02-02-2010, 10:41 | #1 (permalink) |
No Life Poster Join Date: Jun 2006 Location: pakistan Age: 34
Member: 294245 Status: Offline Sonork: 100.1602405 Thanks Meter: 115 | W580 5lock closed not done CARD SERIAL: 00064305 Loaded 51 flash descriptors SIGNED MODE (USING SERVER) CFG:100001000000 No server found. CARD COUNTERS: FLASH 622, UNLOCK 532 Elapsed: 2 secs. SIGNED MODE (USING SERVER) CFG:100001000000 SERVER CREDITS LEFT/USED: 13/17 CARD COUNTERS: FLASH 622, UNLOCK 532 Elapsed: 3 secs. SIGNED MODE (USING SERVER) CFG:100001000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35923501852770 CERT:RED FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID:897E LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 Executing CSCA-based unlock. Checking for signature... signature found, skipping calculation Backup security data... loader startup: executed loader GDFS startup: executed loader unlock: executed Erasing locks... DISCONNECT PHONE NOW REMOVE SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM18 BAD SCRC INSIDE PHONE. CSCA UNLOCK FAILED Elapsed: 97 secs. plz help |
02-02-2010, 13:43 | #4 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Russia Age: 44
Member: 9519 Status: Offline Thanks Meter: 2,150 | before doing anything user should execute identify operation. identify will show "imei mismatch" in that case - user should do NOT full signature unlock, but "reset" operation (without gdfs writing, because gdfs okay) |
02-03-2010, 15:36 | #6 (permalink) |
No Life Poster Join Date: May 2004 Location: India
Member: 65074 Status: Offline Sonork: 100.1611263 Thanks Meter: 214 | The Following is the Laser's Original Post. Code: q: how i can repair any software problem in db200x/db201x,db2020 phone ? phone totally damaged, identify not working, gdfs is corrupted, erom is absent, etc. a: that feature require release >= v0.915043. 1. make sure you have needed quantity of credits on your account 2. select proper model 3. on settings check only "signed mode (using server)" 4. if phone db200x,db201x select COM/UFS as interface. if phone is db2020 - you can select COM/UFS/USB as interface. if phone is db2020 and USB interface selected - you MUST boot phone in bootrom mode (hold "2+5" while inserting cable) 5. press "recovery". 6. if phone hardware okay (flash chip,ram,etc) - phone will be reset to developer status (brown) 7. phone is BROWN now. 8. staying on "emptyboard fill and repair" write correct gdfs_in_ssw format. 9. if flashing went fine, flash db2020 erom with needed CID, still on "emptyboard fill" tab 10. phone now retail and repaired. fullflash phone as usual. Shubhanshu |
04-28-2010, 00:31 | #7 (permalink) | |
No Life Poster Join Date: Feb 2010 Location: Panama, Panama
Member: 1229408 Status: Offline Sonork: 100.1603133 Thanks Meter: 1,917 | Quote:
04-28-2010, 07:03 | #8 (permalink) | |
No Life Poster Join Date: Jun 2006 Location: {JUST@PRAY@FOR@ME} Age: 39
Member: 288504 Status: Offline Sonork: .:100.1587032:. Thanks Meter: 2,266 | Quote:
see FAQ | |
F305 5 lock closed not done | mike3636 | Universalbox | 1 | 02-18-2010 19:17 |
K320 5Lock Close DONE by SETOOL via TP | rico_deep | SETool2 | 21 | 03-28-2009 12:04 |
W810 CID50 5lock closed | mobile_juice | SETool2 | 12 | 02-02-2009 13:17 |
K320 Cid50 5lock closed | yousaf22us | DreamBox | 2 | 08-11-2008 11:08 |
c62 5locks closed | tatalko | NON Siemens Brand (ODM Phones) | 6 | 04-22-2005 17:35 |
