06-25-2011, 11:10 | #1 (permalink) |
No Life Poster Join Date: Sep 2010 Location: In trouble Age: 49
Member: 1388004 Status: Offline Sonork: 100.1637034 Thanks Meter: 444 | w20i "phone not responds to AT..." > 5 locks I've tried to unlock this w20i by checking that in settings : signed mode, full unlock, disable flash. And here's the issue : Code: SIGNED MODE (USING SERVER) CFG:100011000000 ChipID:F100,EMP protocol:0401 PHONE STATE: "RETAIL" FLASH CID: 0081 OTP LOCKED:1 CID:81 PAF:1 IMEI:01253000854098 CERT:RED LDR:2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature... signature found, skipping calculation Backup security data... Erasing locks... DISCONNECT PHONE NOW REMOVE SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM36 Phone not responds to AT #1, retry 1 Phone not responds to AT #1, retry 2 Phone not responds to AT #1, retry 3 Phone not responds to AT #1, retry 4 Phone not responds to AT #1, retry 5 CSCA UNLOCK FAILED Unlock FAILED Elapsed: 56 secs. Tnx to all ! |
06-25-2011, 12:44 | #2 (permalink) |
Member: 1388004 Status: Offline Sonork: 100.1637034 Thanks Meter: 444 | After searching on differents boards, it seems I have to flash phone with rcXXXX firmware, am I right ? The problem is each time I try to download from support it gets me to an Access violation page... Where else can I dl firmware ? BR |
06-26-2011, 08:53 | #4 (permalink) |
Member: 1388004 Status: Offline Sonork: 100.1637034 Thanks Meter: 444 | Thank you for answering, I'm gonna try it and see if that works. But do you know where I can download firmware, cause I would like to try it also, and each time I try with support, it opens access violation page, but counts 1 download anyway... |
06-26-2011, 10:56 | #6 (permalink) |
Member: 1388004 Status: Offline Sonork: 100.1637034 Thanks Meter: 444 | I use 1.106, box activated, trying to connect with firefox, cookies enabled. I succeeded before to download. I'm gonna check with an other pc if that works. |
06-26-2011, 10:56 | #7 (permalink) |
06-26-2011, 11:18 | #8 (permalink) | |
Freak Poster Join Date: Jan 2010 Location: romania Age: 33
Member: 1202098 Status: Offline Sonork: none Thanks Meter: 19 | Quote:
then retry unlocking with signed mode+unlock instead of usercode reset+disable flash mode activation. no more credits will be deducted. after program says unlock done do not remove battery/cable from phone else you will get 5 lock and need to repeat operation | |
The Following User Says Thank You to demoxx For This Useful Post: |
06-26-2011, 12:22 | #9 (permalink) |
Member: 1388004 Status: Offline Sonork: 100.1637034 Thanks Meter: 444 | @sahil2000ind : it's downloading on an other computer, with firefox and setool v1.09, so I will check the one I use to work with, cause I can't figure out why I have this problem on the first pc. As soon as dl is done, I will keep you informed about success or not |
06-26-2011, 12:26 | #10 (permalink) |
No Life Poster Join Date: Jun 2011 Age: 13
Member: 1597873 Status: Offline Thanks Meter: 169 | if u have backup script write to phone then do unlock again. in settings use this --> signed mode+unlock instead of usercode reset+disable flash mode activation wbr, setool_helper |
06-26-2011, 13:10 | #11 (permalink) |
Member: 1388004 Status: Offline Sonork: 100.1637034 Thanks Meter: 444 | w20i "phone not responds to AT" 5 locks [SOLVED] Thank you all, problems solved. After downgrading firmware, unlocking was really fast, even with v1.09, here's full log : Code: RUNNING v 1.09/UNI CARD SERIAL 00153xxx USBFLASH DRIVER VERSION 02.02.00.05 CFG:000000000000 ChipID:F100,EMP protocol:0401 PHONE STATE: "RETAIL" FLASH CID: 0081 OTP LOCKED:1 CID:81 PAF:1 IMEI:01253000854098 CERT:RED LDR:2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA writing "C:\Documents and Settings\STunlock\Bureau\w20_r7ca061_firmware\R7CA061.APP_SW_1232_9903_GENERIC_TO_REDBROWNBLUE_CID81_80_53_52_49_DB3350.SOFTWARE" ALLOWED