w610i dead after unlock is it yet possable to repair these / repair gdfs ? if so how ? best regards ;) |
I think you missed restore file. |
yes maybe , bad mistake not to check i have restore file i used recovery PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:101000000000 RESET MODE STARTED ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 RESET:070703 1106 NPACXC1250329_DB2020_CERTRESETLOADER_P3AA FLASH ID: 897E GOT SEED:078BB50523804E6A15D04E68 P96 AUTH PASSED OTP LOCKED:1 CID:51 PAF:1 IMEI:35489401427245 PHONE SUCCESSFULLY RESET TO DEVELOPER STATE then try to reflash but fail CFG:001000000000 ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35489401427245 ACTIVE CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID: 897E writing "C:\Documents and Settings\dell\Desktop\SeTool_v1.07\flash files\w610i\cid51\R1JD001_1250747_GENERIC_NA.ssw" CURRENT FLASH FILE CID:51 SSW uses full hash, hash len is: 9200 HDR block not accepted,error: 19 Elapsed: 11 secs. please advise , thanks |
can a anyone help please ? how can i tell what is proper cid of this phone ? best regards |
finish the reset procedure flash first DB2020EROM_CNV_RED51_BROWN_CID49_DB2020.ssw from emptyfill tab, setttings: none |
thanks , i did as you said aishur - below is log BOOTROM MODE DETECTED Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35489401427245 ACTIVE CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID: 897E writing "C:\Documents and Settings\dell\Desktop\SeTool_v1.07\eroms\db2020\DB 2020EROM_CNV_RED51_BROWN_CID49_DB2020.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 80 Will flash 4 blocks... Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... SIGNING... Elapsed: 17 secs. then went to normal se tab tab - and flashed with full flash ( signed + complete phone mode ticked) then choose identify - so created restore file automatically then clicked unlock/repair (signed mode ticked ) and sucess - phone alive and unlocked , thanks for your help !! |
ah i see , thanks for your infomation cheers ! |
