs. |
The Following User Says Thank You to razib143 For This Useful Post: |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
