u8330 dead comes .. Flashed but no success ti get it back work SETOOL BOX 3 Tried to do flash Lg U8330 with diff version 3 UK 3 AUs with v11 and v20(from support Files) but nosccess here is logg with diff .version .. please let me know what is wrong and which file to be choose and flash steps with SETOOL BOX3 thanks v0.915034/UNI CARD SERIAL: 00xxx Loaded 51 flash descriptors Open COM port OK ChipID:7100,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0042 Speed:460800 OTP: LOCKED:1 CID:42 PAF:1 IMEI:xxx CERT:RED LDR:040318 1450 LLECXC1325413_CERTLOADER R3J LDR:041214 0759 MATCXC1325712_PRODUCTION R2Z Flash ID check:890D Flash props sent ok SWITCHING TO "USB"... interface not changed writing "D:\Documents and Settings\Best\Desktop\v118330uk\U8330_v11h_UK_Hutc hinson\drive_c_cid42r.cry" CURRENT FLASH FILE CID:254 SSW uses dynamic hash, dynamic hash len is:176 Will flash 176 blocks... subblock 016 NAK, [21780000/00010000] Elapsed: 229 secs. Open COM port OK ChipID:7100,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0042 Speed:460800 loader header not accepted FAILED TO SETUP PHONE Elapsed: 27 secs. Open COM port OK PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Elapsed: 30 secs. Open COM port OK ChipID:7100,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0042 Speed:460800 OTP: LOCKED:1 CID:42 PAF:1 IMEI:xxx CERT:RED LDR:040318 1450 LLECXC1325413_CERTLOADER R3J LDR:041214 0759 MATCXC1325712_PRODUCTION R2Z Flash ID check:890D Flash props sent ok LG3G patching started. simlock #1 not found,THAT IS BAD. not found incomplete InitCard,THAT IS OK. Firmware OTP restriction NOT found,THAT IS OK. firmware selfcheck not found,THAT IS OK. operator check found inside poweron.pxe Phone detached Elapsed: 50 secs. Open COM port OK ChipID:7100,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0042 Speed:460800 OTP: LOCKED:1 CID:42 PAF:1 IMEI:xxx CERT:RED LDR:040318 1450 LLECXC1325413_CERTLOADER R3J LDR:041214 0759 MATCXC1325712_PRODUCTION R2Z Flash ID check:890D Flash props sent ok SWITCHING TO "USB"... interface not changed writing "D:\Documents and Settings\Best\Desktop\U8330_v20h_UK Hutchison\U8330_v20h_UK Hutchison\drive_c_cid42r.cry" CURRENT FLASH FILE CID:254 SSW uses dynamic hash, dynamic hash len is:176 Will flash 176 blocks... subblock 004 NAK, [21280000/00010000] Elapsed: 124 secs. Open COM port OK PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Elapsed: 122 secs. Open COM port OK ChipID:7100,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0042 Speed:460800 OTP: LOCKED:1 CID:42 PAF:1 IMEI:xxx CERT:RED LDR:040318 1450 LLECXC1325413_CERTLOADER R3J LDR:041214 0759 MATCXC1325712_PRODUCTION R2Z Flash ID check:890D Flash props sent ok SWITCHING TO "USB"... interface not changed Will read 00020000 bytes,starting from 44000000 Reading:131072 bytes ReadFLS: ERROR|GetFlashInfo| phone detached Elapsed: 49 secs. Open COM port OK ChipID:7100,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0042 Speed:115200 OTP: LOCKED:1 CID:42 PAF:1 IMEI:xxxx CERT:RED LDR:040318 1450 LLECXC1325413_CERTLOADER R3J LDR:041214 0759 MATCXC1325712_PRODUCTION R2Z Flash ID check:890D Flash props sent ok SWITCHING TO "USB"... interface not changed Will read 00020000 bytes,starting from 44000000 Reading:131072 bytes ReadFLS: ERROR|GetFlashInfo| phone detached Elapsed: 117 secs. Open COM port OK PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Elapsed: 153 secs. Open COM port OK ChipID:7100,EMP protocol:0301 PHONE STATE: "UNKNOWN" [00000000] SUPPORTED FLASH CID IS NOT DETECTED [0259] skipping empty loader... FAILED TO SETUP PHONE Elapsed: 41 secs. Open COM port OK ChipID:7100,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0042 Speed:115200 OTP: LOCKED:1 CID:42 PAF:1 IMEI:xxx CERT:RED LDR:040318 1450 LLECXC1325413_CERTLOADER R3J LDR:041214 0759 MATCXC1325712_PRODUCTION R2Z Flash ID check:890D Flash props sent ok SWITCHING TO "USB"... interface not changed writing "D:\Documents and Settings\Best\Desktop\u8330v20aus\U8330_v20c_Austr alia_Hutchison\drive_c_cid42r.cry" CURRENT FLASH FILE CID:254 SSW uses dynamic hash, dynamic hash len is:176 Will flash 176 blocks... subblock 000 NAK, [21310000/00010000] Elapsed: 281 secs. Open COM port OK PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Elapsed: 94 secs. Open COM port OK PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Elapsed: 49 secs. Open COM port OK ChipID:7100,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0042 Speed:115200 OTP: LOCKED:1 CID:42 PAF:1 IMEI:xxx CERT:RED LDR:040318 1450 LLECXC1325413_CERTLOADER R3J LDR:041214 0759 MATCXC1325712_PRODUCTION R2Z Flash ID check:890D Flash props sent ok LG3G patching started. simlock #1 not found,THAT IS BAD.(this is while unlock procedure I can read)) not found incomplete InitCard,THAT IS OK. Firmware OTP restriction NOT found,THAT IS OK. firmware selfcheck not found,THAT IS OK. Phone detached Elapsed: 58 secs. Open COM port OK ChipID:7100,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0042 Speed:460800 OTP: LOCKED:1 CID:42 PAF:1 IMEI:xxx CERT:RED LDR:040318 1450 LLECXC1325413_CERTLOADER R3J LDR:041214 0759 MATCXC1325712_PRODUCTION R2Z Flash ID check:890D Flash props sent ok SWITCHING TO "USB"... interface not changed writing "D:\Documents and Settings\Best\Desktop\U8330_v20h_UK Hutchison\U8330_v20h_UK Hutchison\drive_c_cid42r.cry" CURRENT FLASH FILE CID:254 SSW uses dynamic hash, dynamic hash len is:176 Will flash 176 blocks... subblock 003 NAK, [215D0000/00010000] Elapsed: 159 secs. |