DOMAINS:BLUE BROWN RED MAXIMUM CID:81 Will flash 1009 blocks... ssw file accepted writing "C:\Documents and Settings\STunlock\Bureau\w20_r7ca061_firmware\R7CA061.FS_WESTERN_EUROPE_TO_REDBROWNBLUE_CID81_80_53_52_49.SOFTWARE" ALLOWED DOMAINS:BLUE BROWN RED MAXIMUM CID:81 Will flash 2623 blocks... ssw file accepted Elapsed: 508 secs. SIGNED MODE (USING SERVER) CFG:100011000000 ChipID:F100,EMP protocol:0401 PHONE STATE: "RETAIL" FLASH CID: 0081 OTP LOCKED:1 CID:81 PAF:1 IMEI:01253000854098 CERT:RED LDR:2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature... Waiting for calculation process... RESPONSE: "SUCCESS" [1038] Backup security data... Erasing locks... DISCONNECT PHONE NOW REMOVE SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM108 PHONE READY TO PROCEED. GOT SEED:00DCB3CE ACTIVATION COMPLETED. USERCODE RESET TO "0000" Unlock DONE Elapsed: 96 secs. |
06-28-2011, 12:43 | #13 (permalink) |
No Life Poster Join Date: May 2007 Location: uk
Member: 508100 Status: Offline Sonork: 1600934 Thanks Meter: 189 | SIGNED MODE (USING SERVER) CFG:101000000000 ChipID:F100,EMP protocol:0401 PHONE STATE: "RETAIL" FLASH CID: 0081 OTP LOCKED:1 CID:81 PAF:1 IMEI:01253000489314 CERT:RED LDR:2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA writing "C:\Documents and Settings\user\Desktop\setool\w20 zylo\R7CA061.APP_SW_1232_9903_GENERIC_TO_REDBROWNB LUE_CID81_80_53_52_49_DB3350 (1).SOFTWARE" ALLOWED DOMAINS:BLUE BROWN RED MAXIMUM CID:81 Will flash 1009 blocks... ssw file accepted writing "C:\Documents and Settings\user\Desktop\setool\w20 zylo\R7CA061.FS_WESTERN_EUROPE_TO_REDBROWNBLUE_CID 81_80_53_52_49.SOFTWARE" ALLOWED DOMAINS:BLUE BROWN RED MAXIMUM CID:81 Will flash 2623 blocks... ssw file accepted using GENERIC phone customization tpa/preset/custom/CONTENT_DOWNLOAD_HOOK.itm tpa/preset/custom/FM_PICTURES_HOOK_3.itm tpa/preset/custom/FM_SOUNDS_HOOK_3.itm tpa/preset/custom/FM_THEMES_HOOK_3.itm tpa/preset/custom/FM_VIDEOS_HOOK_3.itm tpa/preset/custom/GAMES_HOOK_3.itm tpa/preset/custom/MC_MUSIC_HOOK_3.itm tpa/preset/custom/MC_PHOTO_HOOK_3.itm tpa/preset/custom/MC_VIDEO_HOOK_3.itm tpa/preset/custom/ORG_APPLICATIONS_HOOK_3.itm tpa/preset/custom/preloaded_config.xml tpa/preset/custom/SETT_RINGTONE_HOOK_1.itm tpa/preset/custom/SETT_SCREENSAVER_HOOK_1.itm tpa/preset/custom/SETT_STARTSHOW_HOOK_1.itm tpa/preset/custom/SETT_WALLPAPER_HOOK_1.itm tpa/preset/custom/Customize.xml Elapsed: 626 secs. SIGNED MODE (USING SERVER) CFG:100011000000 No server found. CARD COUNTERS: FLASH 786, UNLOCK 552 Elapsed: 22 secs. SIGNED MODE (USING SERVER) CFG:100011000000 No server found. CARD COUNTERS: FLASH 786, UNLOCK 552 Elapsed: 22 secs. SIGNED MODE (USING SERVER) CFG:100011000000 No server found. CARD COUNTERS: FLASH 786, UNLOCK 552 Elapsed: 22 secs. SIGNED MODE (USING SERVER) CFG:100011000000 ChipID:F100,EMP protocol:0401 PHONE STATE: "RETAIL" FLASH CID: 0081 OTP LOCKED:1 CID:81 PAF:1 IMEI:01253000489314 CERT:RED LDR:2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature... signature found, skipping calculation Backup security data... Erasing locks... DISCONNECT PHONE NOW REMOVE SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM425 PHONE READY TO PROCEED. GOT SEED:00FE4B8E ACTIVATION COMPLETED. USERCODE RESET TO "0000" Unlock DONE Elapsed: 85 secs. i hv repeted that again aswell but....... phone is still locked 5 lock |
06-28-2011, 22:14 | #15 (permalink) |
No Life Poster Join Date: Jun 2010 Age: 14
Member: 1315677 Status: Offline Thanks Meter: 1,440 | Code: Backup security data... Erasing locks... DISCONNECT PHONE NOW REMOVE SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM425 PHONE READY TO PROCEED. GOT SEED:00FE4B8E ACTIVATION COMPLETED. USERCODE RESET TO "0000" Unlock DONE Elapsed: 85 secs. |
The Following User Says Thank You to :Aishur: For This Useful Post: |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
